74AXP1G97
Low-power configurable multiple function gate
Rev. 2 — 16 September 2015
Product data sheet
1. General description
The 74AXP1G97 is a configurable multiple function gate with Schmitt-trigger inputs. The
device can be configured as any of the following logic functions MUX, AND, OR, NAND,
NOR, inverter and buffer. All inputs can be connected directly to VCC or GND.
This device ensures very low static and dynamic power consumption across the entire
VCC range from 0.7 V to 2.75 V. This device is fully specified for partial power down
applications using IOFF. The IOFF circuitry disables the output, preventing the potentially
damaging backflow current through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.7 V to 2.75 V
Low input capacitance; CI = 0.5 pF (typical)
Low output capacitance; CO = 1.0 pF (typical)
Low dynamic power consumption; CPD = 2.6 pF at VCC = 1.2 V (typical)
Low static power consumption; ICC = 0.6 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 2.75 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C
74AXP1G97
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP1G97GM
40 C to +85 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AXP1G97GN
40 C to +85 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AXP1G97GS
40 C to +85 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74AXP1G97GX
40 C to +85 C
X2SON6
plastic thermal extremely thin small outline package;
no leads; 6 terminals; body 1 0.8 0.35 mm
SOT1255
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AXP1G97GM
RV
74AXP1G97GN
RV
74AXP1G97GS
RV
74AXP1G97GX
RV
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Fig 1.
DDG
Logic symbol
74AXP1G97
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
74AXP1G97
Nexperia
6. Pinning information
6.1 Pinning
$;3*
$;3*
$;3*
*1'
9&&
*1'
9&&
*1'
DDD
Pin configuration SOT886
DDD
Fig 3.
Pin configuration SOT1115
and SOT1202
9&&
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 2.
Fig 4.
Pin configuration SOT1255
(X2SON6)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
GND
2
ground (0 V)
A
3
data input
Y
4
data output
VCC
5
supply voltage
C
6
data input
7. Functional description
Table 4.
Function table[1]
Input
Output
C
B
A
Y
L
L
L
L
L
L
H
L
L
H
L
H
L
H
H
H
H
L
L
L
H
L
H
H
H
H
L
L
H
H
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level.
74AXP1G97
Product data sheet
3 of 18
74AXP1G97
Nexperia
7.1 Logic configurations
Table 5.
Function selection table
Logic function
Figure
2-input MUX
see Figure 5
2-input AND
see Figure 6
2-input OR with one input inverted
see Figure 7
2-input NAND with one input inverted
see Figure 7
2-input AND with one input inverted
see Figure 8
2-input NOR with one input inverted
see Figure 8
2-input OR
see Figure 9
Inverter
see Figure 10
Buffer
see Figure 11
9&&
9&&
DDH
DDH
Fig 5.
2-input MUX
Fig 6.
2-input AND gate
9&&
9&&
DDH
Fig 7.
2-input NAND gate with input A inverted or
2-input OR gate with input C inverted
DDH
Fig 8.
2-input NOR gate with input B inverted or
2-input AND gate with input C inverted
9&&
9&&
2-input OR gate
74AXP1G97
Product data sheet
DDH
DDH
Fig 9.
