74HC2G66GT,115
74HC2G66GT,115
    NEXPERIA(安世)
    XSON8_2X1MM
    双单刀单投模拟开关
74HC2G66GT,115 数据手册
74HC2G66; 74HCT2G66 Dual single-pole single-throw analog switch Rev. 11 — 6 November 2018 Product data sheet 1. General description The 74HC2G66; 74HCT2G66 is a dual single pole, single-throw analog switch. Each switch has two input/output terminals (nY and nZ) and a digital enable input (nE). When nE is LOW, the analog switch is turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • Wide supply voltage range from 2.0 V to 10.0 V for 74HC2G66 Very low ON resistance: • 41 Ω (typ.) at VCC = 4.5 V • 30 Ω (typ.) at VCC = 6.0 V • 21 Ω (typ.) at VCC = 9.0 V High noise immunity Low power dissipation 25 mA continuous switch current Multiple package options ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74HC2G66DP Temperature range Name Description Version -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm SOT505-2 -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 × 1.95 × 0.5 mm SOT833-1 74HCT2G66DP 74HC2G66DC 74HCT2G66DC 74HC2G66GT 74HCT2G66GT 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 4. Marking Table 2. Marking codes Type number Marking [1] 74HC2G66DP H66 74HCT2G66DP T66 74HC2G66DC H66 74HCT2G66DC T66 74HC2G66GT H66 74HCT2G66GT T66 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 1Y 1Z 1E 2Z 2Y Y 2E E 001aag497 Fig. 1. Z Logic symbol Fig. 2. 001aah372 Logic diagram for 1 switch 6. Pinning information 6.1. Pinning 74HC2G66 74HCT2G66 1Y 1 8 VCC 1Z 2 7 1E 2E 3 6 2Z GND 4 5 2Y 74HC2G66 74HCT2G66 1Y 1 8 VCC 1Z 2 7 1E 2E 3 6 2Z GND 4 5 2Y 001aam498 001aai699 Fig. 3. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 74HC_HCT2G66 Product data sheet Transparent top view Fig. 4. Pin configuration SOT833-1 (XSON8) All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 2 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 6.2. Pin description Table 3. Pin description Symbol Pin Description 1Y, 2Y 1, 5 independent input or output 1Z, 2Z 2, 6 independent input or output GND 4 ground (0 V) 1E, 2E 7, 3 enable input (active HIGH) VCC 8 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input nE Switch L OFF H ON 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit V VCC supply voltage -0.5 +11.0 IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA ISK switch clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA ISW switch current VSW > -0.5 V or VSW < VCC + 0.5 V - ±20 mA ICC supply current - 30 mA IGND ground current -30 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation [1] [2] Tamb = -40 °C to +125 °C per package [2] - 300 mW per switch [2] - 100 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP8 packages: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K. For XSON8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 3 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC2G66 74HCT2G66 Unit Min Typ Max Min Typ Max 2.0 5.0 10.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V VSW switch voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V VCC = 10.0 V - - 35 - - - ns/V [1] [1] To avoid drawing VCC current out of pin nZ, when switch current flows in pin nY, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into pin nZ, no VCC current will flow out of terminal nY. In this case there is no limit for the voltage drop across the switch, but the voltage at pins nY and nZ may not exceed VCC or GND. 