MB05S THRU MB10S
Voltage Range - 50 to 1000 V olts
Current - 0.8 Ampere
SINGLE PHASE GLASS PASSIVATED BRIDGE RECTIFIERS
Features
MBS
Ideal for printed circuit board
High temperature soldering guaranteed: 260°/10 seconds at 5
.043(1.10)
.028(0.70)
.053(1.53)
.037(0.95)
lbs., (2.3kg) tension
Small size, simple installation
High surge current capability
.193(4.90)
.177(4.50)
.033(0.84)
.022(0.56)
Reliable low cost construction utilizing molded plastic technique
.157(4.00)
.276(7.0)
MAX
.142(3.60)
.083(2.12)
.043(1.10)
Mechanical Data
Case : JEDEC MBS Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.008 ounce, 0.22 grams
.014(0.35)
.006(0.15)
.102(2.60)
.087(2.20)
(1)
(2)
.106(2.70)
.118(3.0)
.090(2.30)
MAX
.008(0.20)
MAX
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
Maximum average forward rectified current
at TC=30
On glass-epoxy P.C.B.
On aluminum substrate
IF(AV)
Peak forward surge current,
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward
at=0.4A
voltage drop per leg
TA=25
Maximum DC reverse current
at rated DC blocking voltage
TA=125
MB05S MB1S MB2S MB4S MB6S MB8S MB10S UNITS
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
0.5
1000
700
1000
V
V
V
A
0.8
IFSM
30
A
VF
1.0
V
IR
5
0.5
uA
mA
CJ
13
PF
Typical thermal resistance
RθJC
70
°C/W
Operating temperature range
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
Typical junction capacitance
storage temperature range
(Note 3)
NOTES:1.On glass epoxy P.C.B. mounted on 0.05x0.05''(1.3x1.3mm) pads
2.On aluminum substrate P.C.B. with on area of 0.8''x0.8''(20x20mm) mounted on 0.05X0.05''(1.3X1.3mm) solder pad
3.Measured at 1.0MHz and applied reverse voltage of 4.0 volts.
http://www.microdiode.com
Rev:2024A2
Page :1
MB05S THRU MB10S
Ratings And Characteristic Curves
0.8
Aluminum Substrate
0.7
0.6
0.5
0.4
Glass Epoxy
P.C.B.
0.3
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
PEAK FORWARD SURGE CURRENT.(A)
AVERAGE FORWARD RECTIFIED
CURRENT(A)
FIG. 1- DERATING CURVE OUTPUT RECTIFIED
CURRENT FOR
0.2
0.1
35
30
Ta=40
Single Half Sine-Wave
(JEDEC Method)
25
f=60Hz
f=50Hz
10
5
1Cycle
60
80
100
120
140
160
NUMBER OF CYCLES
INSTANTANEOUS REVERSE LEAKAGE
CURRENT.(uA)
INSTANTANEOUS FORWARD
CURRENT(A)
FIG. 3-TYPICAL FORWARD VOLTAGE
CHARACTERISTICS PER LEG
10
1
0.1
0.01
0.2 0.4
TJ=25
Pulse Width=300us
1% Duty Cycle
0.6
0.8
1.0
1.2
1.4
100
10
AMBIENT TEMPERATURE,( )
FIG. 4-TYPICAL REVERSE LEAKAGE
100
TJ=125
10
1
0.1
TJ=25
1.6
0.01
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE(%)
INSTANTANEOUS FORWARD VOLTAGE.(V)
JUNCTION CAPACITANCE.(pF)
FIG. 5-TYPICAL JUNCTION CAPACTITANE
PER LEG
30
25
TJ=25
f=1.0MHZ
Vsig=50mV p-p
10
5
1
10
100
200
REVERSE VOLTAGE.(V)
The curve above is for reference only.
Rev:2024A2
Page :2
MB05S THRU MB10S
Suggested Pad Layout
P2
P1
Dim
Min
P1
6.00
P2
2.40
Q1
1.84
Q2
1.20
Q1
Q2
Dimensions in millimeters
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“MB10S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13118
- 600+0.10722
- 2400+0.08969
- 6000+0.08168
