74AUP2G06
Low-power dual inverter with open-drain output
Rev. 6 — 15 March 2019
Product data sheet
1. General description
The 74AUP2G06 provides two inverting buffers with open-drain output. The output of the device
is an open drain and can be connected to other open-drain outputs to implement active-LOW
wired-OR or active-HIGH wired-AND functions.
Schmitt-trigger action at all inputs makes the circuit tolerant to slower input rise and fall times
across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire VCC range
This device is fully specified for partial Power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
• JESD8-12 (0.8 V to 1.3 V)
• JESD8-11 (0.9 V to 1.65 V)
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8-B (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F Class 3A. Exceeds 5000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78B Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
74AUP2G06
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AUP2G06GW
-40 °C to +125 °C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP2G06GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 x 1.45 x 0.5 mm
74AUP2G06GF
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 x 1 x 0.5 mm
74AUP2G06GN
-40 °C to +125 °C
XSON6
6 terminals; body 0.9 x 1.0 x 0.35 mm
SOT1115
74AUP2G06GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 x 1.0 x 0.35 mm
SOT1202
4. Marking
Table 2. Marking
Type number
Marking code[1]
74AUP2G06GW
p6
74AUP2G06GM
p6
74AUP2G06GF
p6
74AUP2G06GN
p6
74AUP2G06GS
p6
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
1A
1Y
6
1A
1
6
1Y
Y
3
2A
2Y
4
2A
3
4
2Y
A
GND
mnb095
Fig. 1.
Logic symbol
74AUP2G06
Product data sheet
mna620
mnb096
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig. 3.
Logic diagram (one driver)
Nexperia B.V. 2019. All rights reserved
2 / 16
74AUP2G06
Nexperia
6. Pinning information
6.1. Pinning
74AUP2G06
74AUP2G06
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
001aal426
Transparent top view
001aal424
Fig. 4.
1A
Fig. 5.
Pin configuration SOT363 (SC-88)
Pin configuration SOT886, SOT891, SOT1115
and SOT1202 (XSON6)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A
1, 3
data input
GND
2
ground (0 V)
1Y, 2Y
6, 4
data output
VCC
5
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
Input nA
Output nY
L
Z
H
L
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
IIK
input clamping current
-0.5
+4.6
V
-50
VI
input voltage
-0.5
+4.6
IOK
output clamping current
VO < 0 V
-50
VO
output voltage
Active mode and Power-down mode
-0.5
+4.6
V
IO
output current
VO = 0 V to VCC
ICC
supply current
+20
mA
+50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
74AUP2G06
Product data sheet
Conditions
VI < 0 V
[1]
[1]
mA
V
mA
3 / 16
74AUP2G06
Nexperia
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[1]
[2]
Min
Max
Unit
250
mW
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SC-88 package: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.8
3.6
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
ns/V
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
VCC = 0.8 V to 3.6 V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.70 × VCC
V
VCC = 0.9 V to 1.95 V
0.65 × VCC
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 × VCC V
0.35 × VCC V
0.7
V
0.9
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VIH
VIL
VOL
HIGH-level input voltage
LOW-level input voltage
LOW-level output voltage
VI = VIH or VIL
0.3 × VCC V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOZ
OFF-state output current
VI = VIL; VO = 0 V to 3.6 V;
VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
74AUP2G06
Product data sheet
4 / 16
74AUP2G06
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
ΔICC
CI
additional supply current
VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V
40
μA
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
output enabled; VO = GND; VCC = 0 V
1.7
pF
output disabled; VO = GND; VCC = 0 V
1.1
pF
VCC = 0.8 V
0.70 × VCC
V
0.65 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 × VCC V
0.35 × VCC V
0.7
V
0.9
V
0.1
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
Tamb = -40 °C to +85 °C
VIH
VIL
VOL
VI = VIH or VIL
0.3 × VCC V
II
±0.5
μA
IOZ
VCC = 0 V to 3.6 V
±0.5
μA
IOFF
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
50
μA
74AUP2G06
Product data sheet
5 / 16
74AUP2G06
Nexperia
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC = 0.8 V
0.75 × VCC
V
0.70 × VCC
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 × VCC V
0.30 × VCC V
0.7
V
0.9
V
0.11
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
VIH
VIL
VOL
VI = VIH or VIL
0.33 × VCC V
0.50
V
II
±0.75
μA
IOZ
VCC = 0 V to 3.6 V
±0.75
μA
IOFF
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
75
μA
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7.
