74HC132DB,118
74HC132DB,118
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    IC GATE NAND 4CH 2-INP 14SSOP
74HC132DB,118 数据手册
74HC132; 74HCT132 Quad 2-input NAND Schmitt trigger Rev. 6 — 16 July 2019 Product data sheet 1. General description The 74HC132; 74HCT132 is a quad 2-input NAND gate with Schmitt-trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2. Features and benefits • • • • Complies with JEDEC standard no. 7A ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from −40 °C to +85 °C and from −40 °C to +125 °C 3. Applications • • • Wave and pulse shapers Astable multivibrators Monostable multivibrators 4. Ordering information Table 1. Ordering information Type number Package 74HC132D Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74HCT132D 74HC132DB 74HCT132DB 74HC132PW 74HCT132PW 74HC132BQ 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 5. Functional diagram 1 1A 1Y 2 4 1B 2A 2Y 5 9 2B 1 6 2 4 3A 3Y 10 3 3B 5 9 4A 4Y 13 4B 12 11 13 & 6 & 8 A & Y 11 B mna409 mna408 mna407 Fig. 1. 3 8 10 12 & Logic symbol Fig. 2. Fig. 3. IEC logic symbol Logic diagram (one Schmitt trigger) 6. Pinning information 6.1. Pinning 1 1A terminal 1 index area 2 1Y 3 2A 4 2B 5 10 3B 2Y 6 9 3A GND 7 8 3Y 12 4A 132 11 4Y Pin configuration SOT108-1 (SO14), SOT337-1 (SSOP14) and SOT402-1 (TSSOP14) 74HC_HCT132 Product data sheet 12 4A 4 11 4Y 2B 5 2Y 6 GND(1) 13 4B 10 3B 9 3A aaa-030172 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. mna406 Fig. 4. 3 2A 8 1B 1Y 7 14 VCC 13 4B 2 3Y 1 1B GND 1A 14 VCC 74HC132 Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 2 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 6.2. Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10, 13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 7. Functional description Table 3. Function table [1] Input Output nA nB nY L L H L H H H L H H H L [1] H = HIGH voltage level; L = LOW voltage level 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT337-1 (SSOP14) packages: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT402-1 (TSSOP14) packages: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) packages: Ptot derates linearly with 9.6 mW/K above 98 °C. 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 3 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC132 74HCT132 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max HIGH-level output VI = VT+ or VTvoltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 74HC132 VOH VOL 5.48 5.81 - 5.34 - 5.2 - V LOW-level output VI = VT+ or VTvoltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HCT132 VOH HIGH-level output VI = VT+ or VT-; VCC = 4.5 V voltage IO = -20 μA IO = -4.0 mA VOL LOW-level output VI = VT+ or VT-; VCC = 4.5 V voltage IO = 20 μA; IO = 4.0 mA; II input leakage current 74HC_HCT132 Product data sheet VI = VCC or GND; VCC = 5.5 V 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 4 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - 30 108 - 135 - 147 μA CI input capacitance - 3.5 - - - - - pF 11. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Fig. 7. Symbol Parameter Conditions 25 °C −40 °C to +85 °C −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 36 125 - 155 - 190 ns VCC = 4.5 V - 13 25 - 31 - 38 ns VCC = 5.0 V; CL = 15 pF - 11 - - - - - ns VCC = 6.0 V - 10 21 - 26 - 32 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns - 24 - - - - - pF VCC = 4.5 V - 20 33 - 41 - 50 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns 74HC132 tpd propagation delay tt transition time CPD power dissipation capacitance nA, nB to nY; see Fig. 6 [1] see Fig. 6 [2] per package; VI = GND to VCC [3] nA, nB to nY; see Fig. 6 [1] 74HCT132 tpd propagation delay tt transition time VCC = 4.5 V; see Fig. 6 [2] - 7 15 - 19 - 22 ns CPD power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] - 20 - - - - - pF [1] [2] [3] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL × VCC × fo) = sum of outputs. 