74AXP1G14GMH
74AXP1G14GMH
    NEXPERIA(安世)
    XSON6_1.45x1MM
    IC INVERT SCHMITT 1CH 1-IN 6XSON
74AXP1G14GMH 数据手册
74AXP1G14 Low-power Schmitt trigger inverter Rev. 1 — 28 August 2014 Product data sheet 1. General description The 74AXP1G14 is a single inverter with Schmitt trigger input. It transforms slowly changing input signals into sharply defined, jitter-free output signals. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 1.0 pF (typical) Low dynamic power consumption; CPD = 2.4 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP1G14GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP1G14GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP1G14GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AXP1G14GX 40 C to +85 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Type number Marking code[1] 74AXP1G14GM rF 74AXP1G14GN rF 74AXP1G14GS rF 74AXP1G14GX rF [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 2 A Y 4 2 mna023 Fig 1. Logic symbol 74AXP1G14 Product data sheet 4 $ < PQD mna024 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 6. Pinning information 6.1 Pinning 74AXP1G14 74AXP1G14 n.c. 1 6 VCC n.c. A 2 5 n.c. GND 3 4 Y 5 VCC 4 Y 3 GND A aaa-014791 2 aaa-014792 Transparent top view Fig 4. 1 Transparent top view Pin configuration SOT886, SOT1115 and SOT1202 (XSON6) Fig 5. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description X2SON5 XSON6 n.c. 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input Output A Y L H H L [1] H = HIGH voltage level; L = LOW voltage level. 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 3 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - mA 0.5 +3.3 V 50 - mA 0.5 +3.3 V VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Min Max Unit supply voltage 0.7 2.75 V VI input voltage 0 2.75 V VO output voltage Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C Tamb Conditions ambient temperature 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 4 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min Typ 25 C 0.3VCC - 0.8VCC 0.8VCC V VCC = 1.1 V to 1.95 V 0.4VCC - 0.7VCC 0.7VCC V VCC = 2.3 V to 2.7 V 0.9 - 1.7 1.7 V 0.2VCC - 0.7VCC 0.7VCC V VCC = 1.1 V to 1.95 V 0.3VCC - 0.6VCC 0.6VCC V VCC = 2.3 V to 2.7 V 0.7 - 1.5 1.5 V VCC = 0.75 V to 0.85 V 0.06VCC - 0.5VCC 0.5VCC V VCC = 1.1 V to 1.95 V 0.1VCC - 0.4VCC 0.4VCC V VCC = 2.3 V to 2.7 V 0.2 - 1.0 1.0 V positive-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT+ negative-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT hysteresis voltage VH VOH HIGH-level output voltage LOW-level output voltage VOL Unit Max 25 C Max 85 C see Figure 6 and Figure 7 IO = 20 A; VCC = 0.7 V - 0.69 - - V IO = 100 A; VCC = 0.75 V 0.65 - - - V IO = 2 mA; VCC = 1.1 V 0.825 - - - V IO = 3 mA; VCC = 1.4 V 1.05 - - - V IO = 4.5 mA; VCC = 1.65 V 1.2 - - - V IO = 8 mA; VCC = 2.3 V 1.7 - - - V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V - 0.001 0.1 0.5 A II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off leakage current VI or VO = 0 V or 2.75 V; VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply VI = VCC  0.5 V; IO = 0 A; current VCC = 2.5 V - 2 100 150 A [1] Typical values are measured at VCC = 1.2 V. 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 5 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 10.1 Waveform transfer characteristics 92 97 9, 9+ 97 9, 9+ 97 Fig 6. 97 92 PQD PQD Transfer characteristic Fig 7. Definition of VT+, VT, and VH 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14. Symbol Parameter propagation delay tpd Tamb = 25 C Conditions Tamb = 40 C to +85 C Unit Min Typ[1] Max Min Max 3 12 35 2 114 ns VCC = 1.1 V to 1.3 V 2.0 4.6 7.2 1.8 7.5 ns VCC = 1.4 V to 1.6 V 1.6 3.5 5.0 1.4 5.3 ns VCC = 1.65 V to 1.95 V 1.4 2.9 4.1 1.2 4.5 ns VCC = 2.3 V to 2.7 V 1.2 2.3 3.2 1.0 3.5 ns - - - 1.0 - ns A to Y; see Figure 8 [2][3] VCC = 0.75 V to 0.85 V [4] tt transition time VCC = 2.7 V; see Figure 8 CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance VO = 0 V; VCC = 0 V - 1.0 - - - pF CPD power dissipation capacitance fi = 1 MHz; VI = 0 V to VCC VCC = 0.75 V to 0.85 V - 2.3 - - - pF [1] [5] VCC = 1.1 V to 1.3 V - 2.4 - - - pF VCC = 1.4 V to 1.6 V - 2.5 - - - pF VCC = 1.65 V to 1.95 V - 2.6 - - - pF VCC = 2.3 V to 2.7 V - 3.0 - - - pF All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] For additional propagation delay values at different load capacitances, see Figure 9 to Figure 13. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 6 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter N = number of inputs switching. 