74AUP1G3208
Low-power 3-input OR-AND gate
Rev. 7 — 7 March 2017
1
Product data sheet
General description
The 74AUP1G3208 provides the Boolean function: Y = (A + B) × C. The user can choose
the logic functions OR, AND and OR-AND. All inputs can be connected to VCC or GND.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the
device when it is powered down.
2
Features and benefits
• Wide supply voltage range from 0.8 V to 3.6 V
• High noise immunity
• Complies with JEDEC standards:
– JESD8-12 (0.8 V to 1.3 V)
– JESD8-11 (0.9 V to 1.65 V)
– JESD8-7 (1.2 V to 1.95 V)
– JESD8-5 (1.8 V to 2.7 V)
– JESD8-B (2.7 V to 3.6 V)
• ESD protection:
– HBM JESD22-A114F Class 3A exceeds 5000 V
– MM JESD22-A115-A exceeds 200 V
– CDM JESD22-C101E exceeds 1000 V
• Low static power consumption; ICC = 0.9 μA (maximum)
• Latch-up performance exceeds 100 mA per JESD 78 Class II
• Inputs accept voltages up to 3.6 V
• Low noise overshoot and undershoot < 10 % of VCC
• IOFF circuitry provides partial Power-down mode operation
• Multiple package options
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP1G3208
Nexperia
3
Ordering information
Table 1. Ordering information
Type number
Package
Temperature
range
Name
Description
Version
74AUP1G3208GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP1G3208GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads;
6 terminals; body 1 × 1.45 × 0.5 mm
SOT886
74AUP1G3208GF
-40 °C to +125 °C
XSON6
6 terminals; body 1 × 1 × 0.5 mm
SOT891
74AUP1G3208GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 × 1.0 × 0.35 mm
SOT1115
74AUP1G3208GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 × 1.0 × 0.35 mm
SOT1202
74AUP1G3208GX
-40 °C to +125 °C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 × 0.8 × 0.35 mm
SOT1255
4
Marking
Table 2. Marking
Type number
Marking code
74AUP1G3208GW
a2
74AUP1G3208GM
a2
74AUP1G3208GF
a2
74AUP1G3208GN
a2
74AUP1G3208GS
a2
74AUP1G3208GX
a2
[1]
5
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
Functional diagram
A
1
3
B
6
C
4
Y
001aad501
Figure 1. Logic symbol
74AUP1G3208
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 22
74AUP1G3208
Nexperia
6
Pinning information
6.1 Pinning
74AUP1G3208
74AUP1G3208
A
1
6
C
GND
2
5
VCC
B
3
4
A
1
6
C
GND
2
5
VCC
B
3
4
Y
Y
001aad507
Transparent top view
001aad500
Figure 2. Pin configuration SOT363
Figure 3. Pin configuration SOT886
74AUP1G3208
74AUP1G3208
A
1
6
C
GND
2
5
VCC
B
3
4
Y
A
1
GND
001aad506
2
3
B
Figure 4. Pin configuration SOT891, SOT1115 and
SOT1202
C
6
5
VCC
4
Y
aaa-022052
Figure 5. Pin configuration SOT1255 (X2SON6)
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
A
1
data input A
GND
2
ground (0 V)
B
3
data input B
Y
4
data output Y
VCC
5
supply voltage
C
6
data input C
74AUP1G3208
Product data sheet
3 / 22
74AUP1G3208
Nexperia
7
Functional description
Table 4. Function table
[1]
Output
Input
C
B
A
Y
L
L
L
L
L
L
H
L
L
H
L
L
L
H
H
L
H
L
L
L
H
L
H
H
H
H
L
H
H
H
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level.
