74HCT04PW,112
74HCT04PW,112
    NEXPERIA(安世)
    TSSOP-14
    IC INVERTER 6CH 6-INP 14TSSOP
74HCT04PW,112 数据手册
74HC04; 74HCT04 Hex inverter Rev. 5 — 27 November 2015 Product data sheet 1. General description The 74HC04; 74HCT04 is a hex inverter. The inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard JESD7A  Input levels:  For 74HC04: CMOS level  For 74HCT04: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC04D Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1 thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HCT04D 74HC04DB 74HCT04DB 74HC04PW 74HCT04PW 74HC04BQ 74HCT04BQ 74HC04; 74HCT04 Nexperia Hex inverter 4. Functional diagram    $ <   $ <    $ <   $ <   $ <   $ <           PQD Fig 1.       < $ PQD Logic symbol Fig 2. PQD IEC logic symbol Fig 3. Logic diagram (one inverter)  $ WHUPLQDO LQGH[DUHD $   < <  $   < <   $ *1'   <   $   $ $   < <    $ $  *1'   < <     < < <  9&&  $   *1' $  9&& 5. Pinning information $ DDF 7UDQVSDUHQWWRSYLHZ DDF (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 4. Pin configuration SO14 and (T)SSOP14 74HC_HCT04 Product data sheet Fig 5. Pin configuration DHVQFN14 All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 2 of 15 74HC04; 74HCT04 Nexperia Hex inverter 5.1 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level Input Output nA nY L H H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA 50 mA IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current 0.5 V < VO < VCC + 0.5 V ICC supply current - IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot SO14, (T)SSOP14 and DHVQFN14 packages [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 3 of 15 74HC04; 74HCT04 Nexperia Hex inverter 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC04 Min Typ 74HCT04 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC04 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2 - 20 - 40 A 74HC_HCT04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 4 of 15 74HC04; 74HCT04 Nexperia Hex inverter Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT04 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.84 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2 - 20 - 40 A ICC additional supply current per input pin; VI = VCC  2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 120 432 - 540 - 590 A CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 7. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) - 25 85 105 130 74HC04 tpd propagation delay nA to nY; see Figure 6 [1] VCC = 2.0 V VCC = 4.5 V - 9 17 21 26 ns VCC = 5.0 V; CL = 15 pF - 7 - - - ns - 7 14 18 22 ns VCC = 6.0 V tt transition time 74HC_HCT04 Product data sheet ns see Figure 6 [2] VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns VCC = 6.0 V - 6 13 16 19 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 5 of 15 74HC04; 74HCT04 Nexperia Hex inverter Table 7. Dynamic characteristics …continued GND = 0 V; CL = 50 pF; for test circuit see Figure 7. Symbol Parameter CPD power dissipation capacitance 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) - 21 - - - VCC = 4.5 V - 10 19 24 29 ns VCC = 5.0 V; CL = 15 pF - 8 - - - ns per package; VI = GND to VCC [3] pF 74HCT04 [1] propagation delay nA to nY; see Figure 6 tpd transition time tt power dissipation capacitance CPD VCC = 4.5 V; see Figure 6 [2] - 7 15 19 22 ns per package; VI = GND to VCC  1.5 V [3] - 24 - - - pF [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, 90 Q$LQSXW 90 *1' W 3+/ W 3/+ 92+  90 Q
74HCT04PW,112 价格&库存
很抱歉,暂时无法提供与“74HCT04PW,112”相匹配的价格&库存,您可以联系我们找货
74HCT04PW,112
  • 5+1.929745+0.25086
  • 25+1.4777325+0.19210
  • 96+1.2517396+0.16272
  • 480+1.13003480+0.14690
  • 960+1.09526960+0.14238
库存:1
74HCT04PW,112
  • 5+2.23989
  • 25+1.69848
  • 96+1.44335
  • 480+1.30440
  • 960+1.25769
库存:1
74HCT04PW,112
74HCT04PW,112