Fig 10. Inverter
4 of 18
74AXP1G97
Nexperia
9&&
DDH
Fig 11. Buffer
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
Min
Max
Unit
0.5
3.3
V
50
[1]
0.5
3.3
50
[1]
0.5
3.3
V
mA
50
mA
VI < 0 V
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
supply current
VO < 0 V
VO = 0 V to VCC
mA
V
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
[1]
Tamb = 40 C to +85 C
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
Conditions
Product data sheet
Max
Unit
0.7
2.75
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+85
C
ambient temperature
74AXP1G97
Min
5 of 18
74AXP1G97
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol
VT+
Parameter
Conditions
Min
Typ 25 C
Max
25 C
Max 85 C
0.3VCC
0.8VCC
0.8VCC
V
VCC = 1.1 V to 1.95 V
0.4VCC
0.7VCC
0.7VCC
V
VCC = 2.3 V to 2.7 V
0.9
1.7
1.7
V
0.2VCC
0.7VCC
0.7VCC
V
0.3VCC
0.6VCC
0.6VCC
V
0.7
1.5
1.5
V
VCC = 0.75 V to 0.85 V
0.06VCC
0.5VCC
0.5VCC
V
0.1VCC
0.4VCC
0.4VCC
V
0.2
1.0
1.0
V
0.69
V
IO = 100 A; VCC = 0.75 V
0.65
V
IO = 2 mA; VCC = 1.1 V
0.825
V
positive-going
see Figure 12 and Figure 13
threshold voltage
negative-going
threshold voltage
VT
hysteresis
voltage
VH
VOH
HIGH-level
output voltage
LOW-level
output voltage
VOL
Unit
IO = 20 A; VCC = 0.7 V
IO = 3 mA; VCC = 1.4 V
1.05
V
IO = 4.5 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.7
V
0.01
V
0.1
0.1
V
0.275
0.275
V
0.35
0.35
V
0.45
0.45
V
0.7
0.7
V
II
input leakage
current
VI = 0 V to 2.75 V;
VCC = 0 V to 2.75 V
[1]
0.001
0.1
0.5
A
IOFF
power-off
leakage current
VI or VO = 0 V to 2.75 V;
VCC = 0 V
[1]
0.01
0.1
0.5
A
IOFF
additional
power-off
leakage current
VI or VO = 0 V or 2.75 V;
VCC = 0 V to 0.1 V
[1]
0.02
0.1
0.5
A
ICC
supply current
VI = 0 V or VCC; IO = 0 A
[1]
0.01
0.3
0.6
A
ICC
additional supply VI = VCC 0.5 V; IO = 0 A;
current
VCC = 2.5 V
2
100
150
A
[1]
Typical values are measured at VCC = 1.2 V.
74AXP1G97
Product data sheet
6 of 18
74AXP1G97
Nexperia
10.1 Waveform transfer characteristics
92
97
9,
9+
97
9,
9+
97
97
92
PQD
PQD
Fig 12. Transfer characteristic
Fig 13. Definition of VT+, VT, and VH
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 20.
Symbol Parameter
tpd
propagation
delay
Tamb = 25 C
Conditions
Unit
Min
Typ[1]
Max
Min
Max
3
14
45
3
148
ns
VCC = 1.1 V to 1.3 V
2.3
5.0
8.1
2.1
8.5
ns
VCC = 1.4 V to 1.6 V
1.9
3.7
5.4
1.7
5.8
ns
A, B and C to Y; see Figure 14
[2][3]
VCC = 1.65 V to 1.95 V
1.6
3.1
4.3
1.4
4.7
ns
1.3
2.4
3.3
1.1
3.5
ns
1.0
ns
transition time
CI
input
capacitance
VI = 0 V or VCC;
VCC = 0 V to 2.75 V
0.5
pF
CO
output
capacitance
VO = 0 V; VCC = 0 V
1.0
pF
74AXP1G97
Product data sheet
VCC = 2.7 V; see Figure 14
[4]
tt
7 of 18
74AXP1G97
Nexperia
Table 9.
Dynamic characteristics …continued
Symbol Parameter
Tamb = 25 C
Conditions
Min
CPD
Typ[1]
Max
Max
[5]
power dissipation fi = 1 MHz; VI = 0 V to VCC
capacitance
2.5
pF
2.6
pF
2.7
pF
2.8
pF
3.2
pF
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
For additional propagation delay values at different load capacitances see Figure 15 to Figure 19.
[4]
tt is the same as tTHL and tTLH.
[5]
Min
Unit
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + CL VCC2 fo where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching.
11.1 Waveforms and graphs
9,
$%&LQSXW
90
90
9
W3+/
92+
W3/+
很抱歉,暂时无法提供与“74AXP1G97GNH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.80914
- 10+0.64250
- 30+0.55912
- 100+0.49659
- 500+0.44658
- 1000+0.42153