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V VCC = 9.0 V 6.3 4.7 - 6.3 - V VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V VCC = 9.0 V - 4.3 2.7 - 2.7 V VCC = 6.0 V - - ±0.1 - ±0.1 μA VCC = 9.0 V - - ±0.2 - ±0.2 μA 74HC2G66 VIH VIL II HIGH-level input voltage LOW-level input voltage input leakage current nE; VI = VCC or GND IS(OFF) OFF-state leakage current nY or nZ; VCC = 9.0 V; see Fig. 5 - 0.1 1.0 - 1.0 μA IS(ON) ON-state leakage current nY or nZ; VCC = 9.0 V; see Fig. 6 - 0.1 1.0 - 1.0 μA ICC supply current nE, nY and nZ = VCC or GND VCC = 6.0 V - - 10 - 20 μA VCC = 9.0 V - - 20 - 40 μA 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 4 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max CI input capacitance - 3.5 - - - pF CPD power dissipation capacitance - 9 - - - pF CS(ON) ON-state capacitance - 8 - - - pF - 2.0 - V 74HCT2G66 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V II input leakage current nE; VI = VCC or GND; VCC = 5.5 V - - ±1.0 - ±1.0 μA IS(OFF) OFF-state leakage current nY or nZ; VCC = 5.5 V; see Fig. 5 - 0.1 1.0 - 1.0 μA IS(ON) ON-state leakage current nY or nZ; VCC = 5.5 V; see Fig. 6 - 0.1 1.0 - 1.0 μA ICC supply current nE, nY and nZ = VCC or GND; VCC = 4.5 V to 5.5 V - - 10 - 20 μA ΔICC additional supply current nE = VCC - 2.1 V; IO = 0 A; VCC = 4.5 V to 5.5 V; - - 375 - 410 μA CI input capacitance - 3.5 - - - pF CPD power dissipation capacitance - 9 - - - pF CS(ON) ON-state capacitance - 8 - - - pF [1] Typical values are measured at Tamb = 25 °C. 10.1. Test circuits VCC VCC nE VIL IS VI nE VIH nY nZ GND IS IS VO VI nY nZ GND VO 001aaj465 001aaj466 VI = VCC or GND and VO = GND or VCC. Fig. 5. Test circuit for measuring OFF-state leakage current 74HC_HCT2G66 Product data sheet VI = VCC or GND and VO = open circuit. Fig. 6. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 5 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 10.2. ON resistance Table 8. ON resistance for 74HC2G66 and 74HCT2G66 At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graph see Fig. 8. Symbol Parameter Conditions -40 °C to +85 °C Min Typ [1] ISW = 0.1 mA; VCC = 2.0 V - ISW = 1.0 mA; VCC = 4.5 V - ISW = 1.0 mA; VCC = 6.0 V ISW = 1.0 mA; VCC = 9.0 V -40 °C to +125 °C Unit Max Min Max 250 - - - Ω 41 118 - 142 Ω - 30 105 - 126 Ω - 21 88 - 105 Ω ISW = 0.1 mA; VCC = 2.0 V - 65 - - - Ω ISW = 1.0 mA; VCC = 4.5 V - 28 95 - 115 Ω ISW = 1.0 mA; VCC = 6.0 V - 22 82 - 100 Ω ISW = 1.0 mA; VCC = 9.0 V - 18 70 - 80 Ω ISW = 0.1 mA; VCC = 2.0 V - 65 - - - Ω ISW = 1.0 mA; VCC = 4.5 V - 31 106 - 128 Ω ISW = 1.0 mA; VCC = 6.0 V - 23 94 - 113 Ω ISW = 1.0 mA; VCC = 9.0 V - 19 78 - 95 Ω VCC = 4.5 V - 5 - - - Ω VCC = 6.0 V - 4 - - - Ω VCC = 9.0 V - 3 - - - Ω - 41 118 - 142 Ω - 28 95 - 115 Ω - 31 106 - 128 Ω - 5 - - - Ω 74HC2G66 [2] RON(peak) ON resistance (peak) RON(rail) VI = GND to VCC; see Fig. 7 and Fig. 8 ON resistance (rail) VI = GND; see Fig. 7 and Fig. 8 VI = VCC; see Fig. 7 and Fig. 8 ΔRON ON resistance mismatch between channels VI = VCC to GND; see Fig. 7 and Fig. 8 74HCT2G66 RON(peak) ON resistance (peak) RON(rail) VI = GND to VCC; see Fig. 7 and Fig. 8 ISW = 1.0 mA; VCC = 4.5 V ON resistance (rail) VI = GND; see Fig. 7 and Fig. 8 ISW = 1.0 mA; VCC = 4.5 V VI = VCC; see Fig. 7 and Fig. 8 ISW = 1.0 mA; VCC = 4.5 V ΔRON [1] [2] ON resistance mismatch between channels VI = VCC to GND; see Fig. 7 and Fig. 8 VCC = 4.5 V Typical values are measured at Tamb = 25 °C. At supply voltages approaching 2 V, the ON resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using this supply voltage. 