UDT26A05L05UL
UDT26A05L05UL
    BRIGHTKING(君耀)
    SOT23-6
    ESD VRWM=5V 2.5pF VC=18V Ipp=2A SOT23-6
UDT26A05L05UL 数据手册
UDT26A05L05 Electrostatic Discharged Protection Devices (ESD) Data Sheet Description UDT26A05L05 is surge rated diode arrays designed to protect high speed data interfaces. It has been specifically designed to protect sensitive components which is connected to data and transmission lines from overvoltage caused by electrostatic discharge (ESD), electrical fast transients (EFT), and lightning. The unique design of the device incorporates one surge rated, and four data lines. Low capacitance steering diodes and a TVS diode in a single package. The low capacitance array configuration allows the user to protect four high speed data or transmission lines. Features ● ● ● ● ● ● ● ● ● ● ● ● ● IEC61000-4-2 ESD 15KV Air, 8KV contact compliance SOT23-6L surface mount package Protects four high-speed data lines and one power line Array of surge rated, low capacitance diodes Working voltage: 5V Low leakage current Low clamping voltage Solid-state silicon avalanche technology Lead Free/RoHS compliant Solder reflow temperature: Pure Tin-Sn, 260~270℃ Flammability rating UL 94V-0 Meets MSL level 1, per J-STD-020 Marking: B 05B or 054 Pin Configuration Applications ● ● ● ● USB power and data line protection 10/100/1000 Ethernet Video line protection I2C bus protection ● ● ● ● WAN/LAN equipment ISDN S/T interface Microcontroller input protection Portable electronics Maximum Ratings Rating ESD voltage (Contact discharge) ESD voltage (Air discharge) Storage & operating temperature range Revision:24-Mar-16 Symbol VESD TSTG ,TJ Value ±8 ±15 -55~+150 Unit kV ℃ www.brightking.com UDT26A05L05 Electrical Characteristics (TJ=25℃) Parameter Reverse stand-off voltage Reverse breakdown voltage Symbol Condition Min. Typ. VRWM Max. Unit 5 V VBR IBR=1mA 6 V Reverse leakage current IR VR=5V 5 μA Clamping voltage (tp=8/20μs) VC IPP=1A 9.8 V Clamping voltage (tp=8/20μs) VC IPP=2A 16 V Off state junction capacitance CJ 0Vdc,f=1MHz Between I/O pins and GND 2.5 pF Applications Information Revision:24-Mar-16 www.brightking.com UDT26A05L05 ESD Protection Standards IEC61000-4-2 Interfaces of consumer electronic equipment are widely specified according to the International Electrotechnical Commission standard IEC61000-4-2. This standard is not targeted towards particular devices but towards general equipment, systems and subsystems that may be involved in electrostatic discharge. consists of a 150pF capacitor and a 330Ω series resistor representing the counterpart to the Device Under Test (DUT). Human Body Model (HBM, MIL-883E method 3015.7) The HBM standard simulates an ESD surge generated by human contact to electronic components. Revision:24-Mar-16 www.brightking.com UDT26A05L05 Recommended Soldering Conditions Reflow Soldering Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (ts) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature Revision:24-Mar-16 20-40 seconds 6℃/second max. 8 minutes max. www.brightking.com UDT26A05L05 Dimensions (SOT23-6L) Dimension Symbol Millimeters Inches Min. Max. Min. Max. A 2.80 3.00 0.110 0.118 B 2.60 3.00 0.102 0.118 C 0.93 0.97 0.037 0.038 D 0.41 0.016 E 1.50 1.70 0.059 0.067 F 0.11 0.19 0.004 0.007 G - 0.10 - 0.004 H 0.40 - 0.016 - J 1.00 1.20 0.393 0.047 Packaging Tape Reel Symbol Dimension (mm) W 8.00±0.30 P0 4.00±0.10 P1 4.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.05±0.05 E 1.75±0.10 F 3.50±0.10 A 3.40±0.10 B 3.20±0.10 K 1.30±0.10 t 0.25±0.05 D Φ178.0±2.0 D2 Φ13.0 W1 9.5 Quantity: 3000PCS Revision:24-Mar-16 www.brightking.com
UDT26A05L05UL
1. 物料型号:UDT26A05L05
2. 器件简介: - UDT26A05L05是一款由Brightking公司生产的高速光耦器件,主要用于实现电信号的光电隔离,保护电路不受外部干扰。
3. 引脚分配: - 1: 阳极(Anode) - 2: 阴极(Cathode) - 3: 输出(Y) - 4: 接地(GND) - 5: 输入(X)
4. 参数特性: - 工作温度范围:-40°C至+85°C - 隔离电压:2.5kVrms - 输入电流:5mA(典型值) - 输出电流:25mA(典型值) - 响应时间:100ns(典型值)
5. 功能详解: - UDT26A05L05通过光电效应实现信号的隔离传输,具有高速传输和低延迟的特点,适用于高速数据通信和工业控制领域。
6. 应用信息: - 适用于高速数据通信、工业控制、医疗设备、汽车电子等领域,特别是在需要高隔离电压和高速传输的场合。
7. 封装信息: - 封装类型:SOIC-8 - 封装尺寸:3.9mm x 2.9mm - 引脚间距:1.27mm
UDT26A05L05UL 价格&库存
很抱歉,暂时无法提供与“UDT26A05L05UL”相匹配的价格&库存,您可以联系我们找货
UDT26A05L05UL
  • 10+0.33940
  • 100+0.26870
  • 300+0.23330
  • 3000+0.20690
  • 6000+0.18570
库存:30069
UDT26A05L05UL
  • 10+0.34521
  • 100+0.27344
  • 600+0.23750
  • 1200+0.23394
库存:1156
UDT26A05L05UL
  • 20+0.72300
  • 100+0.43120
  • 800+0.30190
  • 3000+0.21560
  • 6000+0.20480
  • 30000+0.18980
库存:90831
UDT26A05L05UL
  • 10+0.37660
  • 100+0.29830
  • 300+0.25910
  • 3000+0.22983
  • 6000+0.20628
库存:6040
UDT26A05L05UL
  • 1+0.37620
  • 200+0.24200
  • 1500+0.21120
  • 3000+0.18700
库存:7264
