74AUP1G02
Low-power 2-input NOR gate
Rev. 7 — 21 January 2015
Product data sheet
1. General description
The 74AUP1G02 provides the single 2-input NOR function.
Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial Power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP1G02
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G02GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AUP1G02GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP1G02GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP1G02GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP1G02GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AUP1G02GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP1G02GW
pB
74AUP1G02GM
pB
74AUP1G02GF
pB
74AUP1G02GN
pB
74AUP1G02GS
pB
74AUP1G02GX
pB
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Fig 1.
Logic symbol
74AUP1G02
Product data sheet
PQD
PQD
PQD
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 21
74AUP1G02
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
*1'
9&&
9&&
QF
*1'
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 4.
Pin configuration SOT353-1
Fig 5.
Pin configuration SOT886
$83*
$83*
9&&
QF
*1'
9&&
*1'
DDI
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Symbol
Pin description
Pin
Description
TSSOP5 and X2SON5
XSON6
B
1
1
data input
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74AUP1G02
Product data sheet
3 of 21
74AUP1G02
Nexperia
7. Functional description
Table 4.
Function table[1]
Input
Output
A
B
Y
L
L
H
L
H
L
H
L
L
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
Min
0.5
+4.6
V
VI < 0 V
50
mA
0.5
+4.6
V
50
mA
0.5
+4.6
V
mA
[1]
VO > VCC or VO < 0 V
[1]
Max
Unit
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
[2]
Tamb = 40 C to +125 C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
VI
VO
output voltage
Conditions
Min
Max
Unit
supply voltage
0.8
3.6
V
input voltage
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 0.8 V to 3.6 V
ns/V
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AUP1G02
Product data sheet
4 of 21
74AUP1G02
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 VCC
V
VCC = 0.9 V to 1.95 V
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.75 VCC
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
0.1
V
VI = VIH or VIL
0.3 VCC V
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP1G02
Product data sheet
[1]
5 of 21
74AUP1G02
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 VCC
V
0.65 VCC
V
1.6
V
2.0
V
0.30 VCC V
0.35 VCC V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VCC = 0.8 V
0.7
V
0.9
V
VI = VIH or VIL
VCC 0.1
V
0.7 VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
VI = VIH or VIL
0.3 VCC V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP1G02
Product data sheet
[1]
6 of 21
74AUP1G02
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.75 VCC
V
0.70 VCC
V
1.6
V
2.0
V
0.25 VCC V
0.30 VCC V
VIH
VIL
VOH
VOL
VCC = 0.8 V
0.7
V
0.9
V
VI = VIH or VIL
VCC 0.11
V
0.6 VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
VI = VIH or VIL
0.33 VCC V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
[1]
[1]
One input at VCC 0.6 V, other input at VCC or GND.
74AUP1G02
Product data sheet
7 of 21
74AUP1G02
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9
Symbol
Parameter
Min
Typ [1]
Max
17.0
ns
VCC = 1.1 V to 1.3 V
2.5
5.1
10.8
ns
VCC = 1.4 V to 1.6 V
1.6
3.7
6.7
ns
Conditions
Unit
Tamb = 25 C; CL = 5 pF
tpd
propagation delay
A, B to Y; see Figure 8
[2]
VCC = 0.8 V
VCC = 1.65 V to 1.95 V
1.3
3.0
5.3
ns
1.0
2.4
3.9
ns
1.0
2.2
3.4
ns
20.4
ns
2.4
6.0
12.8
ns
1.9
4.3
7.9
ns
Tamb = 25 C; CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
1.6
3.6
6.2
ns
1.4
3.0
4.7
ns
1.3
2.7
4.2
ns
23.9
ns
3.4
6.8
14.6
ns
2.3
4.8
8.9
ns
Tamb = 25 C; CL = 15 pF
tpd
propagation delay
[2]
VCC = 0.8 V
1.9
4.0
7.0
ns
1.7
3.4
5.4
ns
1.6
3.2
4.8
ns
34.2
ns
4.6
9.0
19.9
ns
3.4
6.4
11.8
ns
Tamb = 25 C; CL = 30 pF
tpd
propagation delay
[2]
VCC = 0.8 V
74AUP1G02
Product data sheet
2.6
5.3
9.3
ns
2.4
4.5
7.1
ns
2.3
4.2
6.4
ns
8 of 21
74AUP1G02
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol
Parameter
Conditions
Min
Typ [1]
Max
Unit
Tamb = 25 C
power dissipation capacitance f = 1 MHz; VI = GND to VCC
CPD
VCC = 0.8 V
2.6
pF
2.7
pF
2.9
pF
3.1
pF
3.5
pF
4.1
pF
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
Table 9.
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
2.1
12.1
2.1
13.4
ns
1.4
7.8
1.4
8.6
ns
1.1
6.2
1.1
6.9
ns
0.9
4.6
0.9
5.1
ns
0.8
4.0
0.8
4.4
ns
2.2
14.3
2.2
15.8
ns
1.7
9.2
1.7
10.2
ns
1.5
7.3
1.5
8.1
ns
1.2
5.6
1.2
6.2
ns
1.2
5.0
1.2
5.5
ns
CL = 5 pF
tpd
propagation delay
[1]
CL = 10 pF
tpd
propagation delay
74AUP1G02
Product data sheet
[1]
9 of 21
74AUP1G02
Nexperia
Table 9.
Symbol
Parameter
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
3.1
16.4
3.1
18.1
ns
2.0
10.4
2.0
11.5
ns
1.7
8.3
1.7
9.2
ns
1.5
6.3
1.5
7.0
ns
1.4
5.7
1.4
6.3
ns
CL = 15 pF
propagation delay
tpd
[1]
CL = 30 pF
propagation delay
tpd
[1]
[1]
4.1
22.4
4.1
24.7
ns
2.9
13.9
2.9
15.3
ns
2.3
11.1
2.3
12.3
ns
2.1
8.5
2.1
9.4
ns
2.1
7.7
2.1
8.5
ns
12. Waveforms
9,
90
$%LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74AUP1G02GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 40+1.90886
- 760+1.85158
- 1520+1.79639
- 国内价格
- 1+5.13000
- 10+4.24440
- 30+3.81240
- 100+3.38040
- 500+2.97000
- 1000+2.82960
