74AXP1G06GSH
74AXP1G06GSH
    NEXPERIA(安世)
    XSON6_1X1MM
    IC INVERTER OD 1CH 1-INP 6XSON
74AXP1G06GSH 数据手册
74AXP1G06 Low-power inverter with open-drain output Rev. 1 — 15 January 2014 Product data sheet 1. General description The 74AXP1G06 is a single inverter with open-drain output. Schmitt-trigger action at the input makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 0.7 pF (typical) Low dynamic power consumption; CPD = 1.0 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Input accepts voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP1G06 Nexperia Low-power inverter with open-drain output 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP1G06GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP1G06GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP1G06GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AXP1G06GX 40 C to +85 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74AXP1G06GM rR 74AXP1G06GN rR 74AXP1G06GS rR 74AXP1G06GX rR [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram Y 2 A Y 4 A 2 4 Y A GND Fig 1. Logic symbol 74AXP1G06 Product data sheet mna620 mna619 mna618 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 January 2014 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 17 74AXP1G06 Nexperia Low-power inverter with open-drain output 6. Pinning information 6.1 Pinning $;3* $;3* QF   9&& QF $   QF *1'   <  9&&  <  *1' $ DDD  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 4.  Pin configuration SOT886, SOT1115 and SOT1202 (XSON6) Fig 5. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description X2SON5 XSON6 n.c. 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input Output A Y L Z H L [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 74AXP1G06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 January 2014 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AXP1G06 Nexperia Low-power inverter with open-drain output 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - mA 0.5 +3.3 V 50 - mA 0.5 +3.3 V VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions Min Max Unit supply voltage 0.7 2.75 V VI input voltage 0 2.75 V VO output voltage Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C 0 200 ns/V Tamb ambient temperature t/V input transition rise and fall rate 74AXP1G06 Product data sheet VCC = 0.7 V to 2.75 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 January 2014 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AXP1G06 Nexperia Low-power inverter with open-drain output 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min HIGH-level input voltage VIH LOW-level input voltage VIL LOW-level output voltage VOL Unit Typ 25 C Max 25 C Max 85 C VCC = 0.75 V to 0.85 V 0.75VCC - - - V VCC = 1.1 V to 1.95 V 0.65VCC - - - V VCC = 2.3 V to 2.7 V 1.6 - - - V VCC = 0.75 V to 0.85 V - - 0.25VCC 0.25VCC V VCC = 1.1 V to 1.95 V - - 0.35VCC 0.35VCC V VCC = 2.3 V to 2.7 V - - 0.7 0.7 V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V - 0.001 0.1 0.5 A II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] IOZ OFF-state output current VI = VIL; VO = 0 V to 2.75 V [1] - 0.02 0.1 0.5 A IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off VI or VO = 0 V or 2.75 V; leakage current VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply current VI = VCC  0.5 V; IO = 0 A; VCC = 2.5 V - 2 100 150 A [1] All typical values are measured at VCC = 1.2 V. 74AXP1G06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 January 2014 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AXP1G06 Nexperia Low-power inverter with open-drain output 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 12. Symbol Parameter propagation delay tpd Tamb = 25 C Conditions Tamb = 40 C to +85 C Unit Min Typ[1] Max Min Max 3 12 33 3 104 ns VCC = 1.1 V to 1.3 V 2.2 5.1 7.9 2.0 8.3 ns VCC = 1.4 V to 1.6 V 1.7 3.7 5.2 1.5 5.6 ns VCC = 1.65 V to 1.95 V 1.4 3.5 5.3 1.2 5.6 ns VCC = 2.3 V to 2.7 V 1.2 2.6 3.8 1.0 4.0 ns - - - 0.9 - ns [2][3] A to Y; see Figure 6 VCC = 0.75 V to 0.85 V VCC = 2.7 V; see Figure 6 [4] tt transition time CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance - 0.7 - - - pF CPD power dissipation fi = 1 MHz; VI = 0 V to VCC capacitance VCC = 0.75 V to 0.85 V VO = 0 V; VCC = 0 V [5] - 0.9 - - - pF VCC = 1.1 V to 1.3 V - 1.0 - - - pF VCC = 1.4 V to 1.6 V - 1.0 - - - pF VCC = 1.65 V to 1.95 V - 1.1 - - - pF VCC = 2.3 V to 2.7 V - 1.3 - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPZL and tPLZ. [3] For additional propagation delay (tPZL) values at different load capacitances see Figure 7 to Figure 11. [4] tt is the same as tTZL and tTLZ. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V. 74AXP1G06 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 January 2014 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AXP1G06 Nexperia Low-power inverter with open-drain output 12. Waveforms 9, 90 $LQSXW *1' W3=/ W3/= 9&&
74AXP1G06GSH 价格&库存
很抱歉,暂时无法提供与“74AXP1G06GSH”相匹配的价格&库存,您可以联系我们找货
