74HC00; 74HCT00
Quad 2-input NAND gate
Rev. 7 — 25 November 2015
Product data sheet
1. General description
The 74HC00; 74HCT00 is a quad 2-input NAND gate. Inputs include clamp diodes. This
enables the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
2. Features and benefits
Input levels:
For 74HC00: CMOS level
For 74HCT00: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC00D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
40 C to +125 C
DHVQFN14
plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74HCT00D
74HC00DB
74HCT00DB
74HC00PW
74HCT00PW
74HC00BQ
74HCT00BQ
74HC00; 74HCT00
Nexperia
4. Functional diagram
PQD
Fig 1.
PQD
Logic symbol
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one gate)
5. Pinning information
5.1 Pinning
+&7
WHUPLQDO
LQGH[DUHD
*1'
9&&
*1'
9&&
+&7
*1'
DDO
7UDQVSDUHQWWRSYLHZ
DDO
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and (T)SSOP14
74HC_HCT00
Product data sheet
Fig 5.
Pin configuration DHVQFN14
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC00; 74HCT00
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 4A
1, 4, 9, 12
data input
1B to 4B
2, 5, 10, 13
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nB
nY
L
X
H
X
L
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
IGND
Tstg
storage temperature
Max
Unit
0.5
+7
V
mA
mA
25
mA
supply current
50
mA
ground current
50
mA
65
+150
C
500
mW
[2]
total power dissipation
Ptot
Min
SO14, (T)SSOP14 and
DHVQFN14 packages
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C.
74HC_HCT00
Product data sheet
3 of 15
74HC00; 74HCT00
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC00
Min
Typ
74HCT00
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
74HC00
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.2
1.5
1.5
V
VCC = 4.5 V
2.4
3.15
3.15
V
VCC = 6.0 V
3.2
4.2
4.2
V
LOW-level
input voltage
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.81
5.34
5.2
V
0.1
V
0.1
V
0.1
V
0.15
0.33
0.4
V
0.16
0.33
0.4
V
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
A
74HC_HCT00
Product data sheet
4 of 15
74HC00; 74HCT00
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
CI
25 C
Conditions
input
capacitance
Min
Typ
Max
Min
Max
Min
Max
3.5
pF
74HCT00
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.5
4.4
4.4
V
IO = 4.0 mA
4.32
3.84
3.7
V
LOW-level
output voltage
0.1
V
0.15
0.33
0.4
V
VOL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
1
1
A
ICC
supply current
VCC = 6.0 V
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
150
675
735
A
CI
input
capacitance
3.5
pF
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for test circuit see Figure 7.
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
25
115
135
74HC00
tpd
propagation delay nA, nB to nY; see Figure 6
[1]
VCC = 2.0 V
VCC = 4.5 V
9
23
27
ns
VCC = 5.0 V; CL = 15 pF
7
ns
7
ns
VCC = 6.0 V
tt
transition time
74HC_HCT00
Product data sheet
ns
see Figure 6
[2]
VCC = 2.0 V
19
95
110
ns
VCC = 4.5 V
7
19
22
ns
VCC = 6.0 V
6
16
19
ns
5 of 15
74HC00; 74HCT00
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
CPD
25 C
Conditions
power dissipation
capacitance
[3]
per package; VI = GND to VCC
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
22
pF
74HCT00
[1]
tpd
transition time
tt
power dissipation
capacitance
CPD
VCC = 4.5 V
12
24
29
ns
10
ns
VCC = 4.5 V; see Figure 6
[2]
29
22
ns
per package;
VI = GND to VCC 1.5 V
[3]
22
pF
[1]
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
Q$Q%LQSXW
90
*1'
W3+/
92+
9<
90
9;
Q
很抱歉,暂时无法提供与“74HC00DB,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.70686
- 10+0.56128
- 30+0.48849
- 100+0.43384
- 500+0.39010
- 1000+0.36828
- 国内价格 香港价格
- 726+4.77036726+0.56826
- 1000+4.399151000+0.52404
- 10000+3.9226710000+0.46728
- 100000+3.28643100000+0.39149
- 国内价格 香港价格
