74AUP1T98
Low-power configurable gate with voltage-level translator
Rev. 5 — 5 October 2018
Product data sheet
1. General description
The 74AUP1T98 provides low-power, low-voltage configurable logic gate functions. The output
state is determined by eight patterns of 3-bit input. The user can choose the logic functions MUX,
AND, OR, NAND, NOR, inverter and buffer. All inputs can be connected to VCC or GND.
This device ensures a very low static and dynamic power consumption across the entire VCC range
from 2.3 V to 3.6 V.
The 74AUP1T98 is designed for logic-level translation applications with input switching levels that
accept 1.8 V low-voltage CMOS signals, while operating from either a single 2.5 V or 3.3 V supply
voltage.
The wide supply voltage range ensures normal operation as battery voltage drops from 3.6 V to
2.3 V.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
Schmitt trigger inputs make the circuit tolerant to slower input rise and fall times across the entire
VCC range.
2. Features and benefits
Wide supply voltage range from 2.3 V to 3.6 V
High noise immunity
ESD protection:
• HBM JESD22-A114F Class 3A exceeds 5000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 1.5 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP1T98
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AUP1T98GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP1T98GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 x 1.45 x 0.5 mm
74AUP1T98GF
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 x 1 x 0.5 mm
74AUP1T98GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 x 1.0 x 0.35 mm
SOT1115
74AUP1T98GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 x 1.0 x 0.35 mm
SOT1202
4. Marking
Table 2. Marking
Type number
Marking code
74AUP1T98GW
aR
74AUP1T98GM
aR
74AUP1T98GF
aR
74AUP1T98GN
aR
74AUP1T98GS
aR
5. Functional diagram
A
3
4
B
C
Fig. 1.
1
Y
6
001aad987
Logic symbol
74AUP1T98
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 19
74AUP1T98
Nexperia
6. Pinning information
6.1. Pinning
74AUP1T98
74AUP1T98
B
B
1
6
C
GND
2
5
VCC
A
3
4
6
2
5
VCC
A
3
4
Y
Y
B
1
6
C
GND
2
5
VCC
A
3
4
Y
001aah841
001aah840
Transparent top view
Pin configuration SOT363
74AUP1T98
C
GND
001aah839
Fig. 2.
1
Fig. 3.
Pin configuration SOT886
Fig. 4.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Output
Input
C
B
A
Y
L
L
L
H
L
L
H
H
L
H
L
L
L
H
H
L
H
L
L
H
H
L
H
L
H
H
L
H
H
H
H
L
74AUP1T98
Product data sheet
3 / 19
74AUP1T98
Nexperia
7.1. Logic configurations
Table 5. Function selection table
Logic function
Figure
2-input MUX (inverting)
see Fig. 5
2-input NAND
see Fig. 6
2-input NOR with one input inverted
see Fig. 7
2-input AND with one input inverted
see Fig. 7
2-input NAND with one input inverted
see Fig. 8
2-input OR with one input inverted
see Fig. 8
2-input NOR
see Fig. 9
Buffer
see Fig. 10
Inverter
see Fig. 11
VCC
B
Y
A
C
B
A
1
6
2
5
3
4
VCC
C
A
C
Y
Y
A
1
6
2
5
3
4
001aad991
Fig. 5.
C
Y
001aad992
Fig. 6.
2-input NAND gate
VCC
A
C
Y
A
C
Y
A
1
6
2
5
3
VCC
C
4
Y
B
C
Y
B
C
Y
B
1
6
2
5
3
4
001aad993
Fig. 7.
C
Y
001aad994
2-input AND gate with input A inverted or 2input NOR gate with input C inverted
Fig. 8.
2-input OR gate with input B inverted or 2-input
NAND gate with input C inverted
VCC
B
B
C
Y
1
6
2
5
3
4
VCC
C
C
Y
Y
1
6
2
5
3
4
001aad995
Fig. 9.