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 6 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 10.3. ON resistance test circuit and graphs mnb006 60 RON (Ω) VSW VCC = 4.5 V 40 VCC VCC = 6.0 V nE VIH 20 nY VI GND ISW 0 001aaj467 RON = VSW / ISW. Fig. 7. Test circuit for measuring ON resistance 74HC_HCT2G66 Product data sheet VCC = 9.0 V nZ 0 2 4 6 8 VI (V) 10 Tamb = 25 °C. Fig. 8. Typical ON resistance as a function of input voltage All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 7 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); For test circuit see Fig. 11. Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 2.0 V - 6.5 65 - 80 ns VCC = 4.5 V - 2 13 - 15 ns VCC = 6.0 V - 1.5 11 - 14 ns - 1.2 10 - 12 ns VCC = 2.0 V - 40 125 - 150 ns VCC = 4.5 V - 12 29 - 30 ns VCC = 6.0 V - 10 21 - 26 ns - 7 16 - 20 ns VCC = 2.0 V - 21 145 - 175 ns VCC = 4.5 V - 12 29 - 35 ns VCC = 6.0 V - 11 28 - 33 ns 74HC2G66 tpd propagation delay nY to nZ or nZ to nY; RL = ∞ Ω; see Fig. 9 [2] VCC = 9.0 V ten enable time nE to nY or nZ; see Fig. 10 [2] VCC = 9.0 V tdis disable time nE to nY or nZ; see Fig. 10 [2] VCC = 9.0 V CPD power dissipation capacitance - 10 23 - 27 ns VI = GND to VCC [3] - 9 - - - pF 74HCT2G66 tpd propagation delay nY to nZ or nZ to nY; RL = ∞ Ω; VCC = 4.5 V; see Fig. 9 [2] - 2 15 - 18 ns ten enable time nE to nY or nZ; VCC = 4.5; see Fig. 10 [2] - 13 30 - 36 ns tdis disable time nE to nY or nZ; VCC = 4.5 V; see Fig. 10 [2] - 13 44 - 53 ns CPD power dissipation capacitance VI = GND to VCC - 1.5 V [3] - 9 - - - pF [1] [2] [3] All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation PD (μW). 2 2 PD = CPD × VCC × fi + Σ((CL × CSW) × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CSW = maximum switch capacitance in pF (see Table 7); VCC = supply voltage in volts; 2 Σ((CL × CSW) × VCC × fo) = sum of outputs. 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 8 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 11.1. Waveforms and test circuit VI nY or nZ input VM VM GND t PLH t PHL VOH nZ or nY output VM VM VOL 001aaa541 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 9. Input (nY or nZ) to output (nZ or nY) propagation delays VI nE input VM GND t PLZ nY or nZ output LOW-to-OFF OFF-to-LOW t PZL VCC VM VX VOL t PZH t PHZ nY or nZ output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND switch enabled switch disabled switch enabled 001aaa542 Measurement points are given in Table 10. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 10. Enable and disable times Table 10. Measurement points Type Input Output VM VM VX VY 74HC2G66 0.5VCC 0.5VCC VOL + 10 % VOH - 10 % 74HCT2G66 1.3 V 1.3 V VOL + 10 % VOH - 10 % 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 9 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 11. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 11. Test circuit for measuring switching times Table 11. Test data Type Input Load S1 position VI tr, tf [1] CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC2G66 GND to VCC 6 ns 50 pF 1 kΩ open GND VCC 74HCT2G66 GND to 3 V 6 ns 50 pF 1 kΩ open GND VCC [1] There is no constraint on tr, tf with a 50 % duty factor when measuring fmax. 