7.1 Logic configurations
Table 5. Function selection table
Logic function
Figure
2-input AND
see Figure 6 and Figure 7
2-input OR
see Figure 8
3-input gate with the Boolean function: Y = (A + B) × C
see Figure 9
B
C
VCC
Y
B
1
2
3
6
5
4
A
C
C
VCC
Y
A
1
2
3
Y
6
5
4
001aad502
Figure 6. 2-input AND gate
A
B
Y
VCC
A
1
2
3
6
5
4
Product data sheet
001aad503
A
B
C
VCC
Y
A
B
Y
001aad504
74AUP1G3208
Y
Figure 7. 2-input AND gate
B
Figure 8. 2-input OR gate
C
1
2
3
6
5
4
C
Y
001aad505
Figure 9. 3-input gate with the Boolean function:
Y = (A + B) × C
4 / 22
74AUP1G3208
Nexperia
8
Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
Conditions
supply voltage
Min
Max
Unit
-0.5
+4.6
V
input voltage
[1]
-0.5
+4.6
V
VO
output voltage
Active mode and Power-down mode
[1]
-0.5
+4.6
V
IIK
input clamping current
VI < 0 V
-50
mA
IOK
output clamping current
VO < 0 V
-50
mA
IO
output current
VO = 0 V to VCC
±20
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
250
mW
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
200
ns/V
VI
Ptot
[1]
[2]
total power dissipation
Tamb = -40 °C to +125 °C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SC-88 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9
Recommended operating conditions
Table 7. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
74AUP1G3208
Product data sheet
VCC = 0.8 V to 3.6 V
5 / 22
74AUP1G3208
Nexperia
10 Static characteristics
Table 8. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 × VCC
V
VCC = 0.9 V to 1.95 V
0.65 × VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75 × VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3 × VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 0.8 V to 3.6 V
VOL
LOW-level output voltage
VI = VIH or VIL
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
74AUP1G3208
Product data sheet
6 / 22
74AUP1G3208
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
ΔICC
additional supply current
VI = VCC - 0.6 V; IO = 0 A;
VCC = 3.3 V
40
μA
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
VCC = 0.8 V
0.70 × VCC
V
0.65 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 × VCC
V
0.35 × VCC
V
0.7
V
0.9
V
VCC - 0.1
V
0.7 × VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 × VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
[1]
Unit
Tamb = -40 °C to +85 °C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
74AUP1G3208
Product data sheet
7 / 22
74AUP1G3208
Nexperia
Symbol Parameter
Conditions
ΔICC
VCC = 3.3 V
Min
Typ
Max
50
μA
VCC = 0.8 V
0.75 × VCC
V
0.70 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 × VCC
V
0.30 × VCC
V
0.7
V
0.9
V
VCC - 0.11
V
0.6 × VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 × VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
[1]
Unit
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
VCC = 3.3 V
75
μA
[1]
[1]
One input at VCC - 0.6 V, other inputs at VCC or GND.
74AUP1G3208
Product data sheet
8 / 22
74AUP1G3208
Nexperia
11 Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 11.
Symbol Parameter Conditions
25 °C
Min
Typ
[1]
-40 °C to +125 °C
Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 5 pF
tpd
propagation
delay
A, B or C to Y; see Figure 10
[2]
VCC = 0.8 V
18.5
ns
VCC = 1.1 V to 1.3 V
2.2
5.4
10.6
2.2
10.9
11.1
ns
VCC = 1.4 V to 1.6 V
1.9
3.8
6.4
1.8
6.9
7.2
ns
VCC = 1.65 V to 1.95 V
1.5
3.1
5.1
1.4
5.6
5.9
ns
1.3
2.4
3.7
1.2
4.1
4.4
ns
1.2
2.2
3.2
1.1
3.4
3.6
ns
22.1
ns
2.6
6.3
12.4
2.5
12.8
13.1
ns
2.3
4.4
7.4
2.1
8.0
8.4
ns
2.0
3.6
5.9
1.8
6.4
6.8
ns
1.7
3.0
4.4
1.6
4.8
5.1
ns
1.6
2.7
3.9
1.4
4.2
4.4
ns
25.6
ns
3.0
7.1
14.1
2.8
14.6
14.9
ns
2.6
5.0
8.4
2.4
9.1
9.5
ns
2.2
4.1
6.7
2.1
7.4
7.8
ns
2.0
3.4
5.0
1.9
5.5
5.9
ns
1.9
3.2
4.5
1.7
4.8
5.0
ns
34.1
ns
3.9
9.3
18.9
3.7
19.7
20.1
ns
3.4
6.5
11.0
3.2
12.1
12.7
ns
3.0
5.4
8.9
2.9
9.7
10.3
ns
2.8
4.5
6.5
2.6
7.1
7.5
ns
2.6
4.3
5.8
2.4
6.4
6.7
ns
CL = 10 pF
tpd
propagation
delay
[2]
VCC = 0.8 V
CL = 15 pF
tpd
propagation
delay
[2]
VCC = 0.8 V
CL = 30 pF
tpd
propagation
delay
74AUP1G3208
Product data sheet
VCC = 0.8 V
[2]
9 / 22
74AUP1G3208
Nexperia
25 °C
Min
Typ
[1]
-40 °C to +125 °C
Max
Min
Unit
Max
Max
(85 °C) (125 °C)
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
[1]
[2]
[3]
power
dissipation
capacitance
fi = 1 MHz; VI = GND to VCC
[3]
VCC = 0.8 V
2.6
pF
2.7
pF
2.8
pF
3.0
pF
3.5
pF
4.0
pF
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of the outputs.
