74AUP2G14GW,125
74AUP2G14GW,125
    NEXPERIA(安世)
    TSSOP6_2.2X1.35MM
    IC INVERT SCHMITT 2CH 2IN 6TSSOP
74AUP2G14GW,125 数据手册
74AUP2G14 Low-power dual Schmitt trigger inverter Rev. 6 — 17 September 2015 Product data sheet 1. General description The 74AUP2G14 provides two inverting buffers with Schmitt trigger action which accept standard input signals. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Applications  Wave and pulse shaper  Astable multivibrator  Monostable multivibrator 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP2G14GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP2G14GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP2G14GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP2G14GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP2G14GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AUP2G14GX 40 C to +125 C X2SON6 plastic thermal extremely thin small outline package; no leads; 6 terminals; body 1  0.8  0.35 mm SOT1255 5. Marking Table 2. Marking Type number Marking code[1] 74AUP2G14GW pK 74AUP2G14GM pK 74AUP2G14GF pK 74AUP2G14GN pK 74AUP2G14GS pK 74AUP2G14GX pK [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram   $ $ < <   Logic symbol 74AUP2G14 Product data sheet  $ <   $ < PQE PQE PQE Fig 1.  Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter 7. Pinning information 7.1 Pinning $83* $83* $   *1'   9&& $   < < $   < *1'   9&& $   < DDG 7UDQVSDUHQWWRSYLHZ DDG Fig 4. Pin configuration SOT363 Fig 5. Pin configuration SOT886 $83* $83* $  $   < *1'   9&& $   < *1' <    $ DDG  < DDD 7UDQVSDUHQWWRSYLHZ Fig 6. 9&&  7UDQVSDUHQWWRSYLHZ Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1255 (X2SON6) 7.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 74AUP2G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 3 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter 8. Functional description Table 4. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC [1] Min Max Unit 0.5 +4.6 V 50 - 0.5 +4.6 50 - 0.5 +4.6 V - 20 mA mA V mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For X2SON6 and XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb Conditions Min Max Unit 0.8 3.6 V 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C ambient temperature 74AUP2G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 4 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter 11. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V Tamb = 25 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT 0.3  VCC V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VI = GND or VCC; VCC = 0 V to 3.6 V - 1.1 - pF CO output capacitance VO = GND; VCC = 0 V - 1.7 - pF IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V Tamb = 40 C to +85 C VOH HIGH-level output voltage 74AUP2G14 Product data sheet VI = VT+ or VT IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 5 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VT+ or VT LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V 0.3  VCC V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V - - 0.5 A II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V VI or VO = 0 V to 3.6 V; VCC = 0 V IOFF power-off leakage current - - 0.5 A IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V Tamb = 40 C to +125 C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VT VI = VT+ or VT 0.33  VCC V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A 74AUP2G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 6 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IOFF additional power-off leakage VI or VO = 0 V to 3.6 V; current VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A 12. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 19.9 - - - - ns VCC = 1.1 V to 1.3 V 2.7 5.9 11.0 2.4 11.1 11.2 ns VCC = 1.4 V to 1.6 V 2.6 4.3 6.6 2.4 7.1 7.4 ns VCC = 1.65 V to 1.95 V 2.1 3.7 5.4 2.0 6.0 6.2 ns VCC = 2.3 V to 2.7 V 2.0 3.0 4.1 1.7 4.5 4.7 ns VCC = 3.0 V to 3.6 V 1.9 2.8 3.6 1.5 3.9 4.0 ns - 23.4 - - - - ns VCC = 1.1 V to 1.3 V 2.9 6.8 12.7 2.8 12.8 12.9 ns VCC = 1.4 V to 1.6 V 2.8 5.0 7.7 2.6 8.2 8.6 ns VCC = 1.65 V to 1.95 V 2.7 4.2 6.2 2.5 6.7 7.1 ns VCC = 2.3 V to 2.7 V 2.3 3.6 4.8 2.1 5.2 5.5 ns VCC = 3.0 V to 3.6 V 2.1 3.3 4.3 2.0 4.5 4.7 ns - 26.9 - - - - ns VCC = 1.1 V to 1.3 V 3.3 7.6 14.3 3.0 14.5 14.7 ns VCC = 1.4 V to 1.6 V 3.3 5.5 8.6 2.9 9.4 9.8 ns VCC = 1.65 V to 1.95 V 2.8 4.7 7.0 2.8 7.7 8.1 ns VCC = 2.3 V to 2.7 V 2.7 4.0 5.5 2.4 5.9 6.2 ns VCC = 3.0 V to 3.6 V 2.6 3.8 4.8 2.2 5.2 5.4 ns CL = 5 pF tpd propagation delay nA to nY; see Figure 8 [2] VCC = 0.8 V CL = 10 pF tpd propagation delay nA to nY; see Figure 8 [2] VCC = 0.8 V CL = 15 pF tpd propagation delay nA to nY; see Figure 8 VCC = 0.8 V 74AUP2G14 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 7 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max (85 C) Max (125 C) - 37.3 - - - - ns 4.0 9.8 18.7 3.9 19.6 20.0 ns CL = 30 pF propagation delay nA to nY; see Figure 8 tpd [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 3.7 7.1 11.2 3.8 12.3 12.9 ns VCC = 1.65 V to 1.95 V 3.6 6.0 9.1 3.6 10.0 10.6 ns VCC = 2.3 V to 2.7 V 3.5 5.2 6.9 3.2 7.5 7.9 ns VCC = 3.0 V to 3.6 V 3.3 4.8 6.1 3.1 7.1 7.4 ns VCC = 0.8 V - 2.6 - - - - pF VCC = 1.1 V to 1.3 V - 2.7 - - - - pF VCC = 1.4 V to 1.6 V - 2.9 - - - - pF VCC = 1.65 V to 1.95 V - 3.1 - - - - pF VCC = 2.3 V to 2.7 V - 3.7 - - - - pF VCC = 3.0 V to 3.6 V - 4.3 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [3][4] [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] All specified values are the average typical values over all stated loads. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AUP2G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 17 September 2015 © Nexperia B.V. 2017. All rights reserved 8 of 23 74AUP2G14 Nexperia Low-power dual Schmitt trigger inverter 13. Waveforms 9, 90 Q$LQSXW 90 *1' W 3+/ W 3/+ 92+ 90 Q
74AUP2G14GW,125 价格&库存
很抱歉,暂时无法提供与“74AUP2G14GW,125”相匹配的价格&库存,您可以联系我们找货