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
Max
(85 °C) (125 °C)
12.8
ns
VCC = 1.1 V to 1.3 V
2.3
4.3
9.9
2.0
10.9
12.0
ns
VCC = 1.4 V to 1.6 V
1.8
3.1
6.1
1.5
7.1
7.8
ns
VCC = 1.65 V to 1.95 V
1.5
2.8
4.7
1.2
5.7
6.3
ns
1.2
2.2
3.2
1.0
3.9
4.3
ns
1.1
2.2
3.3
0.8
3.6
4.0
ns
CL = 5 pF
tpd
propagation delay nA to nY; see Fig. 6
[2]
VCC = 0.8 V
74AUP2G06
Product data sheet
6 / 16
74AUP2G06
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
Max
(85 °C) (125 °C)
15.8
ns
2.7
5.4
11.2
2.5
13.2
15.0
ns
2.2
3.9
7.0
2.0
8.5
9.4
ns
1.9
3.6
5.4
1.7
6.7
7.4
ns
1.7
2.9
3.8
1.4
4.5
5.0
ns
1.6
3.2
4.6
1.2
4.9
5.4
ns
CL = 10 pF
tpd
[2]
VCC = 0.8 V
CL = 15 pF
tpd
[2]
VCC = 0.8 V
18.8
ns
3.2
6.4
12.2
2.9
15.2
17.0
ns
2.6
4.6
7.7
2.3
9.4
10.0
ns
2.3
4.5
6.6
2.1
7.3
8.1
ns
2.1
3.5
4.6
1.7
5.1
5.7
ns
2.0
4.0
6.0
1.5
6.5
7.2
ns
27.8
ns
4.4
9.3
16.5
3.9
19.3
21.3
ns
3.6
6.8
10.1
3.2
12.0
13.2
ns
3.2
6.8
10.7
2.9
11.0
12.1
ns
2.9
5.3
7.2
2.6
7.8
8.6
ns
2.9
6.5
10.5
2.5
10.8
11.9
ns
VCC = 0.8 V
0.5
pF
0.6
pF
0.7
pF
0.7
pF
1.0
pF
1.2
pF
CL = 30 pF
tpd
[2]
VCC = 0.8 V
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
[1]
[2]
[3]
power dissipation
capacitance
fi = 1 MHz; VI = GND to VCC
[3]
All typical values are measured at nominal VCC.
tpd is the same as tPZL and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
PD = CPD × VCC × fi × N where:
fi = input frequency in MHz;
VCC = supply voltage in V;
N = number of inputs switching.
74AUP2G06
Product data sheet
7 / 16
74AUP2G06
Nexperia
11.1. Waveform and test circuit
VI
VM
nA input
GND
t PZL
t PLZ
VCC
nY output
VM
VX
VOL
mnb033
Measurement points are given in Table 9.
Logic level: VOL is the typical output voltage level that occurs at the output load.
Fig. 6.
The data input (nA) to output (nY) propagation delays
Table 9. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
0.8 V to 1.6 V
0.5 x VCC
0.5 x VCC
VOL + 0.1 V
1.65 V to 2.7 V
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
3.0 V to 3.6 V
0.5 x VCC
0.5 x VCC
VOL + 0.3 V
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Supply voltage Load
VEXT
VCC
CL
RL[1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
0.8 V to 3.6 V
5 kΩ or 1 MΩ
open
GND
2 x VCC
[1]
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP2G06
Product data sheet
8 / 16
74AUP2G06
Nexperia
12. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
B
E
y
A
X
HE
6
5
v M A
4
Q
pin 1
index
A
1
2
e1
A1
3
bp
c
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
Fig. 8.
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Package outline SOT363 (SC-88)
74AUP2G06
Product data sheet
9 / 16
74AUP2G06
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
Fig. 9.
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Package outline SOT886 (XSON6)
74AUP2G06
Product data sheet
10 / 16
74AUP2G06
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig. 10. Package outline SOT891 (XSON6)
74AUP2G06
Product data sheet
11 / 16
74AUP2G06
Nexperia
XSON6: extremely thin small outline package; no leads;
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig. 11. Package outline SOT1115 (XSON6)
74AUP2G06
Product data sheet
12 / 16
74AUP2G06
Nexperia
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 12. Package outline SOT1202 (XSON6)
74AUP2G06
Product data sheet
13 / 16
74AUP2G06
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AUP2G06 v.6
20190315
Product data sheet
74AUP2G06 v.5
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74AUP2G06 v.5
20121129
Modifications:
74AUP2G06 v.4
20111206
Product data sheet
74AUP2G06 v.3
74AUP2G06 v.3
20101026
Product data sheet
74AUP2G06 v.2
74AUP2G06 v.2
20100325
Product data sheet
74AUP2G06 v.1
74AUP2G06 v.1
20100211
Product data sheet
74AUP2G06
Product data sheet
Product data sheet
74AUP2G06 v.4
Package outline drawing of SOT886 (Fig. 9) modified.
14 / 16
74AUP2G06
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AUP2G06
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74AUP2G06
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................6
11.1. Waveform and test circuit.......................................... 8
12. Package outline.......................................................... 9
13. Abbreviations............................................................ 14
14. Revision history........................................................14
15. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 March 2019
74AUP2G06
Product data sheet
16 / 16
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP2G06GN,132 74AUP2G06GF,132 74AUP2G06GM,115 74AUP2G06GM,132 74AUP2G06GW,125
74AUP2G06GS,132