C
Y
001aad996
2-input NOR gate
Fig. 10. Buffer
VCC
B
B
Y
1
6
2
5
3
4
Y
001aad997
Fig. 11. Inverter
74AUP1T98
Product data sheet
4 / 19
74AUP1T98
Nexperia
8. Limiting values
Table 6. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+4.6
V
IIK
input clamping current
-50
VI
input voltage
IOK
output clamping current
VO < 0 V
-0.5
+4.6
-50
VO
output voltage
Active mode and Power-down mode
-0.5
+4.6
V
IO
output current
VO = 0 V to VCC
±20
mA
ICC
supply current
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
Conditions
VI < 0 V
[1]
Tamb = -40 °C to +125 °C
[1]
[2]
mA
V
mA
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SC-88 package: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 7. Recommended operating conditions
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
2.3
3.6
V
VI
input voltage
V
VO
output voltage
VCC
V
V
Tamb
ambient temperature
-40
+125
°C
Active mode
Power-down mode; VCC = 0 V
74AUP1T98
Product data sheet
5 / 19
74AUP1T98
Nexperia
10. Static characteristics
Table 8. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 °C
VT+
positive-going threshold
voltage
VCC = 2.3 V to 2.7 V
0.60
1.10
V
VCC = 3.0 V to 3.6 V
0.75
1.16
V
VT-
negative-going threshold
voltage
0.35
0.60
V
0.50
0.85
V
hysteresis voltage
(VH = VT+ - VT-)
0.23
0.60
V
0.25
0.56
V
VCC - 0.1
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 2.3 V to 3.6 V
0.10
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
VH
VOH
HIGH-level output voltage
VI = VT+ or VTIO = -20 μA; VCC = 2.3 V to 3.6 V
VOL
LOW-level output voltage
VI = VT+ or VT-
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.1
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
1.2
μA
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP1T98
Product data sheet
6 / 19
74AUP1T98
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
Tamb = -40 °C to +85 °C
VT+
voltage
0.60
1.10
V
0.75
1.19
V
VT-
voltage
0.35
0.60
V
0.50
0.85
V
hysteresis voltage
(VH = VT+ - VT-)
0.10
0.60
V
0.15
0.56
V
VCC - 0.1
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.33
V
0.45
V
0.33
V
0.45
V
VH
VOH
VOL
VI = VT+ or VT-
II
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.5
μA
ICC
supply current
1.5
μA
ΔICC
additional supply current
VCC = 2.3 V to 2.7 V; IO = 0 A
[1]
4
μA
VCC = 3.0 V to 3.6 V; IO = 0 A
[2]
12
μA
74AUP1T98
Product data sheet
7 / 19
74AUP1T98
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VT+
voltage
0.60
1.10
V
0.75
1.19
V
VT-
voltage
0.33
0.64
V
0.46
0.85
V
hysteresis voltage
(VH = VT+ - VT-)
0.10
0.60
V
0.15
0.56
V
VCC - 0.11
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.36
V
0.50
V
0.36
V
0.50
V
VH
VOH
VOL
VI = VT+ or VT-
II
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
3.5
μA
ΔICC
[1]
7
μA
[2]
22
μA
[1]
[2]
One input at 0.3 V or 1.1 V, other input at VCC or GND.
One input at 0.45 V or 1.2 V, other input at VCC or GND.
74AUP1T98
Product data sheet
8 / 19
74AUP1T98
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 13.
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
(85 °C)
Max
(125 °C)
CL = 5 pF
2.0
3.6
5.7
0.5
6.8
7.5
ns
CL = 10 pF
2.5
4.2
6.3
1.0
7.9
8.7
ns
CL = 15 pF
2.9
4.6
6.9
1.0
8.7
9.6
ns
CL = 30 pF
3.9
5.8
8.3
1.5
10.8
11.9
ns
CL = 5 pF
1.7
3.4
5.6
0.5
6.0
6.6
ns
CL = 10 pF
2.1
4.0
6.3
1.0
7.1
7.9
ns
CL = 15 pF
2.5
4.5
6.9
1.0
7.9
8.7
ns
CL = 30 pF
3.4
5.6
8.4
1.5
10.0
11.0
ns
CL = 5 pF
1.3
3.2
5.2
0.5
5.5
6.1
ns
CL = 10 pF
1.8
3.7
5.9
1.0
6.5
7.2
ns
CL = 15 pF
2.2
4.2
6.5
1.0
7.4
8.2
ns
CL = 30 pF
3.1
5.4
7.9
1.5
9.5
10.5
ns
CL = 5 pF
2.0
2.9
4.1
0.5
8.0
8.8
ns
CL = 10 pF
2.4
3.5
4.8
1.0
8.5
9.4
ns
CL = 15 pF
2.8
3.9
5.4
1.0
9.1
10.1
ns
CL = 30 pF
3.6
5.1
6.9
1.5
9.8
10.8
ns
CL = 5 pF
1.5
2.8
4.4
0.5
5.3
5.9
ns
CL = 10 pF
2.0
3.4
5.1
1.0
6.1
6.8
ns
CL = 15 pF
2.4
3.9
5.7
1.0
6.8
7.5
ns
CL = 30 pF
3.4
5.0
7.2
1.5
8.5
9.4
ns
CL = 5 pF
1.3
2.8
4.4
0.5
4.7
5.2
ns
CL = 10 pF
1.7
3.3
5.2
1.0
5.7
6.3
ns
CL = 15 pF
2.1
3.8
5.8