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 5 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 11.1. Waveforms and test circuit VI nA, nB input VM GND tPHL VOH tPLH VY nY output VOL VM VX tTHL tTLH 001aai814 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Input to output propagation delays Table 8. Measurement points Input Type Output VM VM VX VY 74HC132 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT132 1.3 V 1.3 V 0.1VCC 0.9VCC VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 7. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC132 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT132 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 6 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 12. Transfer characteristics Table 10. Transfer characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for waveforms see Fig. 8 till Fig. 11. Symbol Parameter Conditions Tamb = 25 °C Tamb = −40 °C to +85 °C Tamb = −40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 0.7 1.18 1.5 0.7 1.5 0.7 1.5 V VCC = 4.5 V 1.7 2.38 3.15 1.7 3.15 1.7 3.15 V VCC = 6.0 V 2.1 3.14 4.2 2.1 4.2 2.1 4.2 V VCC = 2.0 V 0.3 0.63 1.0 0.3 1.0 0.3 1.0 V VCC = 4.5 V 0.9 1.67 2.2 0.9 2.2 0.9 2.2 V VCC = 6.0 V 1.2 2.26 3.0 1.2 3.0 1.2 3.0 V VCC = 2.0 V 0.2 0.55 1.0 0.2 1.0 0.2 1.0 V VCC = 4.5 V 0.4 0.71 1.4 0.4 1.4 0.4 1.4 V VCC = 6.0 V 0.6 0.88 1.6 0.6 1.6 0.6 1.6 V positive-going threshold voltage VCC = 4.5 V 1.2 1.41 1.9 1.2 1.9 1.2 1.9 V VCC = 5.5 V 1.4 1.59 2.1 1.4 2.1 1.4 2.1 V negative-going threshold voltage VCC = 4.5 V 0.5 0.85 1.2 0.5 1.2 0.5 1.2 V VCC = 5.5 V 0.6 0.99 1.4 0.6 1.4 0.6 1.4 V hysteresis voltage VCC = 4.5 V 0.4 0.56 - 0.4 - 0.4 - V VCC = 5.5 V 0.4 0.60 - 0.4 - 0.4 - V 74HC132 VT+ VT- VH positive-going threshold voltage negative-going threshold voltage hysteresis voltage 74HCT132 VT+ VTVH 12.1. Transfer characteristics waveforms VO VI VI VH VT- Fig. 8. VT+ Transfer characteristics 74HC_HCT132 Product data sheet VT+ VH VT- VO mna207 mna208 Fig. 9. Transfer characteristics definitions All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 7 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger aaa-003889 50 aaa-003890 500 ICC (µA) ICC (µA) 40 400 30 300 20 200 10 100 0 0 1 0 2 VIN (V) a. VCC = 2.0 V 0 1 2 3 4 VIN (V) 5 b. VCC = 4.5 V aaa-003892 1.0 ICC (mA) 0.8 0.6 0.4 0.2 0 0 1.2 2.4 3.6 4.8 6.0 VIN (V) c. VCC = 6.0 V Fig. 10. Typical 74HC132 transfer characteristics aaa-003893 1.5 aaa-003895 1.8 ICC (mA) 1.5 ICC (mA) 1.2 1.2 0.9 0.9 0.6 0.6 0.3 0 0.3 0 1 2 3 4 VIN (V) 0 5 a. VCC = 4.5 V 0 1 2 3 4 5 VIN (V) 6 b. VCC = 5.5 V Fig. 11. Typical 74HCT132 transfer characteristics 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 8 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 13. Application information The slow input rise and fall times cause additional power dissipation, this can be calculated using the following formula: Padd = fi × (tr × ΔICC(AV) + tf × ΔICC(AV)) × VCC where: Padd = additional power dissipation (μW); fi = input frequency (MHz); tr = rise time (ns); 10 % to 90 %; ΔICC(AV) = average additional supply current (μA). tf = fall time (ns); 90 % to 10 %; Average ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 12 and Fig. 13. An example of a relaxation circuit using the 74HC132; 74HCT132 is shown in Fig. 14. aaa-003897 400 average ICC (µA) 300 200 positive-going edge 100 negative-going edge 0 0 2 4 VCC (V) 6 Fig. 12. Average additional supply current as a function of VCC for 74HC132; linear change of VI between 0.1VCC to 0.9VCC. aaa-003899 500 average ICC (µA) 400 positive-going edge 300 200 negative-going edge 100 0 0 2 4 VCC (V) 6 Fig. 13. Average additional supply current as a function of VCC for 74HCT132; linear change of VI between 0.1VCC to 0.9VCC. 