SD103AWS THRU SD103CWS
Reverse Voltage 20-40 Volts
Forward Current - 0.35 Ampere
SCHOTTKY DIODES
Features
SOD-323
0.016(0.40)
0.057(1.45)
0.007(0.20)
0.043(1.10)
0.008(0.20)max.
Cathode bar
Low forward voltage drop
Guard ring construction for transient protection
Negligible reverse recovery time
0.070(1.80)
0.063 (1.40)
0.110 (2.80)
Absolute Maximum Ratings at 25 °C
PARAMETER
0.006 (0.15)
0.024 (0.60)
0.014 (0.35)
Dimensions in inches and (millimeters)
SYMBOLS
SD103AWS
SD103BWS
SD103CWS
UNITS
VRRM
VRMS
VDC
40
30
VOLTS
VR(RMS)
28
21
14
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC Blocking voltage
RMS Reverse voltage
Forward continuous current
IFM
Repetitive peak forward current at 1.0s
Power dissipation
Thermal resistance junction to ambient
0.0019 (0.05)
0.0079 (0.20)
9°
0.016 (0.45)
0.008 (0.2 )
Case: JEDEC SOD-323 molded plastic body Terminals:
Plated leads solderable per MIL-STD-750, Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.0007 ounce, 0.02 grams
Marking: SD103AWS:S4, SD103BWS:S5, SD103CWS:S6
0° to
0.043 (1.10)
Mechanical Data
0.032 (0.80)
0.098 (2.50)
V
350
mA
IFRM
1.5
A
Pd
200
mW
RΘJA
300
Junction temperature
Tj
-55 to +125
Storage temperature
TSTG
-55 to +150
/W
Characteristics at Ta= 25 °C
PARAMETER
Reverse break down
voltage Reverse
SYMBOLS
SD103AWS
SD103BWS
SD103CWS
Fowrard voltage
Reverse current
Capacitance between terminals
Reverse recovery time
http://www.microdiode.com
SD103AWS
SD103BWS
SD103CWS
V(BR)R
Min.
Typ.
Max.
40
30
VF
0.37
0.60
IRM
5.0
Unit
Conditions
V
IR=100uA
V
uA
CT
50
pF
trr
10
ns
IF=20mA
IF=200mA
VR=30V
VR=20V
VR=10V
VR=0V,f=1.0MHz
IF=IR=200mA
Irr=0.1XIR,RL=100
Rev:2025A4
Page :1
Typical Characterisitics
Forward
350
Characteristics
Reverse
1000
Characteristics
REVERSE CURRENT IR
FORWARD CURRENT
IF
(mA)
(uA)
100
Ta=100℃
10
Ta=25℃
1
0.1
200
300
FORWARD VOLTAGE
400
VF
500
Ta=100℃
10
1
0.1
600
Ta=25℃
30
REVERSE VOLTAGE
(mV)
Capacitance Characteristics
50
100
VR
40
(V)
Power Derating Curve
250
Ta=25℃
(mW)
200
PD
40
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
30
100
50
10
10
15
REVERSE VOLTAGE
VR
25
(V)
30
50
75
AMBIENT TEMPERATURE
100
Ta
The curve above is for reference only.
Rev:2025A4
Page :2
125
Packing information
P0
unit:mm
P1
d
Item
E
F
B
A
W
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
P
D2
T
D1
C
W1
D
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-323
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.028
B
0.7
0.7
C
2.15
0.085
D
1.8
0.071
E
2.85
0.112
0.028
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“SD103AWS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1000+0.03978
- 3000+0.02859
- 国内价格
- 100+0.07249
- 1000+0.05783
- 3000+0.04641
- 9000+0.04149
- 51000+0.03720
- 99000+0.03489
- 国内价格
- 50+0.06645
- 600+0.05300
- 1200+0.05220
- 3000+0.04254
- 国内价格
- 100+0.07220
- 1000+0.05740
- 3000+0.04600
- 9000+0.04110
- 51000+0.03690
- 99000+0.03460
- 国内价格
- 1+0.18860
- 200+0.06279
- 1500+0.03922
- 3000+0.03117
