74AHC1G00; 74AHCT1G00
2-input NAND gate
Rev. 7 — 5 November 2014
Product data sheet
1. General description
74AHC1G00 and 74AHCT1G00 are high-speed Si-gate CMOS devices. They provide a
2-input NAND function.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
2. Features and benefits
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
SOT353-1 and SOT753 package options
ESD protection:
HBM JESD22-A114E: exceeds 2000 V
MM JESD22-A115-A: exceeds 200 V
CDM JESD22-C101C: exceeds 1000 V
Specified from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74AHC1G00GW
Package
Temperature range
Name
Description
Version
40 C to +125 C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74AHCT1G00GW
74AHC1G00GV
74AHCT1G00GV
Nexperia
2-input NAND gate
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74AHC1G00GW
AA
74AHC1G00GV
A00
74AHCT1G00GW
CA
74AHCT1G00GV
C00
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
PQD
PQD
Fig 1.
Fig 2.
IEC logic symbol
Fig 3.
PQD
Logic diagram
6. Pinning information
6.1 Pinning
$+&7*
*1'
9&&
DDI
Fig 4.
Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
74AHC_AHCT1G00
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
Nexperia
2-input NAND gate
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Inputs
Output
A
B
Y
L
L
H
L
H
H
H
L
H
H
H
L
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
Conditions
0.5
+7.0
V
VI
input voltage
0.5
+7.0
V
IIK
input clamping current
VI < 0.5 V
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
IO
output current
0.5 V < VO < VCC + 0.5 V
mA
25
mA
ICC
supply current
75
mA
IGND
ground current
75
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise
and fall rate
74AHC_AHCT1G00
Product data sheet
Conditions
74AHC1G00
74AHCT1G00
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
5.5
4.5
5.0
5.5
V
V
VCC
VCC
V
40
+25
+125
40
+25
+125
C
VCC = 3.3 V 0.3 V
100
ns/V
VCC = 5.0 V 0.5 V
ns/V
3 of 12
Nexperia
2-input NAND gate
10. Static characteristics
Table 7.
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 50 A; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = 50 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = 8.0 mA; VCC = 4.5 V
For type 74AHC1G00
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
3.94
3.8
3.70
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
A
CI
input
capacitance
1.5
10
10
10
pF
For type 74AHCT1G00
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = 50 A
4.4
4.5
4.4
4.4
V
3.94
3.8
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
IO = 8.0 mA
VOL
LOW-level
output voltage
IO = 50 A
IO = 8.0 mA
II
input leakage
current
74AHC_AHCT1G00
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
4 of 12
Nexperia
2-input NAND gate
Table 7.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
ICC
VCC = 5.5 V
1.0
10
40
A
ICC
additional
per input pin; VI = 3.4 V;
supply current other inputs at VCC or GND;
IO = 0 A; VCC = 5.5 V
1.35
1.5
1.5
mA
CI
input
capacitance
1.5
10
10
10
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf = 3.0 ns. For test circuit see Figure 6.
Symbol Parameter
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
4.5
7.9
1.0
9.5
1.0
10.5
ns
6.5
11.4
1.0
13.0
1.0
14.5
ns
3.5
5.5
1.0
6.5
1.0
7.0
ns
4.9
7.5
1.0
8.5
1.0
9.5
ns
17
pF
3.6
6.2
1.0
7.1
1.0
8.0
ns
5.0
7.9
1.0
9.0
1.0
10.0
ns
18
pF
For type 74AHC1G00
tpd
propagation
delay
A and B to Y; see Figure 5
[1]
[2]
VCC = 3.0 V to 3.6 V
CL = 15 pF
CL = 50 pF
[3]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
per buffer;
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[4]
[1]
For type 74AHCT1G00
tpd
propagation
delay
[3]
CL = 15 pF
CL = 50 pF
CPD
power
dissipation
capacitance
[4]
per buffer;
VI = GND to VCC
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
[3]
Typical values are measured at VCC = 5.0 V.
[4]
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
74AHC_AHCT1G00
Product data sheet
5 of 12
Nexperia
2-input NAND gate
12. Waveforms
90
$%LQSXW
W3+/
W3/+
90
很抱歉,暂时无法提供与“74AHC1G00GV,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.60921
- 800+0.59047
- 1500+0.57277
- 国内价格
- 1+1.89250
- 3+1.70930
- 10+1.55710
- 25+1.37870
- 100+1.19660
- 159+0.69470
- 438+0.65520
- 3000+0.63120
