74AHC1GU04-Q100
Inverter
Rev. 1 — 21 November 2012
Product data sheet
1. General description
The 74AHC1GU04-Q100 is a high-speed Si-gate CMOS device. It provides an inverting
single stage function.
The AHC device has CMOS input switching levels and supply voltage range 2 V to 5.5 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
74AHC1GU04GW-Q100 40 C to +125 C
74AHC1GU04GV-Q100
40 C to +125 C
Description
Version
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
SC-74A
plastic surface-mounted package; 5 leads
SOT753
4. Marking
Table 2.
Marking codes
Type number
Marking
74AHC1GU04GW-Q100
AD
74AHC1GU04GV-Q100
AU4
74AHC1GU04-Q100
Nexperia
Inverter
5. Functional diagram
A
2
Y
4
1
2
Logic symbol
A
Y
mna044
mna043
Fig 1.
4
Fig 2.
mna045
IEC logic symbol
Fig 3.
Logic diagram
6. Pinning information
6.1 Pinning
$+&*84
QF
*1'
9&&
DDD
Fig 4.
Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
Y
L
H
H
L
74AHC1GU04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
74AHC1GU04-Q100
Nexperia
Inverter
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
Conditions
Unit
0.5
+7.0
V
mA
+7.0
V
VO < 0.5 V or VO > VCC + 0.5 V
mA
0.5 V < VO < VCC + 0.5 V
25
mA
supply current
75
mA
ground current
75
mA
65
+150
C
250
mW
input clamping current
input voltage
IOK
output clamping current
IO
output current
ICC
IGND
Tstg
storage temperature
[1]
total power dissipation
Ptot
Max
0.5
IIK
VI
VI < 0.5 V
Min
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For both TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 3.3 V 0.3 V
100
ns/V
VCC = 5.0 V 0.5 V
ns/V
10. Static characteristics
Table 7.
Symbol
Parameter
25 C
Conditions
Min
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
74AHC1GU04_Q100
Product data sheet
Typ
40 C to +85 C
Max
Min
40 C to +125 C Unit
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
3 of 13
74AHC1GU04-Q100
Nexperia
Inverter
Table 7.
Static characteristics …continued
Symbol
Parameter
25 C
Conditions
Min
VOH
VOL
Typ
40 C to +85 C
Max
Min
40 C to +125 C Unit
Max
Min
Max
HIGH-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 50 A; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = 50 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 4.0 mA; VCC = 3.0 V 2.58
2.48
2.40
V
IO = 8.0 mA; VCC = 4.5 V 3.94
3.8
3.70
V
LOW-level
VI = VIH or VIL
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
1.0
10
40
A
CI
input
capacitance
- 1.5
10
10
10
pF
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf = 3.0 ns. For test circuit see Figure 6.
Symbol
Parameter
25 C
Conditions
Min
tpd
propagation
delay
A to Y; see Figure 5
VCC = 3.0 V to 3.6 V
Max
Min
Max
3.4
7.1
1.0
8.5
1.0
10.0
ns
4.9
10.6
1.0
12.0
1.0
13.5
ns
CL = 15 pF
2.6
5.5
1.0
6.0
1.0
7.0
ns
CL = 50 pF
3.6
7.0
1.0
8.0
1.0
9.0
ns
14
VCC = 4.5 V to 5.5 V
per buffer;
VI = GND to VCC
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
[3]
Typical values are measured at VCC = 5.0 V.
[4]
Min
[2]
CL = 50 pF
power
dissipation
capacitance
Max
[1]
CL = 15 pF
CPD
Typ
40 C to +85 C 40 C to +125 C Unit
[3]
[4]
pF
CPD is used to determine the dynamic power dissipation PD (W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
74AHC1GU04_Q100
Product data sheet
4 of 13
74AHC1GU04-Q100
Nexperia
Inverter
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts.
12. Waveforms
VM(1)
A input
VCC
tPHL
tPLH
PULSE
GENERATOR
VI
CL
50 pF
RT
VM(1)
Y output
VO
DUT
mna034
mna046
VM = 0.5 VCC; VI = GND to VCC.
Test data is given in Table 8.
Definitions for test circuit:
CL = Load capacitance including jig and probe
capacitance.
RT = Termination resistance should be equal to output
impedance Zo of the pulse generator.
Fig 5.
The input (A) to output (Y) propagation delay
times
Fig 6.
Load circuitry for switching times
13. Typical transfer characteristics
mna397
2.0
VO
(V)
1.6
mna398
1.0
VO
ICC
(mA)
0.8
1.2
0.6
0.8
0.4
3.0
10
VO
ICC
(mA)
VO
(V)
8
6
1.5
4
ID (drain current)
0.4
ID (drain current)
2
0.8
1.2
1.6
1
2
VI (V)
VI (V)
Fig 7.