1.0
6.2
6.9
ns
CL = 30 pF
3.1
5.0
7.2
1.5
7.8
8.6
ns
VCC = 2.3 V to 2.7 V; VI = 1.65 V to 1.95 V
tpd
propagation delay A, B, C to Y; see Fig. 12
[2]
VCC = 2.3 V to 2.7 V; VI = 2.3 V to 2.7 V
tpd
[2]
VCC = 2.3 V to 2.7 V; VI = 3.0 V to 3.6 V
tpd
[2]
VCC = 3.0 V to 3.6 V; VI = 1.65 V to 1.95 V
tpd
[2]
VCC = 3.0 V to 3.6 V; VI = 2.3 V to 2.7 V
tpd
[2]
VCC = 3.0 V to 3.6 V; VI = 3.0 V to 3.6 V
tpd
74AUP1T98
Product data sheet
[2]
9 / 19
74AUP1T98
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
(85 °C)
Max
(125 °C)
3.6
pF
4.3
pF
Tamb = 25 °C
CPD
[1]
[2]
[3]
power dissipation
capacitance
fi = 1 MHz; VI = GND to VCC [3]
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of the outputs.
11.1. Waveforms and test circuits
VI
A, B, C input
VM
VM
GND
t PHL
t PLH
VOH
VM
Y output
VM
VOL
t PLH
t PHL
VOH
Y output
VM
VM
VOL
001aab593
Measurement points are given in Table 10.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 12. Input A, B and C to output Y propagation delay times
Table 10. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
2.3 V to 3.6 V
0.5 x VCC
0.5 x VI
1.65 V to 3.6 V
≤ 3.0 ns
74AUP1T98
Product data sheet
10 / 19
74AUP1T98
Nexperia
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 13. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VCC
CL
RL [1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
2.3 V to 3.6 V
5 pF, 10 pF, 15 pF and 30 pF
5 kΩ or 1 MΩ
open
GND
2 × VCC
[1]
VEXT
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1T98
Product data sheet
11 / 19
74AUP1T98
Nexperia
12. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig. 14. Package outline SOT363 (SC-88)
74AUP1T98
Product data sheet
12 / 19
74AUP1T98
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig. 15. Package outline SOT886 (XSON6)
74AUP1T98
Product data sheet
13 / 19
74AUP1T98
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
4
e1
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig. 16. Package outline SOT891 (XSON6)
74AUP1T98
Product data sheet
14 / 19
74AUP1T98
Nexperia
XSON6: extremely thin small outline package; no leads;
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig. 17. Package outline SOT1115 (XSON6)
74AUP1T98
Product data sheet
15 / 19
74AUP1T98
Nexperia
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 18. Package outline SOT1202 (XSON6)
74AUP1T98
Product data sheet
16 / 19
74AUP1T98
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP1T98 v.5
20181005
Product data sheet
74AUP1T98 v.4
Modifications:
74AUP1T98 v.4
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
20120815
Product data sheet
74AUP1T98 v.3
Package outline drawing of SOT886 (Fig. 15) modified.
74AUP1T98 v.3
20111130
Product data sheet
74AUP1T98 v.2
74AUP1T98 v.2
20101019
Product data sheet
74AUP1T98 v.1
74AUP1T98 v.1
20080306
Product data sheet
74AUP1T98
Product data sheet
17 / 19
74AUP1T98
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AUP1T98
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
18 / 19
74AUP1T98
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
7.1. Logic configurations.....................................................4
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................5
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................9
11.1. Waveforms and test circuits.....................................10
12. Package outline........................................................ 12
13. Abbreviations............................................................ 17
14. Revision history........................................................17
15. Legal information......................................................18
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 5 October 2018
74AUP1T98
Product data sheet
19 / 19
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP1T98GF,132 74AUP1T98GM,115 74AUP1T98GM,132 74AUP1T98GW,125 74AUP1T98GN,132
74AUP1T98GS,132
