74AHCT86BQ,115
74AHCT86BQ,115
    NEXPERIA(安世)
    DHVQFN-14-EP(2.5x3)
    IC GATE XOR 4CH 2-INP 14DHVQFN
74AHCT86BQ,115 数据手册
74AHC86; 74AHCT86 Quad 2-input EXCLUSIVE-OR gate Rev. 02 — 15 November 2007 Product data sheet 1. General description The 74AHC86; 74AHCT86 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74AHC86; 74AHCT86 provides a 2-input exclusive-OR function. 2. Features ■ ■ ■ ■ ■ ■ Balanced propagation delays All inputs have a Schmitt-trigger action Inputs accepts voltages higher than VCC For 74AHC86 only: operates with CMOS input levels For 74AHCT86 only: operates with TTL input levels ESD protection: ◆ HBM JESD22-A114E exceeds 2000 V ◆ MM JESD22-A115-A exceeds 200 V ◆ CDM JESD22-C101C exceeds 1000 V ■ Multiple package options ■ Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74AHC86D Package Temperature range Name Description Version −40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 −40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 −40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced SOT762-1 very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74AHCT86D 74AHC86PW 74AHCT86PW 74AHC86BQ 74AHCT86BQ 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 4. Functional diagram 1 1A 1B 1Y 3 2A 2B 2Y 6 10 3A 3B 3Y 8 12 13 4A 4B 4Y 11 2 4 5 9 mna787 Fig 1. Logic symbol 1 =1 3 =1 6 =1 8 =1 11 2 4 5 9 10 A 12 Y 13 B Fig 2. Logic diagram (one gate) mna788 mna786 Fig 3. IEC logic symbol © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 2 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 5. Pinning information 1 1A terminal 1 index area 1Y 3 12 4A 2A 4 74AHC86 74AHCT86 2 13 4B 1Y 3 12 4A 2A 4 86 11 4Y 2B 5 GND(1) 10 3B 2Y 6 11 4Y 10 3B 2B 5 2Y 6 9 3A GND 7 8 3Y 9 8 2 1B 3Y 1B 14 VCC 13 4B 7 1 GND 1A 14 VCC 5.1 Pinning 3A 001aad105 Transparent top view 001aah083 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration SO14, TSSOP14 Fig 5. Pin configuration DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10, 13 data input 1Y to 4Y 3, 6, 8, 11 data outputs GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input nA Input nB Output nY L L L L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level. © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 3 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage VI input voltage IIK input clamping current VI < −0.5 V [1] IOK output clamping current VO < −0.5 V or VO > VCC + 0.5 V [1] IO output current VO = −0.5 V to (VCC + 0.5 V) Min Max Unit −0.5 +7.0 V −0.5 +7.0 V −20 - mA - ±20 mA - ±25 mA ICC supply current - 75 mA IGND ground current −75 - mA Tstg storage temperature −65 +150 °C Ptot total power dissipation [1] Tamb = −40 °C to +125 °C SO14 package [2] - 500 mW TSSOP14 package [3] - 500 mW DHVQFN14 package [4] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 °C. [3] Ptot derates linearly with 5.5 mW/K above 60 °C. [4] Ptot derates linearly with 4.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74AHC86 74AHCT86 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 5.5 4.5 5.0 5.5 V VI input voltage 0 - 5.5 0 - 5.5 V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature −40 +25 +125 −40 +25 +125 °C ∆t/∆V input transition rise and fall rate VCC = 3.3 V ± 0.3 V - - 100 - - - ns/V VCC = 5.0 V ± 0.5 V - - 20 - - 20 ns/V © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 4 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = −50 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = −50 µA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = −50 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = −4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = −8.0 mA; VCC = 4.5 V For type 74AHC86 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 3.94 - - 3.8 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 µA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 µA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 µA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 µA CI input capacitance - 3.0 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF For type 74AHCT86 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = −50 µA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.8 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V IO = −8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 µA IO = 8.0 mA © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 