VCC = 2.0 V; IO = 0 A
74AHC1GU04_Q100
Product data sheet
Fig 8.
3
VCC = 3.0 V; IO = 0 A
5 of 13
74AHC1GU04-Q100
Nexperia
Inverter
mna399
6
50
VO
(V)
ICC
(mA)
40
VO
Rbias = 560 kΩ
VCC
30
3
0.47 μF
input
100 μF
output
VI
(f = 1 kHz)
ID (drain current)
10
A IO
GND
mna050
Fig 9.
2
4
6
VI (V)
VCC = 5.5 V; IO = 0 A
Fig 10. Test set-up for measuring forward
transconductance gfs = IO/VI at VO is
constant
mna400
40
gfs
(mA/V)
30
4
VCC (V)
6
Fig 11. Typical forward transconductance gfs as a function of the supply voltage at Tamb = 25 C
14. Application information
Some applications are:
• Linear amplifier (see Figure 12)
• In crystal oscillator design (see Figure 13)
Remark: All values given are typical unless otherwise specified.
74AHC1GU04_Q100
Product data sheet
6 of 13
74AHC1GU04-Q100
Nexperia
Inverter
R2
R1
VCC
1 μF
R2
R1
U04
U04
C1
ZL
C2
out
mna052
mna053
Maximum Vo(p-p) = VCC 1.5 V centered at 0.5 VCC.
C1 = 47 pF (typical)
G ol
G v = – --------------------------------------R1
1 + ------- 1 + G ol
R2
C2 = 22 pF (typical)
R1 = 1 M to 10 M (typical)
R2 optimum value depends on the frequency and
required stability against changes in VCC or average
minimum ICC (ICC is typically 2 mA at VCC = 3 V and
f = 1 MHz).
Gol = open loop gain
Gv = voltage gain
R1 3 k, R2 1 M
ZL > 10 k; Gol = 20 (typical)
Typical unity gain bandwidth product is 5 MHz.
Fig 12. Used as a linear amplifier
Fig 13. Crystal oscillator configuration
Table 9.
External components for resonator (f < 1 MHz)
All values given are typical and must be used as an initial set-up.
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
22 M
220 k
56 pF
20 pF
16 kHz to 24.9 kHz
22 M
220 k
56 pF
10 pF
25 kHz to 54.9 kHz
22 M
100 k
56 pF
10 pF
55 kHz to 129.9 kHz
22 M
100 k
47 pF
5 pF
130 kHz to 199.9 kHz
22 M
47 k
47 pF
5 pF
200 kHz to 349.9 kHz
22 M
47 k
47 pF
5 pF
350 kHz to 600 kHz
22 M
47 k
47 pF
5 pF
Table 10.
Optimum value for R2
Frequency
R2
Optimum for
3 kHz
2.0 k
minimum required ICC
8.0 k
minimum influence due to change in VCC
6 kHz
1.0 k
4.7 k
minimum influence by VCC
0.5 k
10 kHz
14 kHz
>14 kHz
74AHC1GU04_Q100
Product data sheet
2.0 k
0.5 k
1.0 k
replace R2 by C3 with a typical value of 35 pF
7 of 13
74AHC1GU04-Q100
Nexperia
Inverter
15. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 14. Package outline SOT353-1 (TSSOP5)
74AHC1GU04_Q100
Product data sheet
8 of 13
74AHC1GU04-Q100
Nexperia
Inverter
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 15. Package outline SOT753 (SC-74A)
74AHC1GU04_Q100
Product data sheet
9 of 13
74AHC1GU04-Q100
Nexperia
Inverter
16. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
17. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC1GU04_Q100 v.1
20121121
Product data sheet
74AHC1GU04_Q100
Product data sheet
10 of 13
74AHC1GU04-Q100
Nexperia
Inverter
18. Legal information
18.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
18.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AHC1GU04_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
11 of 13
74AHC1GU04-Q100
Nexperia
Inverter
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
18.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
19. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC1GU04_Q100
Product data sheet
12 of 13
Nexperia
74AHC1GU04-Q100
Inverter
20. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
18
18.1
18.2
18.3
18.4
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 3
Dynamic characteristics . . . . . . . . . . . . . . . . . . 4
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Typical transfer characteristics . . . . . . . . . . . . 5
Application information. . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Date of release: 21 November 2012
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHC1GU04GW-Q100H 74AHC1GU04GV-Q100H
很抱歉,暂时无法提供与“74AHC1GU04GW-Q100H”相匹配的价格&库存,您可以联系我们找货
