74HCT08PW,118
74HCT08PW,118
    NEXPERIA(安世)
    TSSOP-14
    IC GATE AND 4CH 2-INP 14TSSOP
74HCT08PW,118 数据手册
74HC08; 74HCT08 Quad 2-input AND gate Rev. 6 — 13 June 2017 1 Product data sheet General description The 74HC08; 74HCT08 is a quad 2-input AND gate. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • Complies with JEDEC standard JESD7A • Input levels: – For 74HC08: CMOS level – For 74HCT08: TTL level • ESD protection: – HBM JESD22-A114F exceeds 2 000 V – MM JESD22-A115-A exceeds 200 V • Multiple package options • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC08D -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74HCT08D 74HC08DB 74HCT08DB 74HC08PW 74HCT08PW 74HC08BQ 74HCT08BQ 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 4 Functional diagram 1 & 3 & 6 & 8 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 4 1Y 3 5 2Y 6 9 3Y 10 8 12 11 4Y 11 13 Y B mna223 mna222 Figure 1. Logic symbol 5 A & Figure 2. IEC logic symbol mna221 Figure 3. IEC logic symbol Pinning information 5.1 Pinning 1 1A terminal 1 index area 1B 2 13 4B 1Y 3 12 4A 2A 4 11 4Y 2B 5 10 3B 2Y 6 9 3A GND 7 8 3Y 12 4A 2A 4 2B 5 2Y 6 11 4Y GND(1) 10 3B 9 3A aaa-004036 Transparent top view Figure 4. Pin configuration SO14 and (T)SSOP14 Product data sheet 3 (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. aaa-004035 74HC_HCT08 1Y 8 14 VCC 13 4B 3Y 1 2 7 1A 1B GND 74HC08 74HCT08 14 VCC 74HC08 74HCT08 Figure 5. Pin configuration DHVQFN14 All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10,13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6 Functional description Table 3. Function table [1] Output Input nA nB nY L L L L H L H L L H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC Conditions supply voltage IIK input clamping current Min Max Unit -0.5 +7 V VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA [1] - ±20 mA - ±25 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot [1] [2] total power dissipation Tamb = -40 to +85 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 °C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 °C. 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC08 74HCT08 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V 74HC08 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74HC_HCT08 Product data sheet VI = VIH or VIL VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate Symbol Parameter Conditions 25 °C IO = 5.2 mA; VCC = 6.0 V -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1 - ±1 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HCT08 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA 3.98 4.32 - 3.84 - 3.7 - V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA - 0.15 0.26 - 0.33 - 0.4 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1 - ±1 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 60 216 - 270 - 294 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 10 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Figure 7. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Max (85 °C) Max (125 °C) VCC = 2.0 V - 25 90 115 135 ns VCC = 4.5 V - 9 18 23 27 ns VCC = 5.0 V; CL = 15 pF - 7 - - - ns - 7 15 20 23 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns VCC = 6.0 V - 6 13 16 19 ns - 10 - - - pF - 14 24 30 36 ns 74HC08 tpd propagation delay nA, nB to nY; see Figure 6 [1] VCC = 6.0 V tt transition time CPD [2] see Figure 6 power dissipation capacitance per package; VI = GND to VCC [3] propagation delay nA, nB to nY; see Figure 6 [1] 74HCT08 tpd VCC = 4.5 V VCC = 5.0 V; CL = 15 pF tt transition time VCC = 4.5 V; see Figure 6 [2] CPD power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] [1] [2] [3] - 11 - - - ns - 7 15 19 22 ns - 20 - - - pF tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL × VCC × fo) = sum of outputs. 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 10.1 Waveforms and test circuit VI nA, nB input VM GND tPHL VOH VY nY output VOL tTHL tPLH VM VX tTLH aaa-004037 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Input to output propagation delays Table 8. Measurement points Input Output VM VM VX VY 74HC08 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT08 1.3 V 1.3 V 0.1VCC 0.9VCC Type 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Figure 7. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC08 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT08 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 11 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 8. Package outline SOT108-1 (SO14) 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 9. Package outline SOT337-1 (SSOP14) 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 10. Package outline SOT402-1 (TSSOP14) 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 Eh e 14 8 k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Figure 11. Package outline SOT762-1 (DHVQFN14) 74HC_HCT08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT08 v.6 20170613 Product data sheet - Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT08 v.5 20151130 Modifications: • Type numbers 74HC08N and 74HCT08N (SOT27-1) removed. 74HC_HCT08 v.4 20120906 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT08 v.3 20030725 Product specification - 74HC_HCT08_CNV v.2 74HC_HCT08_CNV v.2 19970826 Product specification - - 74HC_HCT08 Product data sheet Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 74HC_HCT08 v.5 74HC_HCT08 v.4 74HC_HCT08 v.3 © Nexperia B.V. 2017. All rights reserved. 13 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT08 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 16 74HC08; 74HCT08 Nexperia Quad 2-input AND gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT08 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 13 June 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 16 Nexperia 74HC08; 74HCT08 Quad 2-input AND gate Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 3 Recommended operating conditions ................ 4 Static characteristics .......................................... 4 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................9 Abbreviations .................................................... 13 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 June 2017 Document identifier: 74HC_HCT08 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC08BQ,115 74HC08D,652 74HC08DB,112 74HC08DB,118 74HC08D,653 74HC08PW,112 74HC08PW,118 74HCT08BQ,115 74HCT08D,652 74HCT08DB,112 74HCT08DB,118 74HCT08D,653 74HCT08PW,112 74HCT08PW,118 74HC08D/AUJ 74HCT08D/AUJ
74HCT08PW,118
物料型号:74HC08; 74HCT08,这是一款四2输入与门。
器件简介:74HC08和74HCT08是四2输入与门,输入端包含钳位二极管,允许使用限流电阻将输入接口至超过VCC的电压。
引脚分配:文档提供了SO14、SSOP14、TSSOP14和DHVQFN14四种封装的引脚分配图和描述。
参数特性:包括工作电压范围、输入输出电平、ESD保护等级、多种封装选项、温度范围等。
功能详解:逻辑功能表展示了所有可能的输入组合及其对应的输出结果。
应用信息:虽然文档中没有直接的应用信息,但与门是一种基本的数字逻辑电路,广泛应用于各种数字电路设计中。
封装信息:文档列出了四种不同的封装类型及其详细的物理尺寸和特性。
74HCT08PW,118 价格&库存
很抱歉,暂时无法提供与“74HCT08PW,118”相匹配的价格&库存,您可以联系我们找货
74HCT08PW,118
  • 5+0.94521
  • 20+0.86181
  • 100+0.77841
  • 500+0.69501
  • 1000+0.65609
  • 2000+0.62829
74HCT08PW,118
    74HCT08PW,118
    • 1+0.92730
    • 100+0.61930
    • 1250+0.56210
    • 2500+0.51590
    库存:1
