74HC1G02; 74HCT1G02
2-input NOR gate
Rev. 04 — 11 July 2007
Product data sheet
1. General description
74HC1G02 and 74HCT1G02 are high speed Si-gate CMOS devices. They provide a
2-input NOR function.
The HC device has CMOS input switching levels and supply voltage range 2 V to 6 V.
The HCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V.
The standard output currents are half those of the 74HC02 and 74HCT02.
2. Features
n
n
n
n
n
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
SOT353-1 and SOT753 package options
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
74HC1G02GW
−40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads; SOT353-1
body width 1.25 mm
−40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
74HCT1G02GW
74HC1G02GV
74HCT1G02GV
4. Marking
Table 2.
Marking codes
Type number
Marking
74HC1G02GW
HB
74HCT1G02GW
TB
74HC1G02GV
H02
74HCT1G02GV
T02
Version
SOT753
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
5. Functional diagram
B
1
B
2
A
Y
1
4
≥1
4
Y
2
A
mna104
mna103
Fig 1. Logic symbol
mna105
Fig 2. IEC logic symbol
Fig 3. Logic diagram
6. Pinning information
6.1 Pinning
74HC1G02
74HCT1G02
B
1
A
2
GND
3
5
VCC
4
Y
001aaf085
Fig 4. Pin configuration
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7. Functional description
Table 4.
Function table
H = HIGH voltage level; L = LOW voltage level
Inputs
Output
A
B
Y
L
L
H
L
H
L
H
L
L
H
H
L
74HC_HCT1G02_4
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). [1]
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
−0.5 V < VO < VCC + 0.5 V
±12.5
mA
ICC
supply current
25
mA
IGND
ground current
−25
mA
Tstg
storage temperature
−65
+150
°C
200
mW
Tamb = −40 °C to +125 °C
total power dissipation
Ptot
[2]
Min
Max
Unit
−0.5
+7.0
V
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
9. Recommended operating conditions
Table 6.
Symbol Parameter
VCC
supply voltage
Conditions
74HC1G02
74HCT1G02
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
−40
+25
+125
−40
+25
+125
°C
∆t/∆V
input transition rise
and fall rate
VCC = 2.0 V
625
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
ns/V
10. Static characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol
Parameter
Conditions
−40 °C to +85 °C
−40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
V
For type 74HC1G02
VIH
VIL
HIGH-level input
voltage
LOW-level input
voltage
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
74HC_HCT1G02_4
Product data sheet
3 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
Table 7.
Static characteristics …continued
Symbol
VOH
VOL
Parameter
HIGH-level output
voltage
LOW-level output
voltage
−40 °C to +85 °C
Conditions
−40 °C to +125 °C
Min
Typ
Max
Min
Max
Unit
VI = VIH or VIL
IO = −20 µA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = −20 µA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = −20 µA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = −2.0 mA; VCC = 4.5 V
4.13
4.32
3.7
V
IO = −2.6 mA; VCC = 6.0 V
5.63
5.81
5.2
V
IO = 20 µA; VCC = 2.0 V
0.1
V
IO = 20 µA; VCC = 4.5 V
0.1
V
IO = 20 µA; VCC = 6.0 V
0.1
V
IO = 2.0 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 2.6 mA; VCC = 6.0 V
0.16
0.33
0.4
V
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
1.0
1.0
µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
10
µA
CI
input capacitance
1.5
pF
For type 74HCT1G02
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL
4.4
4.5
4.4
V
4.13
4.32
3.7
V
VOL
LOW-level output
voltage
VI = VIH or VIL
0.1
V
0.15
0.33
0.4
V
II
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
µA
ICC
supply current
VCC = 5.5 V
10
µA
∆ICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC − 2.1 V; IO = 0 A
500
850
µA
CI
input capacitance
1.5
pF
74HC_HCT1G02_4
Product data sheet
4 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
11. Dynamic characteristics
Table 8.
GND = 0 V; tr = tf ≤ 6.0 ns; All typical values are measured at Tamb = 25 °C. For test circuit see Figure 6
Symbol Parameter
−40 °C to +85 °C
Conditions
−40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V; CL = 50 pF
25
115
135
ns
VCC = 4.5 V; CL = 50 pF
9
23
27
ns
VCC = 5.0 V; CL = 15 pF
7
ns
VCC = 6.0 V; CL = 50 pF
8
ns
18
pF
11
24
27
ns
9
ns
19
pF
For type 74HC1G02
tpd
CPD
propagation delay A and B to Y; see Figure 5
[1]
[2]
power dissipation VI = GND to VCC
capacitance
For type 74HCT1G02
tpd
[1]
CPD
power dissipation VI = GND to VCC − 1.5 V
capacitance
[1]
tpd is the same as tPLH and tPHL.
[2]
CPD is used to determine the dynamic power dissipation PD (µW).
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
∑ (CL × VCC2 × fo) = sum of outputs
[2]
12. Waveforms
A, B input
VM
VCC
tPHL
Y output
tPLH
PULSE
GENERATOR
VM
VI
VO
DUT
CL
RT
mna101
mna106
For HC1G02: VM = 0.5 × VCC; VI = GND to VCC
Test data is given in Table 8.
For HCT1G02: VM = 1.3 V; VI = GND to 3.0 V
CL = Load capacitance including jig and probe
capacitance.
RT = Termination resistance should be equal to
output impedance Zo of the pulse generator.
Fig 5. Input to output propagation delays
Fig 6. Load circuitry for switching times
74HC_HCT1G02_4
Product data sheet
5 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
13. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
E
D
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
L
e
w M
bp
detail X
e1
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig 7. Package outline SOT353-1 (TSSOP5)
74HC_HCT1G02_4
Product data sheet
6 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
Plastic surface-mounted package; 5 leads
SOT753
D
E
B
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
SC-74A
Fig 8. Package outline SOT753 (SC-74A)
74HC_HCT1G02_4
Product data sheet
7 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
14. Abbreviations
Table 9.
Abbreviations
Acronym
Description
DUT
Device Under Test
TTL
Transistor-Transistor Logic
15. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT1G02_4
20070711
Product data sheet
74HC_HCT1G02_3
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Package SOT353 changed to SOT353-1 in Table 1 and Figure 7.
Quick reference data and Soldering sections removed.
Section 2 “Features” updated.
74HC_HCT1G02_3
20020517
Product specification
74HC_HCT1G02_2
74HC_HCT1G02_2
20010302
74HC_HCT1G02_1
74HC_HCT1G02_1
19980831
74HC_HCT1G02_4
Product data sheet
8 of 10
74HC1G02; 74HCT1G02
Nexperia
2-input NOR gate
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
16.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74HC_HCT1G02_4
Product data sheet
9 of 10
Nexperia
74HC1G02; 74HCT1G02
2-input NOR gate
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 3
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Contact information. . . . . . . . . . . . . . . . . . . . . . 9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 July 2007
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC1G02GV,125 74HC1G02GW,125 74HC1G02GW,165 74HCT1G02GV,125 74HCT1G02GW,125
很抱歉,暂时无法提供与“74HCT1G02GV,125”相匹配的价格&库存,您可以联系我们找货
