74AUP2G04
Low-power dual inverter
Rev. 6 — 17 September 2015
Product data sheet
1. General description
The 74AUP2G04 provides two inverting buffers.
Schmitt trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F Class 3A exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP2G04
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP2G04GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP2G04GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP2G04GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP2G04GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP2G04GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AUP2G04GX
40 C to +125 C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 0.8 0.35 mm
SOT1255
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AUP2G04GW
p4
74AUP2G04GM
p4
74AUP2G04GF
p4
74AUP2G04GN
p4
74AUP2G04GS
p4
74AUP2G04GX
p4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Logic symbol
74AUP2G04
Product data sheet
PQE
PQE
Fig 1.
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 20
74AUP2G04
Nexperia
6. Pinning information
6.1 Pinning
$83*
$83*
很抱歉,暂时无法提供与“74AUP2G04GM,132”相匹配的价格&库存,您可以联系我们找货
