74AUP1G98
Low-power configurable multiple function gate
Rev. 8 — 23 September 2015
Product data sheet
1. General description
The 74AUP1G98 provides configurable multiple functions. The output state is determined
by eight patterns of 3-bit input. The user can choose the logic functions MUX, AND, OR,
NAND, NOR, inverter and buffer. All inputs can be connected to VCC or GND.
This device ensures a very low static and dynamic power consumption across the entire
VCC range from 0.8 V to 3.6 V.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
The 74AUP1G98 has Schmitt trigger inputs making it capable of transforming slowly
changing input signals into sharply defined, jitter-free output signals.
The inputs switch at different points for positive and negative-going signals. The difference
between the positive voltage VT+ and the negative voltage VT is defined as the input
hysteresis voltage VH.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
ESD protection:
HBM JESD22-A114F exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP1G98
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G98GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP1G98GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP1G98GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP1G98GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP1G98GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AUP1G98GX
40 C to +125 C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 0.8 0.35 mm
SOT1255
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AUP1G98GW
a9
74AUP1G98GM
a9
74AUP1G98GF
a9
74AUP1G98GN
a9
74AUP1G98GS
a9
74AUP1G98GX
a9
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Fig 1.
DDG
Logic diagram
74AUP1G98
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 24
74AUP1G98
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
*1'
9&&
*1'
9&&
DDG
7UDQVSDUHQWWRSYLHZ
DDG
Fig 2.
Pin configuration SOT363
Fig 3.
Pin configuration SOT886
$83*
$83*
*1'
9&&
*1'
DDG
DDD
7UDQVSDUHQWWRSYLHZ
Fig 4.
9&&
7UDQVSDUHQWWRSYLHZ
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 5.
Pin configuration SOT1255 (X2SON6)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
74AUP1G98
Product data sheet
3 of 24
74AUP1G98
Nexperia
7. Functional description
Table 4.
Function table[1]
Input
Output
C
B
A
Y
L
L
L
H
L
L
H
H
L
H
L
L
L
H
H
L
H
L
L
H
H
L
H
L
H
H
L
H
H
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
7.1 Logic configurations
Table 5.
Function selection table
Logic function
Figure
2-input MUX with inverted output
see Figure 6
2-input NAND
see Figure 7
2-input NOR with one input inverted
see Figure 8
2-input AND with one input inverted
see Figure 8
2-input NAND with one input inverted
see Figure 9
2-input OR with one input inverted
see Figure 9
2-input NOR
see Figure 10
Buffer
see Figure 11
Inverter
see Figure 12
9&&
9&&
DDG
Fig 6.
74AUP1G98
Product data sheet
DDG
Fig 7.
2-input NAND gate
4 of 24
74AUP1G98
Nexperia
9&&
9&&
DDG
DDG
Fig 8.
2-input AND gate with input A inverted or
2-input NOR gate with inverted C input
Fig 9.
2-input OR gate with input B inverted or
2-input NAND gate with input C inverted
9&&
9&&
DDG
DDG
Fig 10. 2-input NOR gate
Fig 11. Buffer
9&&
DDG
Fig 12. Inverter
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
VO
output voltage
Active mode and Power-down
mode
IO
output current
VO = 0 V to VCC
ICC
supply current
74AUP1G98
Product data sheet
[1]
Min
Max
Unit
0.5
+4.6
V
50
0.5
+4.6
50
0.5
+4.6
V
mA
50
mA
mA
V
mA
5 of 24
74AUP1G98
Nexperia
Table 6.
