74HC1G08; 74HCT1G08
2-input AND gate
Rev. 5 — 14 March 2018
1
Product data sheet
General description
The 74HC1G08; 74HCT1G08 is a single 2-input AND gate. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess
of VCC.
2
Features
• Input levels:
– For 74HC1G08: CMOS level
– For 74HCT1G08: TTL level
• Symmetrical output impedance
• High noise immunity
• Low power dissipation
• Balanced propagation delays
• ESD protection:
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
• Multiple package options
• Specified from −40 °C to +85 °C and −40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
74HC1G08GW
Package
Temperature range Name
Description
Version
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
-40 °C to +125 °C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74HCT1G08GW
74HC1G08GV
74HCT1G08GV
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
4
Marking
Table 2. Marking codes
Type number
Marking
74HC1G08GW
HE
74HCT1G08GW
TE
74HC1G08GV
H08
74HCT1G08GV
T08
5
Functional diagram
1
B
2
A
Y
1
4
4
2
mna114
mna113
Figure 1. Logic symbol
Figure 2. IEC logic symbol
B
Y
A
mna115
Figure 3. Logic diagram
6
Pinning information
6.1 Pinning
74HC1G08
74HCT1G08
B
1
A
2
GND
3
5
VCC
4
Y
001aaf102
Figure 4. Pin configuration
74HC_HCT1G08
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
2 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
6.2 Pin description
Table 3. Pin description
Symbol
Pin
Description
B
1
data input
A
2
data input
GND
3
ground (0 V)
Y
4
data output
VCC
5
supply voltage
7
Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
A
B
Y
L
L
L
L
H
L
H
L
L
H
H
H
8
Limiting values
Table 5. Limiting values
[1]
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
Min
Max
Unit
-0.5
+7.0
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±12.5
mA
ICC
supply current
25
mA
IGND
ground current
-25
mA
Tstg
storage temperature
-65
+150
°C
200
mW
Ptot
total power dissipation
Conditions
Tamb = -40 °C to +125 °C
[2]
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] Above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
74HC_HCT1G08
Product data sheet
3 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
9
Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
74HC1G08
74HCT1G08
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise
and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
139
139
ns/V
VCC = 6.0 V
83
ns/V
10 Static characteristics
Table 7. Static characteristics
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = -2.0 mA; VCC = 4.5 V
4.13
4.32
3.7
V
IO = -2.6 mA; VCC = 6.0 V
5.63
5.81
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
V
IO = 2.0 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 2.6 mA; VCC = 6.0 V
0.16
0.33
0.4
V
1.0
1.0
μA
74HC1G08
VIH
VIL
VOH
VOL
II
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
input leakage current
74HC_HCT1G08
Product data sheet
VI = VIH or VIL
VI = VIH or VIL
VI = VCC or GND; VCC = 6.0 V
4 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
Symbol
Parameter
Conditions
ICC
supply current
CI
input capacitance
-40 °C to +85 °C
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
-40 °C to +125 °C
Unit
Min
Typ
Max
Min
Max
10
μA
1.5
pF
74HCT1G08
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL
4.4
4.5
4.4
V
4.13
4.32
3.7
V
0.1
V
0.15
0.33
0.4
V
VOL
LOW-level output
voltage
VI = VIH or VIL
II
VI = VCC or GND; VCC = 5.5 V
1.0
1.0
μA
ICC
supply current
VCC = 5.5 V
10
μA
ΔICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC - 2.1 V; IO = 0 A
500
850
μA
CI
input capacitance
1.5
pF
11 Dynamic characteristics
Table 8. Dynamic characteristics
GND = 0 V; tr = tf ≤ 6.0 ns; All typical values are measured at Tamb = 25 °C. For test circuit see Figure 6
Symbol Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
VCC = 2.0 V; CL = 50 pF
25
115
135
ns
VCC = 4.5 V; CL = 50 pF
9
23
27
ns
VCC = 5.0 V; CL = 15 pF
7
ns
8
ns
19
pF
74HC1G08
tpd
propagation delay A and B to Y; see Figure 5
[1]
VCC = 6.0 V; CL = 50 pF
CPD
power dissipation VI = GND to VCC
capacitance
74HC_HCT1G08
Product data sheet
[2]
5 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ
Max
Min
Max
11
23
27
ns
11
ns
21
pF
74HCT1G08
tpd
[1]
CPD
power dissipation VI = GND to VCC - 1.5 V
capacitance
[2]
[1] tpd is the same as tPLH and tPHL.
[2] CPD is used to determine the dynamic power dissipation PD (μW).
2
2
PD = CPD x VCC x fi + ∑(CL x VCC x fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
2
∑(CL x VCC x fo) = sum of outputs
11.1 Waveform and test circuit
VCC
A, B input
PULSE
GENERATOR
VM
VI
DUT
VO
CL
RT
tPHL
tPLH
mna101
Test data is given in Table 8. Definitions for test
Y output
circuit:
VM
mna116
CL = Load capacitance including jig and probe
capacitance
For 74HC1G08: VM = 0.5 x VCC; VI = GND to VCC
For 74HCT1G08: VM = 1.3 V; VI = GND to 3.0 V
RT = Termination resistance should be equal to the
Figure 5. The input (A and B) to output (Y) propagation
delays
Figure 6. Test circuit for measuring switching times
74HC_HCT1G08
Product data sheet
output impedance Zo of the pulse generator
6 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
12 Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Figure 7. Package outline SOT353-1 (TSSOP5)
74HC_HCT1G08
Product data sheet
7 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
Plastic surface-mounted package; 5 leads
SOT753
D
B
E
y
A
X
HE
5
v M A
4
Q
A
A1
c
1
2
3
Lp
detail X
bp
e
w M B
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.100
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT753
JEITA
SC-74A
EUROPEAN
PROJECTION
ISSUE DATE
02-04-16
06-03-16
Figure 8. Package outline SOT753 (SC-74A)
74HC_HCT1G08
Product data sheet
8 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
13 Abbreviations
Table 9. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14 Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT1G08 v.5
20180314
Product data sheet
74HC_HCT1G08 v.4
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74HC_HCT1G08 v.4
20070717
Modifications:
• The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
• Package SOT353 changed to SOT353-1 in Table 1 and Figure 7.
• Quick Reference Data and Soldering sections removed.
• Section 2 "Features" updated.
74HC_HCT1G08 v.3
20020517
Product specification
74HC_HCT1G08 v.2
74HC_HCT1G08 v.2
20010302
74HC_HCT1G08 v.1
74HC_HCT1G08 v.1
19981110
Preliminary specification
74HC_HCT1G08
Product data sheet
Product data sheet
74HC_HCT1G08 v.3
9 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
15 Legal information
15.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74HC_HCT1G08
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
10 / 12
74HC1G08; 74HCT1G08
Nexperia
2-input AND gate
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74HC_HCT1G08
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
Nexperia
74HC1G08; 74HCT1G08
2-input AND gate
Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
11.1
12
13
14
15
General description ............................................ 1
Features ............................................................... 1
Ordering information .......................................... 1
Marking .................................................................2
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 3
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 4
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveform and test circuit ..................................6
Package outline ...................................................7
Abbreviations ...................................................... 9
Revision history .................................................. 9
Legal information .............................................. 10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 March 2018
Document identifier: 74HC_HCT1G08
很抱歉,暂时无法提供与“74HCT1G08GW,125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.54902
- 25+1.53410
- 100+0.75916
- 250+0.75126
- 500+0.70123
- 1000+0.57134
- 3000+0.35983