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 10 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 11.2. Additional dynamic characteristics Table 12. Additional dynamic characteristics for 74HC2G66 and 74HCT2G66 GND = 0 V; tr = tf = 6.0 ns; CL = 50 pF; unless otherwise specified. All typical values are measured at Tamb = 25 °C. Symbol Parameter Conditions THD fi = 1 kHz; RL = 10 kΩ; see Fig. 12 total harmonic distortion Min Typ Max Unit VCC = 4.5 V; VI = 4.0 V (p-p) - 0.04 - % VCC = 9.0 V; VI = 8.0 V (p-p) - 0.02 - % VCC = 4.5 V; VI = 4.0 V (p-p) - 0.12 - % VCC = 9.0 V; VI = 8.0 V (p-p) - 0.06 - % VCC = 4.5 V - 180 - MHz VCC = 9.0 V - 200 - MHz VCC = 4.5 V - -50 - dB VCC = 9.0 V - -50 - dB VCC = 4.5 V - 110 - mV VCC = 9.0 V - 220 - mV VCC = 4.5 V - -60 - dB VCC = 9.0 V - -60 - dB fi = 10 kHz; RL = 10 kΩ; see Fig. 12 f(-3dB) αiso -3 dB frequency response RL = 50 Ω; CL = 10 pF; see Fig. 13 and Fig. 14 RL = 600 Ω; fi = 1 MHz; see Fig. 15 and Fig. 16 isolation (OFF-state) Vct between digital input and switch (peak to peak value); RL = 600 Ω; fi = 1 MHz; see Fig. 17 crosstalk voltage Xtalk between switches; RL = 600 Ω; fi = 1 MHz; see Fig. 18 crosstalk 11.3. Test circuits and graphs VCC nE VIH VCC nE VIH nY/nZ nY/nZ fi 2RL 10 µF 2RL 0.1 µF VCC nZ/nY VCC nZ/nY VO 2RL CL dB VO 001aaj469 fi 2RL CL D 001aaj468 Fig. 12. Test circuit for measuring total harmonic distortion 74HC_HCT2G66 Product data sheet With fi = 1 MHz adjust the switch input voltage for a 0 dBm level at the switch output, (0 dBm = 1 mW into 50 Ω). Then Increase the input frequency until the dB meter reads -3 dB. Fig. 13. Test circuit for measuring the -3 dB frequency response All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 11 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch mna083 5 (dB) 0 -5 10 102 103 104 105 fi (kHz) 106 Test conditions: VCC = 4.5 V; GND = 0 V; RL = 50 Ω; RSOURCE = 1 kΩ. Fig. 14. Typical -3 dB frequency response VCC VCC nE VIL 2RL 0.1 µF nY/nZ nZ/nY fi VO CL 2RL dB 001aaj470 Adjust the switch input voltage for a 0 dBm level (0 dBm = 1 mW into 600 Ω) Fig. 15. Test circuit for measuring isolation (OFF-state) mna082 0 (dB) - 20 - 40 - 60 - 80 - 100 10 102 103 104 105 fi (kHz) 106 Test conditions: VCC = 4.5 V; GND = 0 V; RL = 50 Ω; RSOURCE = 1 kΩ. Fig. 16. Typical isolation (OFF-state) as a function of frequency 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 12 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch VCC nE VCC GND 2RL nY/nZ VCC 2RL nZ/nY DUT 2RL 2RL oscilloscope CL GND mnb011 a. Circuit V(p- p) mnb012 b. Crosstalk voltage Adjust the switch input voltage for a 0 dBm level (0 dBm = 1 mW into 600 Ω) Fig. 17. Test circuit for measuring crosstalk voltage (between the digital input and the switch) VCC 1E VIH 0.1 µF RL 2RL 1Y or 1Z 1Z or 1Y CHANNEL ON fi 2RL CL V VO1 V VO2 2E VIL VCC VCC 2RL 2RL 2Y or 2Z 2RL 2Z or 2Y CHANNEL OFF 2RL CL 001aai846 Adjust the switch input voltage for a 0 dBm level (0 dBm = 1 mW into 600 Ω) Fig. 18. Test circuit for measuring crosstalk (between the switches) 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 13 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 12. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 19. Package outline SOT505-2 (TSSOP8) 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 14 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit A max. max nom min mm 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 20. Package outline SOT765-1 (VSSOP8) 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 15 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig. 21. Package outline SOT833-1 (XSON8) 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 16 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 13. Abbreviations Table 13. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 14. