74HCT03D-Q100J
74HCT03D-Q100J
    NEXPERIA(安世)
    SOIC-14
    IC GATE NAND OD 4CH 2-INP 14SO
74HCT03D-Q100J 数据手册
74HC03-Q100; 74HCT03-Q100 Quad 2-input NAND gate Rev. 1 — 4 July 2013 Product data sheet 1. General description The 74HC03-Q100; 74HCT03-Q100 is a quad 2-input NAND gate with open-drain outputs. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC03-Q100: CMOS level  For 74HCT03-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC03D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm 74HCT03D-Q100 74HC03DB-Q100 74HCT03DB-Q100 74HC03PW-Q100 74HCT03PW-Q100 SOT402-1 74HC03-Q100; 74HCT03-Q100 Nexperia Quad 2-input NAND gate 4. Functional diagram  1 1A 2 1B 1Y 3 4 2A 5 2B 2Y 6 9 3A 10 3B 3Y 8 12 4A 13 4B 4Y 11        mna212 Fig 1.    Y A  B GND DDD Logic symbol Fig 2. 001aab715 IEC logic symbol Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning +&4 +&74 +&4 +&74 $   9&& %   % $   9&& <   $ %   %  < <   $ $   <  % %   %  <   $ *1'   < $ % < *1'      $ < DDD Fig 4. DDD Pin configuration SO14 Fig 5. Pin configuration (T)SSOP14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10, 13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 74HC_HCT03_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 2 of 14 74HC03-Q100; 74HCT03-Q100 Nexperia Quad 2-input NAND gate 6. Functional description Function table[1] Table 3. Input Output nA nB nY L L Z L H Z H L Z H H L [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VO output voltage IIK input clamping current IOK Conditions Min Max Unit 0.5 +7 V [1] 0.5 +7 V VI < 0.5 V or VI > VCC + 0.5 V [1] - 20 mA output clamping current VO < 0.5 V [1] - 20 mA IO output current 0.5 V < VO - 25 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW [2] total power dissipation Ptot SO14 and (T)SSOP14 packages [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage Conditions 74HC03-Q100 74HCT03-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate - - 625 - - - VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT03_Q100 Product data sheet VCC = 2.0 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 July 2013 © ns/V Nexperia B.V. 2017. All rights reserved 3 of 14 74HC03-Q100; 74HCT03-Q100 Nexperia Quad 2-input NAND gate 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V 74HC03-Q100 VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V VI = VIH or VIL - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - 0.1 - - 1 - 1 A IOZ OFF-state output current per input pin; VI = VIL; VO = VCC or GND; other inputs at VCC or GND; VCC = 6.0 V; IO = 0 A - - ±0.5 - ±5.0 - ±10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - 2.0 - - 20 - 40 A CI input capacitance - 3.5 - - - - - pF 74HCT03-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A IOZ OFF-state output current per input pin; VI = VIL; VO = VCC or GND; other inputs at VCC or GND; VCC = 5.5 V; IO = 0 A - - ±0.5 - ±5.0 - ±10 A 74HC_HCT03_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 4 of 14 74HC03-Q100; 74HCT03-Q100 Nexperia Quad 2-input NAND gate Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 A ICC additional supply current per input pin; VI = VCC  2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 100 360 - 450 - 490 A CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for load circuit, see Figure 7. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) 74HC03-Q100 tpd propagation delay nA, nB to nY; see Figure 6 [1] VCC = 2.0 V - 28 95 120 145 ns VCC = 4.5 V - 10 19 24 29 ns VCC = 5.0 V; CL = 15 pF - 8 - - - ns - 8 16 20 25 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 4 - - - pF VCC = 6.0 V tt transition time [2] see Figure 6 VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT03_Q100 Product data sheet per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 July 2013 © Nexperia B.V. 2017. All rights reserved 5 of 14 74HC03-Q100; 74HCT03-Q100 Nexperia Quad 2-input NAND gate Table 7. Dynamic characteristics …continued GND = 0 V; CL = 50 pF; for load circuit, see Figure 7. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) - 12 24 30 36 ns - 10 - - - ns 74HCT03-Q100 [1] propagation delay nA, nB to nY; see Figure 6 tpd VCC = 4.5 V VCC = 5.0 V; CL = 15 pF tt transition time VCC = 4.5 V; see Figure 6 [2] CPD power dissipation capacitance per package; VI = GND to VCC  1.5 V [3] [1] - 7 15 19 22 ns - 4 - - - pF tpd is the same as tPLZ and tPZL. [2] tt is the same as tTHL. [3] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, 90 Q$Q%LQSXW *1' W3/= W3=/ 9&&  Q
74HCT03D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT03D-Q100J”相匹配的价格&库存,您可以联系我们找货
74HCT03D-Q100J
  • 1215+3.866701215+0.50260
  • 10000+3.4473010000+0.44810
  • 100000+2.88750100000+0.37530
库存:2500
74HCT03D-Q100J
74HCT03D-Q100J
    • 1+3.82320
    • 200+1.47960
    • 500+1.42560
    • 1000+1.40400
    74HCT03D-Q100J
      • 2500+1.217232500+0.15805
