74HC27D,653
74HC27D,653
    NEXPERIA(安世)
    SOIC-14
    三路3输入NOR门
74HC27D,653 数据手册
74HC27; 74HCT27 Triple 3-input NOR gate Rev. 5.1 — 27 November 2015 Product data sheet 1. General description The 74HC27; 74HCT27 is a triple 3-input NOR gate. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard no. 7A  Input levels:  For 74HC27: CMOS level  For 74HCT27: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package 74HC27D Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HCT27D 74HC27DB 74HCT27DB 74HC27PW 74HCT27PW 74HC27BQ 74HCT27BQ SOT762-1 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate 4. Functional diagram    $  %  &  $  %  &  $  %  &    <    $ •  < %  & PQD PQD Fig 1. •   <    < • Logic symbol Fig 2. IEC logic symbol PQD Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning +& +&7  $ WHUPLQDO LQGH[DUHD $   9&& %   &  9&& +& +&7 %   & $   <   &  <    &   % <   $  & % & *1'   < <  <   *1' $ % *1'   %  $ DDD 7UDQVSDUHQWWRSYLHZ DDJ (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 4. Pin configuration SO14, (T)SSOP14 74HC_HCT27 Product data sheet Fig 5. Pin configuration DHVQFN14 All information provided in this document is subject to legal disclaimers. Rev. 5.1 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 2 of 16 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 9 data input 1B, 2B, 3B 2, 4, 10 data input 1C, 2C, 3C 13, 5, 11 data input 1Y, 2Y, 3Y 12, 6, 8 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Inputs Outputs nA nB nC nY L L L H X X H L X H X L H X X L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current 0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW IIK SO14, (T)SSOP14 and DHVQFN14 packages [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT27 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5.1 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 3 of 16 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC27 Min Typ 74HCT27 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics type 74HC27; 74HCT27 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V 74HC27 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - 0.1 - 1.0 - 1.0 A - - 2.0 - 20 - 40 A II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V 74HC_HCT27 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 5.1 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 4 of 16 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate Table 6. Static characteristics type 74HC27; 74HCT27 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT27 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 4.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.16 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A - - 2.0 - 20 - 40 A - 150 540 - 675 - 735 A - 3.5 - - - - - pF II input leakage current ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A ICC additional per input pin; supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A nA, nB or nC inputs CI input capacitance 74HC_HCT27 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5.1 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 5 of 16 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate 10. Dynamic characteristics Table 7. Dynamic characteristics type 74HC27; 74HCT27 GND = 0 V; for load circuit see Figure 7. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) - 28 90 115 135 VCC = 4.5 V - 10 18 23 27 ns VCC = 5.0 V; CL = 15 pF - 8 - - - ns - 8 15 20 23 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 24 - - - pF - 12 21 26 32 ns 74HC27 propagation delay nA, nB, nC to nY; see Figure 6 tpd [1] VCC = 2.0 V VCC = 6.0 V transition time tt [2] see Figure 6 VCC = 6.0 V per package; VI = GND to VCC [3] propagation delay nA, nB, nC to nY; see Figure 6 [1] power dissipation capacitance CPD ns 74HCT27 tpd VCC = 4.5 V VCC = 5.0 V; CL = 15 pF transition time tt power dissipation capacitance CPD - 10 - - - ns VCC = 4.5 V; see Figure 6 [2] - 7 15 19 22 ns per package; VI = GND to VCC  1.5 V [3] - 30 - - - pF [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 74HC_HCT27 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5.1 — 27 November 2015 © Nexperia B.V. 2017. All rights reserved 6 of 16 74HC27; 74HCT27 Nexperia Triple 3-input NOR gate 11. Waveforms 9, Q$Q%Q&LQSXW 90 *1' W3+/ 92+ W3/+ 9< 90 9; Q
74HC27D,653 价格&库存
很抱歉,暂时无法提供与“74HC27D,653”相匹配的价格&库存,您可以联系我们找货
74HC27D,653
  • 1+2.06800
  • 100+1.59500
  • 1250+1.37500
  • 2500+1.32000
库存:54
74HC27D,653
  • 2500+1.006312500+0.13079
  • 5000+0.974695000+0.12668
  • 7500+0.958857500+0.12462
  • 12500+0.9412912500+0.12234
  • 17500+0.9310417500+0.12101
  • 25000+0.9211725000+0.11973
库存:1457
74HC27D,653
    • 1+2.60680
    • 10+2.04820
    • 30+1.81300
    库存:84
