74AUP1G38
Low-power 2-input NAND gate (open drain)
Rev. 7 — 4 April 2016
Product data sheet
1. General description
The 74AUP1G38 provides the single 2-input NAND gate with open-drain output. The
output of the device is an open drain and can be connected to other open-drain outputs to
implement active-LOW wired-OR or active-HIGH wired-AND functions.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP1G38
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G38GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74AUP1G38GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP1G38GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP1G38GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP1G38GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AUP1G38GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP1G38GW
aB
74AUP1G38GM
aB
74AUP1G38GF
aB
74AUP1G38GN
aB
74AUP1G38GS
aB
74AUP1G38GX
aB
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74AUP1G38
Product data sheet
*1'
DDE
DDE
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
DDE
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 19
74AUP1G38
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
*1'
9&&
9&&
QF
*1'
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 4.
Pin configuration SOT353-1 (TSSOP5)
Fig 5.
Pin configuration SOT886 (XSON6)
$83*
$83*
9&&
QF
*1'
9&&
*1'
DDI
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT891, SOT1115 and
SOT1202 (XSON6)
Fig 7.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
A
1
1
data input
B
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74AUP1G38
Product data sheet
3 of 19
74AUP1G38
Nexperia
7. Functional description
Table 4.
Function table[1]
Input
Output
A
B
Y
L
L
Z
L
H
Z
H
L
Z
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level;
Z = high-impedance OFF state.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+4.6
50
0.5
+4.6
50
0.5
+4.6
V
+20
mA
V
mA
V
mA
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
supply current
+50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
[2]
Tamb = 40 C to +125 C
[2]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AUP1G38
Product data sheet
Conditions
VCC = 0.8 V to 3.6 V
Min
Max
Unit
0.8
3.6
V
V
V
40
+125
C
ns/V
4 of 19
74AUP1G38
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 VCC
V
VCC = 0.9 V to 1.95 V
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
Tamb = 25 C
VIH
VIL
VOL
HIGH-level input voltage
LOW-level input voltage
LOW-level output voltage
VI = VIH or VIL
0.3 VCC V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOZ
OFF-state output current
VI = VIH or VIL (and at least one input
LOW); VO = 0 V to 3.6 V; VCC = 0 V to
3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A; VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
output enabled; VO = GND; VCC = 0 V
1.7
pF
output disabled; VO = GND; VCC = 0 V
1.1
pF
VCC = 0.8 V
0.70 VCC
V
0.65 VCC
V
1.6
V
2.0
V
Tamb = 40 C to +85 C
VIH
74AUP1G38
Product data sheet
5 of 19
74AUP1G38
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ
VIL
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
0.1
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
VOL
Max
Unit
VI = VIH or VIL
0.3 VCC V
II
0.5
A
IOZ
3.6 V
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
50
A
VCC = 0.8 V
0.75 VCC
V
0.70 VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 VCC V
0.30 VCC V
0.7
V
0.9
V
0.11
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
VIH
VIL
VOL
74AUP1G38
Product data sheet
VI = VIH or VIL
0.33 VCC V
6 of 19
74AUP1G38
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
II
0.75
A
IOZ
3.6 V
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
75
A
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V; for test circuit see Figure 9
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
13.5
ns
VCC = 1.1 V to 1.3 V
1.9
4.6
10.4
1.8
11.4
12.6
ns
VCC = 1.4 V to 1.6 V
1.5
3.3
6.5
1.4
7.4
8.2
ns
Max
Max
(85 C) (125 C)
CL = 5 pF
tpd
propagation delay A or B to Y; see Figure 8
[2]
VCC = 0.8 V
VCC = 1.65 V to 1.95 V
1.2
2.9
5.1
1.1
5.9
6.5
ns
1.0
2.2
3.8
0.9
4.5
4.9
ns
0.9
2.3
4.0
0.8
4.5
4.9
ns
16.3
ns
2.3
5.6
12.3
2.1
13.7
15.1
ns
1.8
4.1
7.6
1.7
8.8
9.7
ns
CL = 10 pF
tpd
[2]
VCC = 0.8 V
1.6
3.8
6.1
1.4
7.1
7.8
ns
1.4
2.9
4.6
1.2
5.4
5.9
ns
1.3
3.2
5.7
1.1
6.4
7.0
ns
19.0
ns
2.6
6.6
14.2
2.4
15.8
17.4
ns
2.1
4.8
8.7
1.9
10.1
11.1
ns
1.9
4.6
7.6
1.7
8.5
9.3
ns
1.6
3.6
5.6
1.5
6.3
6.9
ns
1.6
4.1
7.5
1.4
8.3
9.1
ns
CL = 15 pF
tpd
VCC = 0.8 V
74AUP1G38
Product data sheet
[2]
7 of 19
74AUP1G38
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
27.0
ns
3.6
9.5
19.5
3.2
21.8
24.0
ns
Max
Max
(85 C) (125 C)
CL = 30 pF
tpd
[2]
VCC = 0.8 V
2.9
7.0
11.5
2.6
13.6
15.0
ns
2.6
7.0
12.1
2.3
13.3
14.6
ns
2.4
5.4
8.9
2.1
9.9
10.9
ns
2.3
6.5
12.7
2.1
13.9
15.3
ns
VCC = 0.8 V
0.6
pF
0.7
pF
0.8
pF
0.9
pF
1.1
pF
1.4
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
power dissipation
capacitance
CPD
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPZL and tPLZ.
[3]
[3]
fi = 1 MHz;
VI = GND to VCC
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N where:
fi = input frequency in MHz;
VCC = supply voltage in V;
N = number of inputs switching.
74AUP1G38
Product data sheet
8 of 19
74AUP1G38
Nexperia
12. Waveforms
9,
$%LQSXW
90
*1'
W 3/=
W 3=/
9&&
很抱歉,暂时无法提供与“74AUP1G38GX,125”相匹配的价格&库存,您可以联系我们找货