12. Waveforms VI A input VM VM GND tPLH VOH tPHL 90 % Y output 90 % VM VOL VM 10 % 10 % tTLH tTHL aaa-014793 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. The data input (A) to output (Y) propagation delays Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM 0.75 V to 2.7 V 0.5VCC VCC  3.0 ns 0.5VCC DDD  ǻW QV DDD   ǻW QV                     &/ S)  Tamb = 40 C to +85 C unless otherwise specified.         &/ S) Tamb = 40 C to +85 C unless otherwise specified. (1) Minimum: VCC = 2.7 V (1) Minimum: VCC = 1.95 V (2) Typical: Tamb = 25 C; VCC = 2.5 V (2) Typical: Tamb = 25 C; VCC = 1.8 V (3) Maximum: VCC = 2.3 V (3) Maximum: VCC = 1.65 V Fig 9. Additional tpd versus load capacitance 74AXP1G14 Product data sheet  Fig 10. Additional tpd versus load capacitance All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 7 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter DDD   ǻWW QV DDD  ǻW QV                       &/ S)   Tamb = 40 C to +85 C unless otherwise specified.        &/ S)  Tamb = 40 C to +85 C unless otherwise specified. (1) Minimum: VCC = 1.6 V (1) Minimum: VCC = 1.3 V (2) Typical: Tamb = 25 C; VCC = 1.5 V (2) Typical: Tamb = 25 C; VCC = 1.2 V (3) Maximum: VCC = 1.4 V (3) Maximum: VCC = 1.1 V Fig 11. Additional tpd versus load capacitance Fig 12. Additional tpd versus load capacitance DDD  ǻW QV               &/ S)  Tamb = 40 C to +85 C unless otherwise specified. (1) Minimum: VCC = 0.85 V (2) Typical: Tamb = 25 C; VCC = 0.8 V (3) Maximum: VCC = 0.75 V Fig 13. Additional tpd versus load capacitance 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 8 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 9(;7 9&& * 9, 5/ 92 '87 57 &/ 5/ PQD Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 14. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 0.75 V to 2.7 V 5 pF 10 k 0V 0V 2  VCC 74AXP1G14 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 9 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 13. Package outline 627 ;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP E    [  / / H   H  H [ $  $ ' ( WHUPLQDO LQGH[DUHD   PP VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW PP PD[ QRP PLQ $   $ E ' (           H H   / /       1RWHV ,QFOXGLQJSODWLQJWKLFNQHVV &DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV 2XWOLQH YHUVLRQ 627 VRWBSR 5HIHUHQFHV ,(& -('(& -(,7$ (XURSHDQ SURMHFWLRQ ,VVXHGDWH   02 Fig 15. Package outline SOT886 (XSON6) 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 10 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW PP PP $  $ E ' ( H H PD[      QRP     PLQ     / /       1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 16. Package outline SOT1115 (XSON6) 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 11 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter ;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP  627 E   î  / / H    H H î  $ $ ' ( WHUPLQDO LQGH[DUHD   VFDOH 'LPHQVLRQV 8QLW PP PP $  $ E ' ( H H / / PD[        QRP        PLQ      1RWH ,QFOXGLQJSODWLQJWKLFNQHVV 9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\ VRWBSR 5HIHUHQFHV 2XWOLQH YHUVLRQ ,(& -('(& -(,7$ 627    (XURSHDQ SURMHFWLRQ ,VVXHGDWH   Fig 17. Package outline SOT1202 (XSON6) 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 12 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter ;621SODVWLFWKHUPDOHQKDQFHGH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV WHUPLQDOVERG\[[PP ' $ % 627 ; $ ( $ $ GHWDLO; WHUPLQDO LQGH[DUHD H & Y Z E   WHUPLQDO LQGH[DUHD & $ % & \ & \ N ' K  /    PP VFDOH 'LPHQVLRQV 8QLW PP $  $ $ ' 'K ( E H N /  PD[              QRP PLQ        Y  Z \ \    1RWH 'LPHQVLRQ$LVLQFOXGLQJSODWLQJWKLFNQHVV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 2XWOLQH YHUVLRQ 5HIHUHQFHV ,(& -('(& (,$- VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   627 Fig 18. Package outline SOT1226 (X2SON5) 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 13 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 14. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AXP1G14 v.1 20140828 Product data sheet - - 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 14 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AXP1G14 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 15 of 17 74AXP1G14 Nexperia Low-power Schmitt trigger inverter Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AXP1G14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 28 August 2014 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74AXP1G14 Low-power Schmitt trigger inverter 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 10.1 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Waveform transfer characteristics . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 August 2014 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AXP1G14GMH 74AXP1G14GXH 74AXP1G14GSH 74AXP1G14GNH
74AXP1G14GMH 价格&库存
很抱歉,暂时无法提供与“74AXP1G14GMH”相匹配的价格&库存,您可以联系我们找货