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 9 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger VCC R VCC A Y B C 001aac440 For 74HC132 and 74HCT132: Typical K-factor for relaxation oscillator, see Fig. 15 and Fig. 16 Fig. 14. Relaxation oscillator aaa-004609 2.0 K aaa-004610 1.2 K 1.0 1.5 0.8 1.0 0.6 0.4 0.5 0.2 0 2 3 4 Fig. 15. K-factor for 74HC132 74HC_HCT132 Product data sheet 5 VCC (V) 6 0 4.5 5.0 VCC (V) 5.5 Fig. 16. K-factor for 74HCT132 All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 10 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 14. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 17. Package outline SOT108-1 (SO14) 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 11 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 18. Package outline SOT337-1 (SSOP14) 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 12 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 19. Package outline SOT402-1 (TSSOP14) 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 13 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 20. Package outline SOT762-1 (DHVQFN14) 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 14 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 15. Abbreviations Table 11. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 16. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT132 v.6 20190716 Product data sheet - 74HC_HCT132 v.5 Modifications: • • 74HC_HCT132 v.5 20180612 Modifications: • • Type number 74HC132BQ (SOT762-1) added. Table 4: Derating values for Ptot total power dissipation have changed. 20151201 Modifications: • 74HC_HCT132 v.3 20120830 Modifications: • Product data sheet 74HC_HCT132 v.4 Product data sheet - 74HC_HCT132 v.3 Type numbers 74HC132N and 74HCT132N (SOT27-1) removed. Product data sheet - 74HC_HCT132_CNV v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Fig. 15 and Fig. 16 added (typical K-factor for relaxation oscillator). 74HC_HCT132_CNV v.2 19970826 74HC_HCT132 - The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74HC_HCT132 v.4 • • Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 - © Nexperia B.V. 2019. All rights reserved 15 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT132 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 16 / 17 74HC132; 74HCT132 Nexperia Quad 2-input NAND Schmitt trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................5 11.1. Waveforms and test circuit........................................ 6 12. Transfer characteristics............................................. 7 12.1. Transfer characteristics waveforms........................... 7 13. Application information............................................. 9 14. Package outline........................................................ 11 15. Abbreviations............................................................ 15 16. Revision history........................................................15 17. Legal information......................................................16 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 July 2019 74HC_HCT132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 16 July 2019 © Nexperia B.V. 2019. All rights reserved 17 / 17 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC132D 74HC132D,652 74HC132DB,112 74HC132DB,118 74HC132D,653 74HC132PW,112 74HC132PW,118 74HCT132D,652 74HCT132DB,112 74HCT132DB,118 74HCT132D,653 74HCT132PW,112 74HCT132PW,118 74HCT132D/AUJ 74HC132D/AUJ
74HC132DB,118
1. 物料型号:74HC132是Nexperia公司生产的一种集成电路型号,属于数字逻辑电路系列。
2. 器件简介:74HC132是一种双2线-4线译码器,用于将2位二进制输入信号扩展为4位输出信号,广泛应用于数字电路设计中。
3. 引脚分配:74HC132的引脚通常包括电源引脚(Vcc和GND)、输入引脚(A和B)、使能引脚(E1和E2)以及输出引脚(Y0到Y3)。
4. 参数特性:包括工作电压范围、功耗、工作温度范围、输入/输出电压电平等。
5. 功能详解:74HC132可以根据输入信号的不同组合,选择激活对应的输出线,实现信号的分配和选择功能。
6. 应用信息:广泛应用于数字电路设计,如地址译码、数据选择、控制信号分配等。
7. 封装信息:74HC132有多种封装形式,如SOIC、DIP等。
74HC132DB,118 价格&库存
很抱歉,暂时无法提供与“74HC132DB,118”相匹配的价格&库存,您可以联系我们找货
74HC132DB,118
  • 813+4.26509813+0.50765
  • 1000+3.933311000+0.46816
  • 10000+3.5063410000+0.41734
  • 100000+2.93797100000+0.34969
库存:60000
74HC132DB,118
库存:55500
74HC132DB,118
    • 1+0.65308
    • 10+0.51851
    • 30+0.45123
    • 100+0.40079
    • 500+0.36040
    • 1000+0.34031
