74AHC00; 74AHCT00
Quad 2-input NAND gate
Rev. 04 — 28 April 2008
Product data sheet
1. General description
The 74AHC00; 74AHCT00 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC
standard No. JESD7-A.
The 74AHC00; 74AHCT00 provides the quad 2-input NAND function.
2. Features
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Input levels:
u For 74AHC00: CMOS level
u For 74AHCT00: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AHC00D
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74AHC00PW
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74AHC00BQ
−40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74AHC00
SOT762-1
74AHC00; 74AHCT00
Nexperia
Table 1.
Ordering information …continued
Type number
Package
Temperature range
Name
Description
Version
74AHCT00D
−40 °C to +125 °C
SO14
body width 3.9 mm
SOT108-1
74AHCT00PW
−40 °C to +125 °C
TSSOP14
body width 4.4 mm
SOT402-1
74AHCT00BQ
−40 °C to +125 °C
74AHCT00
SOT762-1
4. Functional diagram
1
1 1A
2 1B
1Y 3
4 2A
5 2B
2Y 6
9 3A
10 3B
3Y 8
12 4A
13 4B
4Y 11
2
4
5
9
10
12
13
3
6
8
A
Y
11
B
mna212
Fig 1.
mna211
mna246
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one gate)
5. Pinning information
1
1A
terminal 1
index area
14 VCC
5.1 Pinning
1B
2
1Y
3
12 4A
2A
4
00
11 4Y
11 4Y
2B
5
GND (1)
10 3B
10 3B
2Y
6
2
13 4B
12 4A
1Y
3
2A
4
2B
5
2Y
6
9
3A
8
1B
13 4B
GND
7
8
3Y
3Y
14 VCC
7
1
GND
1A
00
9
3A
001aac939
Transparent top view
001aac938
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 4.
Pin configuration SO14 and TSSOP14
Fig 5.
Pin configuration DHVQFN14
74AHC_AHCT00_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 14
74AHC00; 74AHCT00
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input
1B
2
data input
1Y
3
data output
2A
4
data input
2B
5
data input
2Y
6
data output
GND
7
ground (0 V)
3Y
8
data output
3A
9
data input
3B
10
data input
4Y
11
data output
4A
12
data input
4B
13
data input
VCC
14
supply voltage
6. Functional description
Table 3.
Function selection[1]
Input
Output
nA
nB
nY
L
X
H
X
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
74AHC_AHCT00_4
Product data sheet
3 of 14
74AHC00; 74AHCT00
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP14 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN14 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Operating conditions
Parameter
Conditions
Min
Typ
Max
Unit
V
74AHC00
VCC
supply voltage
2.0
5.0
5.5
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT00
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
74AHC_AHCT00_4
Product data sheet
4 of 14
74AHC00; 74AHCT00
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
Min
−40 °C to +85 °C −40 °C to +125 °C Unit
Typ Max
Min
Max
Min
Max
74AHC00
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level
output voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
VI = VIH or VIL
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level output VI = VIH or VIL
voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1.0
2.0
µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
µA
CI
input capacitance VI = VCC or GND
3.0
10
10
10
pF
74AHCT00
VIH
HIGH-level input
voltage
2.0
2.0
2.0
V
VIL
LOW-level input
voltage
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = −50 µA
4.4
4.5
4.4
4.4
V
IO = −8.0 mA
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
VOL
LOW-level output VI = VIH or VIL; VCC = 4.5 V
voltage
IO = 50 µA
IO = 8.0 mA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
74AHC_AHCT00_4
Product data sheet
5 of 14
74AHC00; 74AHCT00
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ Max
Min
Max
Min
Max
ICC
supply current
VCC = 5.5 V
2.0
µA
∆ICC
additional supply
current
per input pin;
VI = VCC − 2.1 V;
other pins at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
1.35
1.5
1.5
mA
CI
3.0
10
10
10
pF
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 7.
Symbol
Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
4.5
7.9
1.0
9.5
1.0
10.0
ns
CL = 50 pF
6.0
11.4
1.0
13.0
1.0
14.5
ns
3.2
5.5
1.0
6.5
1.0
7.0
ns
4.5
7.5
1.0
8.5
1.0
9.5
ns
7.0
pF
3.3
6.9
1.0
8.0
1.0
9.0
ns
4.5
7.9
1.0
9.0
1.0
10.0
ns
7.0
pF
74AHC00
propagation
delay
tpd
nA, nB to nY; see Figure 6
[2]
CL = 15 pF
CL = 50 pF
power
dissipation
capacitance
CPD
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[3]
[2]
74AHCT00
propagation
delay
tpd
CL = 15 pF
CL = 50 pF
power
dissipation
capacitance
CPD
VI = GND to VCC
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT00_4
Product data sheet
6 of 14
74AHC00; 74AHCT00
Nexperia
11. Waveforms
VI
VM
nA, nB input
GND
tPLH
tPHL
VOH
VM
nY output
VOL
001aah088
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Input to output propagation delays
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC00
0.5 × VCC
0.5 × VCC
74AHCT00
1.5 V
0.5 × VCC
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 7.
Load circuitry for measuring switching times
74AHC_AHCT00_4
Product data sheet
7 of 14
74AHC00; 74AHCT00
Nexperia
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC00
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT00
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT00_4
Product data sheet
8 of 14
74AHC00; 74AHCT00
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74AHC_AHCT00_4
Product data sheet
9 of 14
74AHC00; 74AHCT00
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Package outline SOT402-1 (TSSOP14)
74AHC_AHCT00_4
Product data sheet
10 of 14
74AHC00; 74AHCT00
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 10. Package outline SOT762-1 (DHVQFN14)
74AHC_AHCT00_4
Product data sheet
11 of 14
74AHC00; 74AHCT00
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charge Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
TTL
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT00_4
20080428
Product data sheet
74AHC_AHCT00_3
Modifications:
Table 6: the conditions for input leakage current have been changed.
74AHC_AHCT00_3
20080108
Product data sheet
74AHC_AHCT00_2
74AHC_AHCT00_2
19990923
Product specification
74AHC_AHCT00_1
74AHC_AHCT00_1
19981209
74AHC_AHCT00_4
Product data sheet
12 of 14
74AHC00; 74AHCT00
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT00_4
Product data sheet
13 of 14
Nexperia
74AHC00; 74AHCT00
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 28 April 2008
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC00BQ,115 74AHC00D,112 74AHC00D,118 74AHC00PW,112 74AHC00PW,118 74AHCT00BQ,115
74AHCT00D,112 74AHCT00D,118 74AHCT00PW,112 74AHCT00PW,118
