74AHCT1G86GW,125
74AHCT1G86GW,125
    NEXPERIA(安世)
    TSSOP-5_2.05X1.25MM
    IC GATE XOR 1CH 2-INP 5TSSOP
74AHCT1G86GW,125 数据手册
74AHC1G86; 74AHCT1G86 2-input EXCLUSIVE-OR gate Rev. 05 — 4 July 2007 Product data sheet 1. General description 74AHC1G86 and 74AHCT1G86 are high-speed Si-gate CMOS devices. They provide a 2-input EXCLUSIVE-OR function. The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V. The AHCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V. 2. Features n Symmetrical output impedance n High noise immunity n ESD protection: u HBM JESD22-A114E: exceeds 2000 V u MM JESD22-A115-A: exceeds 200 V u CDM JESD22-C101C: exceeds 1000 V n Low power dissipation n Balanced propagation delays n SOT353-1 and SOT753 package options n Specified from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74AHC1G86GW Package Temperature range Name Description Version −40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 −40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74AHCT1G86GW 74AHC1G86GV 74AHCT1G86GV 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 4. Marking Table 2. Marking codes Type number Marking code 74AHC1G86GW AH 74AHCT1G86GW CH 74AHC1G86GV A86 74AHCT1G86GV C86 5. Functional diagram 1 2 B A Y 1 4 =1 4 2 mna039 mna038 Fig 1. Logic symbol Fig 2. IEC logic symbol B Y A mna040 Fig 3. Logic diagram 6. Pinning information 6.1 Pinning 74AHC1G86 B 1 A 2 GND 3 5 VCC 4 Y 001aaf054 Fig 4. Pin configuration © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 2 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 6.2 Pin description Table 3. Pin description Symbol Pin Description B 1 data input A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Inputs Output A B Y L L L L H H H L H H H L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Max Unit supply voltage −0.5 +7.0 V VI input voltage −0.5 +7.0 V IIK input clamping current VI < −0.5 V IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V IO output current −0.5 V < VO < VCC + 0.5 V ICC −20 - mA - ±20 mA - ±25 mA supply current - 75 mA IGND ground current −75 - mA Tstg storage temperature −65 +150 °C - 250 mW total power dissipation Ptot Tamb = −40 °C to +125 °C [1] [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For both TSSOP5 and SC-74A packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 3 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC1G86 Min Typ 74AHCT1G86 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V For type 74AHC1G86 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = −50 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −50 µA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = −50 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = −8.0 mA; VCC = 4.5 V 3.94 - - 3.8 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 µA II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 µA CI input capacitance - 1.5 10 - 10 - 10 pF © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 4 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max For type 74AHCT1G86 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = −50 µA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V IO = −8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 µA IO = 8.0 mA VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 µA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.0 - 10 - 40 µA ∆ICC additional per input pin; VI = 3.4 V; supply current other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 1.5 10 - 10 - 10 pF 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf = ≤ 3.0 ns. For waveform see Figure 5. For test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max CL = 15 pF - 4.0 11.0 1.0 13.0 1.0 14.0 ns CL = 50 pF - 5.8 14.5 1.0 16.5 1.0 18.5 ns - 3.4 6.8 1.0 8.0 1.0 8.5 ns - 4.9 8.8 1.0 10.0 1.0 11.5 ns - 9 - - - - - pF For type 74AHC1G86 tpd propagation delay A and B to Y VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V [1] [2] [3] CL = 15 pF CL = 50 pF CPD power per buffer; dissipation CL = 50 pF; f = 1 MHz; capacitance VI = GND to VCC [4] © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 5 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate Table 8. Dynamic characteristics …continued GND = 0 V; tr = tf = ≤ 3.0 ns. For waveform see Figure 5. For test circuit see Figure 6. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 3.5 6.9 1.0 8.0 1.0 9.0 ns - 5.0 7.9 1.0 9.0 1.0 10.5 ns - 11 - - - - - pF For type 74AHCT1G86 propagation delay tpd [1] A and B to Y VCC = 4.5 V to 5.5 V [3] CL = 15 pF CL = 50 pF power per buffer; dissipation CL = 50 pF; f = 1 MHz; capacitance VI = GND to VCC CPD [4] [1] tpd is the same as tPLH and tPHL. [2] Typical values are measured at VCC = 3.3 V. [3] Typical values are measured at VCC = 5.0 V. [4] CPD is used to determine the dynamic power dissipation PD (µW). PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 12. Waveforms A, B input VM tPHL Y output tPLH VM mna041 Measurement points are given in Table 9. Fig 5. The input (A and B) to output (Y) propagation delays Table 9. Measurement points Type Input Output VI VM VM 74AHC1G86 GND to VCC 0.5 × VCC 0.5 × VCC 74AHCT1G86 GND to 3.0 V 1.5 V 0.5 × VCC © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 6 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate VCC PULSE GENERATOR VI VO DUT RT CL 50 pF mna034 Test data is given in Table 8. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 6. Load circuitry for switching times © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 7 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 13. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm E D SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 L e w M bp detail X e1 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Fig 7. Package outline SOT353-1 (TSSOP5) © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 8 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate Plastic surface-mounted package; 5 leads SOT753 D E B y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Fig 8. Package outline SOT753 (SC-74A) © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 9 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 14. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT1G86_5 20070704 Product data sheet - 74AHC_AHCT1G86_4 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors . • • • Legal texts have been adapted to the new company name where appropriate. Package SOT353 changed to SOT353-1 in Section 3 and Section 13. Quick reference data and Soldering sections removed. 74AHC_AHCT1G86_4 20020606 Product specification - 74AHC_AHCT1G86_3 74AHC_AHCT1G86_3 20020218 Product specification - 74AHC_AHCT1G86_2 74AHC_AHCT1G86_2 20010406 Product specification - 74AHC1G_AHCT1G86_1 74AHC1G_AHCT1G86_1 19990920 Product specification - - © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 10 of 12 74AHC1G86; 74AHCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 16.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74AHC_AHCT1G86_5 Product data sheet Rev. 05 — 4 July 2007 Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia 74AHC1G86; 74AHCT1G86 2-input EXCLUSIVE-OR gate 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 July 2007 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHC1G86GV,125 74AHC1G86GW,125 74AHCT1G86GV,125 74AHCT1G86GW,125
74AHCT1G86GW,125
物料型号:74AHC_AHCT1G86 器件简介:74AHC_AHCT1G86是一款高速CMOS双4路数据选择器/多路复用器,具有低功耗和高噪声抑制特性。
引脚分配:该器件有24个引脚,包括8个数据输入、4个使能输入、4个输出和8个Vcc和GND引脚。
参数特性:工作电压范围为2.0V至5.5V,工作温度范围为-40℃至+85℃,符合RoHS标准。
功能详解:支持高速操作,具有三态输出,可实现数据选择和多路复用功能。
应用信息:适用于高速数据通信、多路数据选择和信号分配等应用场景。
封装信息:提供多种封装选项,包括TSSOP-24和QFN-24等。
74AHCT1G86GW,125 价格&库存
很抱歉,暂时无法提供与“74AHCT1G86GW,125”相匹配的价格&库存,您可以联系我们找货
74AHCT1G86GW,125
  • 3000+0.344383000+0.04451
  • 6000+0.331946000+0.04291
  • 9000+0.325719000+0.04210
  • 15000+0.3188015000+0.04121
  • 21000+0.3147721000+0.04069
  • 30000+0.3108930000+0.04019
库存:3475
74AHCT1G86GW,125
    74AHCT1G86GW,125
      74AHCT1G86GW,125
      • 5+1.29329
      • 10+0.72970
      • 100+0.56478
      • 500+0.52918
      • 1000+0.49359
      • 5000+0.45918
      • 10000+0.41172
      库存:440
      74AHCT1G86GW,125
      • 1+1.635801+0.21110
      • 10+0.9321010+0.12030
      • 100+0.67980100+0.08780
      • 1000+0.642001000+0.08290
      • 3000+0.566303000+0.07310
      • 9000+0.541109000+0.06990
      • 24000+0.5285024000+0.06820
      • 45000+0.5159045000+0.06660
      • 99000+0.4957099000+0.06400
      库存:16000