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT2G66 v.11 20181106 Product data sheet - Modifications: • • • • • 74HC_HCT2G66 v.10 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC2G66GD and 74HCT2G66GD (SOT996-2) removed. Corrected Fig. 2 Package outline drawing SOT765-1 updated 74HC_HCT2G66 v.10 20131003 Modifications: • 74HC_HCT2G66 v.9 20111213 Product data sheet - 74HC_HCT2G66 v.8 74HC_HCT2G66 v.8 20100923 Product data sheet - 74HC_HCT2G66 v.7 74HC_HCT2G66 v.7 20100914 Product data sheet - 74HC_HCT2G66 v.6 74HC_HCT2G66 v.6 20100402 Product data sheet - 74HC_HCT2G66 v.5 74HC_HCT2G66 v.5 20090126 Product data sheet - 74HC_HCT2G66 v.4 74HC_HCT2G66 v.4 20040519 Product specification - 74HC_HCT2G66 v.3 74HC_HCT2G66 v.3 20031126 Product specification - 74HC_HCT2G66 v.2 74HC_HCT2G66 v.2 20030808 Product specification - 74HC_HCT2G66 v.1 74HC_HCT2G66 v.1 20030625 Product specification - - 74HC_HCT2G66 Product data sheet Product data sheet - 74HC_HCT2G66 v.9 For type numbers 74HC2G66GD and 74HCT2G66GD XSON8U has changed to XSON8. All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 17 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT2G66 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 18 / 19 74HC2G66; 74HCT2G66 Nexperia Dual single-pole single-throw analog switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 10.1. Test circuits................................................................5 10.2. ON resistance............................................................6 10.3. ON resistance test circuit and graphs........................7 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit........................................ 9 11.2. Additional dynamic characteristics........................... 11 11.3. Test circuits and graphs........................................... 11 12. Package outline........................................................ 14 13. Abbreviations............................................................ 17 14. Revision history........................................................17 15. Legal information......................................................18 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 6 November 2018 74HC_HCT2G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 6 November 2018 © Nexperia B.V. 2018. All rights reserved 19 / 19 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC2G66DC,125 74HCT2G66DC,125 74HC2G66DP,125 74HCT2G66DP,125 74HC2G66GD,125 74HCT2G66GD,125 74HCT2G66GT,115 74HCT2G66DP/S911,1 74HC2G66GT,115
74HC2G66GT,115
物料型号:74HC2G66; 74HCT2G66
器件简介: - 74HC2G66; 74HCT2G66是一款双单刀单掷模拟开关,每个开关具有两个输入/输出端(nY和nZ)和一个数字使能输入(nE)。当nE为低电平时,模拟开关关闭。输入端包含钳位二极管,允许使用限流电阻将输入接口至超过VCC的电压。
引脚分配: - 1Y, 2Y:独立输入或输出 - 1Z, 2Z:独立输入或输出 - GND:地(0V) - 1E, 2E:使能输入(高电平有效) - VCC:供电电压
参数特性: - 宽电源电压范围:74HC2G66为2.0V至10.0V - 非常低的导通电阻:典型值在4.5V时为41Ω,在6.0V时为30Ω,在9.0V时为21Ω - 高噪声容限 - 低功耗散 - 25mA连续开关电流 - 多种封装选项 - ESD保护:HBM JESD22-A114F超过2000V,MM JESD22-A115-A超过200V - 规格从-40°C至+85°C和-40°C至+125°C
功能详解: - 功能表显示了输入nE与开关状态的关系。当nE为高电平时,开关打开;为低电平时,开关关闭。
应用信息: - 该器件适用于需要模拟开关的应用,例如音频切换、多路复用器等。
封装信息: - 提供多种封装选项,包括TSSOP8、VSSOP8和XSON8。
74HC2G66GT,115 价格&库存
很抱歉,暂时无法提供与“74HC2G66GT,115”相匹配的价格&库存,您可以联系我们找货
74HC2G66GT,115
74HC2G66GT,115
  • 1+2.105541+0.25290
  • 10+1.4438010+0.17342
  • 25+1.2799225+0.15373
  • 100+1.09675100+0.13173
  • 250+1.00875250+0.12116
  • 500+0.95590500+0.11481
  • 1000+0.912341000+0.10958
  • 2500+0.866342500+0.10406
库存:6586
74HC2G66GT,115
  • 5000+0.838585000+0.10072
  • 10000+0.8157610000+0.09798
  • 15000+0.8043315000+0.09661
  • 25000+0.7916625000+0.09509
  • 35000+0.7842735000+0.09420
  • 50000+0.7771450000+0.09334
库存:6586