74AUP1G3208
Product data sheet
10 / 22
74AUP1G3208
Nexperia
11.1 Waveforms and test circuit
VI
A, B, C input
VM
VM
GND
t PHL
t PLH
VOH
VM
Y output
VM
VOL
t PLH
t PHL
VOH
Y output
VM
VM
VOL
001aab593
Measurement points are given in Table 10.
VOL and VOH are typical output voltage levels that occur with the output load.
Figure 10. Input A, B and C to output Y propagation delay times
Table 10. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 × VCC
0.5 × VCC
VCC
≤ 3.0 ns
74AUP1G3208
Product data sheet
11 / 22
74AUP1G3208
Nexperia
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance ZO of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 11. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VEXT
VCC
CL
[1]
RL
0.8 V to 3.6 V
5 kΩ or 1 MΩ
[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
open
GND
2 × VCC
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1G3208
Product data sheet
12 / 22
74AUP1G3208
Nexperia
12 Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
SC-88
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
Figure 12. Package outline SOT363 (SC-88)
74AUP1G3208
Product data sheet
13 / 22
74AUP1G3208
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Figure 13. Package outline SOT886 (XSON6)
74AUP1G3208
Product data sheet
14 / 22
74AUP1G3208
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Figure 14. Package outline SOT891 (XSON6)
74AUP1G3208
Product data sheet
15 / 22
74AUP1G3208
Nexperia
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
mm
1 mm
scale
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Figure 15. Package outline SOT1115 (XSON6)
74AUP1G3208
Product data sheet
16 / 22
74AUP1G3208
Nexperia
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
mm
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Figure 16. Package outline SOT1202 (XSON6)
74AUP1G3208
Product data sheet
17 / 22
74AUP1G3208
Nexperia
X2SON6: plastic thermal enhanced extremely thin small outline package; no leads;
6 terminals; body 1.0 x 0.8 x 0.35 mm
SOT1255
X
A
D
B
A
pin 1
ID area
E
A1
detail X
C
e1
b
(4x)
4
3
y1 C
A B
v
y
L
(4x)
2
5
Dh
(2x)
1
6
e2
1 mm
scale
Unit
A
A1
D
Dh
E
e1
e2
b
L
v
y
y1
max 0.35 0.04 1.05 0.30 0.85
0.30 0.25
nom 0.32 0.02 1.00 0.25 0.80 0.60 0.40 0.25 0.20 0.10 0.05 0.05
0.22 0.17
min 0.30 0.00 0.95 0.22 0.75
mm
sot1255_po
Outline
version
References
IEC
JEDEC
JEITA
European
projection
Issue date
15-07-20
15-07-22
SOT1255
Figure 17. Package outline SOT1255 (X2SON6)
74AUP1G3208
Product data sheet
18 / 22
74AUP1G3208
Nexperia
13 Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14 Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP1G3208 v.7
20170307
Product data sheet
74AUP1G3208 v.6
Modifications:
• The format of this data sheet has been redesigned to comply with the new identity guidelines
of Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74AUP1G3208 v.6
20160309
Modifications:
• Added type number 74AUP1G3208GX (SOT1255/X2SON6)
74AUP1G3208 v.5
20120622
Modifications:
• Package outline drawing of SOT886 (Figure 13) modified.
74AUP1G3208 v.4
20111123
Modifications:
• Legal pages updated.
74AUP1G3208 v.3
20101011
74AUP1G3208 v.2
74AUP1G3208 v.1
74AUP1G3208
Product data sheet
Product data sheet
Product data sheet
Product data sheet
74AUP1G3208 v.5
74AUP1G3208 v.4
74AUP1G3208 v.3
Product data sheet
74AUP1G3208 v.2
20090703
Product data sheet
74AUP1G3208 v.1
20061129
Product data sheet
19 / 22
74AUP1G3208
Nexperia
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74AUP1G3208
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
20 / 22
74AUP1G3208
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74AUP1G3208
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
21 / 22
74AUP1G3208
Nexperia
Contents
1
2
3
4
5
6
6.1
6.2
7
7.1
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 2
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 3
Functional description ........................................4
Logic configurations ...........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Dynamic characteristics .....................................9
Waveforms and test circuit .............................. 11
Package outline .................................................13
Abbreviations .................................................... 19
Revision history ................................................ 19
Legal information .............................................. 20
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 7 March 2017
Document identifier: 74AUP1G3208
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP1G3208GF,132 74AUP1G3208GM,115 74AUP1G3208GM,132 74AUP1G3208GW,125
74AUP1G3208GN,132 74AUP1G3208GS,132 74AUP1G3208GXZ
