74HCT1G86GW,125
74HCT1G86GW,125
    NEXPERIA(安世)
    TSSOP5_2.25X1.35MM
    电压电平转换器 5V 20μA TSSOP5_2.25X1.35MM
74HCT1G86GW,125 数据手册
74HC1G86; 74HCT1G86 2-input EXCLUSIVE-OR gate Rev. 04 — 20 July 2007 Product data sheet 1. General description 74HC1G86 and 74HCT1G86 are high-speed Si-gate CMOS devices. They provide a 2-input EXCLUSIVE-OR function. The HC device has CMOS input switching levels and supply voltage range 2 V to 6 V. The HCT device has TTL input switching levels and supply voltage range 4.5 V to 5.5 V. The standard output currents are half those of the 74HC/HCT86. 2. Features n n n n n n Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays SOT353-1 and SOT753 package options Specified from −40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number 74HC1G86GW Package Temperature range Name Description Version −40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 −40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 74HCT1G86GW 74HC1G86GV 74HCT1G86GV 4. Marking Table 2. Marking codes Type number Marking 74HC1G86GW HH 74HCT1G86GW TH 74HC1G86GV H86 74HCT1G86GV T86 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 5. Functional diagram 1 2 B A Y 1 4 =1 4 2 mna039 mna038 Fig 1. Logic symbol Fig 2. IEC logic symbol B Y A mna040 Fig 3. Logic diagram 6. Pinning information 6.1 Pinning 74HC1G86 B 1 A 2 GND 3 5 VCC 4 Y 001aaf055 Fig 4. Pin configuration 6.2 Pin description Table 3. Pin description Symbol Pin Description B 1 data input A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 2 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Inputs Output A B Y L L L L H H H L H H H L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). [1] Symbol Parameter VCC supply voltage IIK input clamping current IOK Min Max Unit −0.5 +7.0 V VI < −0.5 V or VI > VCC + 0.5 V - ±20 mA output clamping current VO < −0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current −0.5 V < VO < VCC + 0.5 V - ±12.5 mA ICC supply current - 25 mA IGND ground current −25 - mA Tstg storage temperature −65 +150 °C - 200 mW total power dissipation Ptot Conditions Tamb = −40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 °C the value of Ptot derates linearly with 2.5 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 74HC1G86 74HCT1G86 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V input voltage 0 - VCC 0 - VCC V output voltage 0 - VCC 0 - VCC V VCC supply voltage VI VO Tamb ambient temperature ∆t/∆V input transition rise and fall rate −40 +25 +125 −40 +25 +125 VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - - 139 - - 139 ns/V VCC = 6.0 V - - 83 - - - ns/V © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 °C Nexperia B.V. 2017. All rights reserved 3 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - V For type 74HC1G86 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 2.0 V - 0.8 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 V VI = VIH or VIL IO = −20 µA; VCC = 2.0 V 1.9 2.0 - 1.9 - V IO = −20 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = −20 µA; VCC = 6.0 V 5.9 6.0 - 5.9 - V IO = −2.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = −2.6 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 µA; VCC = 2.0 V - 0 0.1 - 0.1 V IO = 20 µA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 20 µA; VCC = 6.0 V - 0 0.1 - 0.1 V IO = 2.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 2.6 mA; VCC = 6.0 V - 0.16 0.33 - 0.4 V VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 µA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 - 20 µA CI input capacitance - 1.5 - - - pF For type 74HCT1G86 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL IO = −20 µA; VCC = 4.5 V 4.4 4.5 - 4.4 - V IO = −2.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V VOL II LOW-level output voltage input leakage current VI = VIH or VIL IO = 20 µA; VCC = 4.5 V - 0 0.1 - 0.1 V IO = 2.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 µA © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 4 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate Table 7. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Min Typ Max Min Max Unit ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 10 - 20 µA ∆ICC additional supply current per input; VCC = 4.5 V to 5.5 V; VI = VCC − 2.1 V; IO = 0 A - - 500 - 850 µA CI input capacitance - 1.5 - - - pF 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf ≤ 6.0 ns; All typical values are measured at Tamb = 25 °C. For test circuit see Figure 6 Symbol Parameter −40 °C to +85 °C Conditions −40 °C to +125 °C Unit Min Typ Max Min Max For type 74HC1G86 tpd propagation delay A and B to Y; see Figure 5 [1] VCC = 2.0 V; CL = 50 pF - 22 115 - 135 ns VCC = 4.5 V; CL = 50 pF - 11 23 - 27 ns VCC = 5.0 V; CL = 15 pF - 9 - - - ns - 9 20 - 23 ns - 23 - - - pF VCC = 4.5 V; CL = 50 pF - 13 23 - 27 ns VCC = 5.0 V; CL = 15 pF - 10 - - - ns - 23 - - - pF VCC = 6.0 V; CL = 50 pF CPD [2] power dissipation VI = GND to VCC capacitance For type 74HCT1G86 tpd CPD propagation delay A and B to Y; see Figure 5 power dissipation VI = GND to VCC − 1.5 V capacitance [1] tpd is the same as tPLH and tPHL. [2] CPD is used to determine the dynamic power dissipation PD (µW). PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts ∑ (CL × VCC2 × fo) = sum of outputs [1] [2] © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 5 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 12. Waveforms VM A, B input tPHL tPLH VM Y output mna041 For 74HC1G86: VM = 0.5 × VCC; VI = GND to VCC. For 74HCT1G86: VM = 1.3 V; VI = GND to 3.0 V. Fig 5. The input (A and B) to output (Y) propagation delays VCC PULSE GENERATOR VI VO DUT RT CL 50 pF mna034 Test data is given in Table 8. Definitions for test circuit: CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 6. Load circuitry for switching times © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 6 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 13. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm E D SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 L e w M bp detail X e1 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Fig 7. Package outline SOT353-1 (TSSOP5) © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 7 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate Plastic surface-mounted package; 5 leads SOT753 D E B y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Fig 8. Package outline SOT753 (SC-74A) © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 8 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 14. Abbreviations Table 9. Abbreviations Acronym Description DUT Device Under Test TTL Transistor-Transistor Logic 15. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT1G86_4 20070720 Product data sheet - 74HC_HCT1G86_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • Legal texts have been adapted to the new company name where appropriate. Package SOT353 changed to SOT353-1 in Table 1 and Figure 7. Quick Reference Data and Soldering sections removed. Section 2 “Features” updated. 74HC_HCT1G86_3 20020515 Product specification - 74HC_HCT1G86_2 74HC_HCT1G86_2 20010406 Product specification - 74HC_HCT1G86_1 74HC_HCT1G86_1 19980805 Product specification - - © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 9 of 11 74HC1G86; 74HCT1G86 Nexperia 2-input EXCLUSIVE-OR gate 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 16.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 74HC_HCT1G86_4 Product data sheet Rev. 04 — 20 July 2007 Nexperia B.V. 2017. All rights reserved 10 of 11 Nexperia 74HC1G86; 74HCT1G86 2-input EXCLUSIVE-OR gate 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 3 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 July 2007 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC1G86GV,125 74HC1G86GW,125 74HCT1G86GV,125 74HCT1G86GW,125
74HCT1G86GW,125 价格&库存
很抱歉,暂时无法提供与“74HCT1G86GW,125”相匹配的价格&库存,您可以联系我们找货
74HCT1G86GW,125
    74HCT1G86GW,125
    • 3000+0.693703000+0.08960
    • 6000+0.624406000+0.08060
    • 15000+0.5890015000+0.07600
    • 30000+0.4478030000+0.05780
    • 75000+0.4427075000+0.05720
    • 150000+0.43770150000+0.05650
    库存:12000