Limiting values …continued
Symbol
Parameter
IGND
ground current
Tstg
storage temperature
total power dissipation
Ptot
Conditions
Tamb = 40 C to +125 C
Min
Max
Unit
50
mA
65
+150
C
250
mW
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For X2SON6 and XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
ambient temperature
10. Static characteristics
Table 8.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
Tamb = 25 C
VOH
VOL
HIGH-level output voltage
LOW-level output voltage
74AUP1G98
Product data sheet
VI = VT+ or VT
IO = 1.1 mA; VCC = 1.1 V
0.75VCC
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
VI = VT+ or VT
0.1
V
0.3VCC
V
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
6 of 24
74AUP1G98
Nexperia
Table 8.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ
Max
Unit
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
1.1
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
VCC 0.1
V
0.7VCC
V
[1]
Tamb = 40 C to +85 C
VOH
VI = VT+ or VT
VOL
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
VI = VT+ or VT
II
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP1G98
Product data sheet
[1]
7 of 24
74AUP1G98
Nexperia
Table 8.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VOH
VI = VT+ or VT
VOL
VCC 0.11
V
0.6VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33VCC
V
0.41
V
VI = VT+ or VT
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
[1]
[1]
One input at VCC 0.6 V, other input at VCC or GND.
74AUP1G98
Product data sheet
8 of 24
74AUP1G98
Nexperia
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 14.
Symbol Parameter
Tamb = 25 C
Conditions
Tamb = 40 C to +125 C Unit
Min
Typ[1]
Max
Min
23.3
Max
Max
(85 C) (125 C)
CL = 5 pF
tpd
propagation delay
A, B, C to Y; see Figure 13
[2]
VCC = 0.8 V
ns
VCC = 1.1 V to 1.3 V
2.9
6.7
12.9
2.7
13.2
13.4
ns
VCC = 1.4 V to 1.6 V
2.4
4.8
7.7
2.4
8.3
8.7
ns
VCC = 1.65 V to 1.95 V
2.2
4.0
6.3
1.9
7.0
7.4
ns
VCC = 2.3 V to 2.7 V
2.0
3.2
4.6
1.8
5.2
5.4
ns
VCC = 3.0 V to 3.6 V
1.9
2.9
4.0
1.6
4.2
4.4
ns
27.1
ns
CL = 10 pF
tpd
propagation delay
[2]
VCC = 0.8 V
3.3
7.6
14.5
3.0
15.1
15.3
ns
2.7
5.4
8.8
2.8
9.5
9.9
ns
2.5
4.6
7.2
2.3
8.0
8.4
ns
2.4
3.8
5.3
2.2
5.9
6.2
ns
2.3
3.5
4.7
2.0
4.9
5.2
ns
30.6
ns
CL = 15 pF
tpd
propagation delay
VCC = 0.8 V
74AUP1G98
Product data sheet
[2]
3.6
8.4
16.1
3.3
16.9
17.2
ns
3.0
6.0
9.7
3.1
10.5
11.0
ns
2.8
5.1
7.9
2.5
8.9
9.3
ns
2.7
4.2
5.9
2.5
6.6
7.0
ns
2.5
3.9
5.2
2.2
5.5
5.8
ns
9 of 24
74AUP1G98
Nexperia
Table 9.
Dynamic characteristics …continued
Symbol Parameter
Tamb = 25 C
Conditions
Min
Typ[1]
Max
Min
38.7
ns
4.5
10.7
21.1
4.1
22.0
22.4
ns
Max
Max
(85 C) (125 C)
CL = 30 pF
propagation delay
tpd
[2]
VCC = 0.8 V
3.8
7.6
12.3
3.8
13.5
14.2
ns
3.5
6.3
10.1
3.1
11.3
11.9
ns
3.4
5.3
7.5
3.2
8.4
8.9
ns
3.2
5.0
6.7
2.9
7.1
7.5
ns
VCC = 0.8 V
2.7
pF
2.9
pF
3.0
pF
3.2
pF
3.8
pF
4.4
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
power dissipation
capacitance
CPD
fi = 1 MHz; VI = GND to VCC
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL
[3]
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
74AUP1G98
Product data sheet
10 of 24
74AUP1G98
Nexperia
12. Waveforms
9,
$%&LQSXW
90
90
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74AUP1G98GXZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.287881+0.42565
- 国内价格 香港价格
- 2238+1.424092238+0.18436
- 10000+1.2702910000+0.16445
- 100000+1.06467100000+0.13783
- 国内价格 香港价格
- 20+3.2878820+0.42565
