74AHCT1G00GV,125
74AHCT1G00GV,125
    NEXPERIA(安世)
    SOT753-5
    2输入与非门 SOT753
74AHCT1G00GV,125 数据手册
74AHC1G00; 74AHCT1G00 2-input NAND gate Rev. 7 — 5 November 2014 Product data sheet 1. General description 74AHC1G00 and 74AHCT1G00 are high-speed Si-gate CMOS devices. They provide a 2-input NAND function. The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V. The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V. 2. Features and benefits       Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays SOT353-1 and SOT753 package options ESD protection:  HBM JESD22-A114E: exceeds 2000 V  MM JESD22-A115-A: exceeds 200 V  CDM JESD22-C101C: exceeds 1000 V  Specified from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74AHC1G00GW Package Temperature range Name Description Version 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74AHCT1G00GW 74AHC1G00GV 74AHCT1G00GV 74AHC1G00; 74AHCT1G00 Nexperia 2-input NAND gate 4. Marking Table 2. Marking codes Type number Marking[1] 74AHC1G00GW AA 74AHC1G00GV A00 74AHCT1G00GW CA 74AHCT1G00GV C00 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  %  $ < %   <  Logic symbol $ PQD PQD Fig 1.  Fig 2. IEC logic symbol Fig 3. PQD Logic diagram 6. Pinning information 6.1 Pinning $+&* $+&7* %  $  *1'   9&&  < DDI Fig 4. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description B 1 data input A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 74AHC_AHCT1G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 5 November 2014 © Nexperia B.V. 2017. All rights reserved 2 of 12 74AHC1G00; 74AHCT1G00 Nexperia 2-input NAND gate 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Inputs Output A B Y L L H L H H H L H H H L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VCC supply voltage Conditions 0.5 +7.0 V VI input voltage 0.5 +7.0 V IIK input clamping current VI < 0.5 V 20 - mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V IO output current 0.5 V < VO < VCC + 0.5 V - 20 mA - 25 mA ICC supply current - 75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74AHC_AHCT1G00 Product data sheet Conditions 74AHC1G00 74AHCT1G00 Unit Min Typ Max Min Typ Max 2.0 5.0 5.5 4.5 5.0 5.5 V 0 - 5.5 0 - 5.5 V 0 - VCC 0 - VCC V 40 +25 +125 40 +25 +125 C VCC = 3.3 V  0.3 V - - 100 - - - ns/V VCC = 5.0 V  0.5 V - - 20 - - 20 ns/V All information provided in this document is subject to legal disclaimers. Rev. 7 — 5 November 2014 © Nexperia B.V. 2017. All rights reserved 3 of 12 74AHC1G00; 74AHCT1G00 Nexperia 2-input NAND gate 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V For type 74AHC1G00 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 3.94 - - 3.8 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 A CI input capacitance - 1.5 10 - 10 - 10 pF For type 74AHCT1G00 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A IO = 8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA II input leakage current 74AHC_AHCT1G00 Product data sheet VI = 5.5 V or GND; VCC = 0 V to 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 5 November 2014 © Nexperia B.V. 2017. All rights reserved 4 of 12 74AHC1G00; 74AHCT1G00 Nexperia 2-input NAND gate Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 A ICC additional per input pin; VI = 3.4 V; supply current other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 1.5 10 - 10 - 10 pF 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf =  3.0 ns. For test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 4.5 7.9 1.0 9.5 1.0 10.5 ns - 6.5 11.4 1.0 13.0 1.0 14.5 ns - 3.5 5.5 1.0 6.5 1.0 7.0 ns - 4.9 7.5 1.0 8.5 1.0 9.5 ns - 17 - - - - - pF - 3.6 6.2 1.0 7.1 1.0 8.0 ns - 5.0 7.9 1.0 9.0 1.0 10.0 ns - 18 - - - - - pF For type 74AHC1G00 tpd propagation delay A and B to Y; see Figure 5 [1] [2] VCC = 3.0 V to 3.6 V CL = 15 pF CL = 50 pF [3] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power dissipation capacitance per buffer; CL = 50 pF; f = 1 MHz; VI = GND to VCC [4] A and B to Y; see Figure 5 [1] For type 74AHCT1G00 tpd propagation delay VCC = 4.5 V to 5.5 V [3] CL = 15 pF CL = 50 pF CPD power dissipation capacitance [4] per buffer; VI = GND to VCC [1] tpd is the same as tPLH and tPHL. [2] Typical values are measured at VCC = 3.3 V. [3] Typical values are measured at VCC = 5.0 V. [4] CPD is used to determine the dynamic power dissipation PD (W). PD = CPD  VCC2  fi +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 74AHC_AHCT1G00 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 5 November 2014 © Nexperia B.V. 2017. All rights reserved 5 of 12 74AHC1G00; 74AHCT1G00 Nexperia 2-input NAND gate 12. Waveforms 90 $%LQSXW W3+/ W3/+ 90
74AHCT1G00GV,125 价格&库存
很抱歉,暂时无法提供与“74AHCT1G00GV,125”相匹配的价格&库存,您可以联系我们找货
74AHCT1G00GV,125
  • 1+1.13791
  • 10+0.78935
  • 25+0.67316
  • 100+0.60824
  • 250+0.58045
  • 500+0.52200
  • 1000+0.48715
  • 3000+0.46966
库存:544
74AHCT1G00GV,125
    74AHCT1G00GV,125
    74AHCT1G00GV,125
    • 3000+0.454873000+0.05904
    • 6000+0.439036000+0.05698
    • 9000+0.431109000+0.05595
    • 15000+0.4223215000+0.05481
    • 21000+0.4171821000+0.05415
    • 30000+0.4122330000+0.05350
    库存:3276