5 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 °C Conditions VI = 5.5 V or GND; VCC = 0 V to 5.5 V −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max - - 0.1 - 1.0 - 2.0 µA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 µA ∆ICC additional per input pin; supply current VI = VCC − 2.1 V; IO = 0 A; other pins at VCC or GND; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4.0 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 4.8 11.0 1.0 13.0 1.0 14.0 ns CL = 50 pF - 6.8 14.5 1.0 16.5 1.0 18.5 ns - 3.4 6.8 1.0 8.0 1.0 8.5 ns 4.8 8.8 1.0 10.0 1.0 11.0 ns - 10.0 - - - - - pF For type 74AHC86 tpd propagation delay nA, nB to nY; see Figure 6 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF CPD power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance [3] © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 6 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate Table 7. Dynamic characteristics …continued GND = 0 V; For test circuit see Figure 7. Symbol Parameter 25 °C Conditions −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ[1] Max Min Max Min Max - 3.4 6.9 1.0 8.0 1.0 9.0 ns - 4.9 8.8 1.0 10.0 1.0 11.0 ns - 12.0 - - - - - pF For type 74AHCT86 propagation delay tpd nA, nB to nY; see Figure 6 [2] VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF [3] power CL = 50 pF; fi = 1 MHz; dissipation VI = GND to VCC capacitance CPD [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in µW). PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching Σ(CL × VCC2 × fo) = sum of the outputs. 11. Waveforms VI VM nA, nB input GND t PHL t PLH VOH VM nY output VOL mna224 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Propagation delay input (nA, nB) to output (nY) Table 8. Measurement points Type Input Output VM VM 74AHC86 0.5VCC 0.5VCC 74AHCT86 1.5 V 0.5VCC © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 7 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC PULSE GENERATOR VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistor S1 = Test selection switch Fig 7. Load circuitry for switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74AHC86 VCC 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC 74AHCT86 3.0 V 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 8 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 8. Package outline SOT108-1 (SO14) © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 9 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 9. Package outline SOT402-1 (TSSOP14) © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 10 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b 1 0.05 0.00 0.30 0.18 mm c D (1) Dh E (1) Eh 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT762-1 (DHVQFN14) © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 11 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC_AHCT86_2 20071115 Product data sheet - 74AHC_AHCT86_1 Modifications: 74AHC_AHCT86_1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Section 3: DHVQFN14 package added. Section 7: derating values added for DHVQFN14 package. Section 12: outline drawing added for DHVQFN14 package. 19990917 Product specification - © 74AHC_AHCT86_2 Product data sheet - Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 12 of 14 74AHC86; 74AHCT86 Nexperia Quad 2-input EXCLUSIVE-OR gate 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 15.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74AHC_AHCT86_2 Product data sheet Rev. 02 — 15 November 2007 Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia 74AHC86; 74AHCT86 Quad 2-input EXCLUSIVE-OR gate 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 November 2007 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AHC86BQ,115 74AHC86D,112 74AHC86D,118 74AHC86PW,112 74AHC86PW,118 74AHCT86D,112 74AHCT86D,118 74AHCT86PW,112 74AHCT86PW,118 74AHCT86BQ,115
74AHCT86BQ,115 价格&库存
很抱歉,暂时无法提供与“74AHCT86BQ,115”相匹配的价格&库存,您可以联系我们找货
74AHCT86BQ,115
  • 1+3.175031+0.41037
  • 10+2.2203910+0.28699
  • 25+1.9770425+0.25553
  • 100+1.70759100+0.22071
  • 250+1.57827250+0.20399
  • 500+1.50056500+0.19395
  • 1000+1.436411000+0.18566
库存:1451
74AHCT86BQ,115
  • 3000+1.199503000+0.15504
  • 6000+1.164516000+0.15052
  • 9000+1.146999000+0.14825
  • 15000+1.1275815000+0.14574
  • 21000+1.1162321000+0.14428
  • 30000+1.1053230000+0.14287
库存:1451
