74HCT2G14GW-Q100H
74HCT2G14GW-Q100H
    NEXPERIA(安世)
    SOT363-6
    电压电平转换器 5V 20μA SOT363-6
74HCT2G14GW-Q100H 数据手册
74HC2G14-Q100; 74HCT2G14-Q100 Dual inverting Schmitt trigger Rev. 1 — 20 March 2014 Product data sheet 1. General description The 74HC2G14-Q100; 74HCT2G14-Q100 is a dual inverter with Schmitt trigger inputs. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 2.0 V to 6.0 V  Complies with JEDEC standard no. 7A  Input levels:  For 74HC2G14-Q100: CMOS level  For 74HCT2G14-Q100: TTL level  High noise immunity  Low power dissipation  Balanced propagation delays  Unlimited input rise and fall times  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Applications  Wave and pulse shaper for highly noisy environments  Astable multivibrators  Monostable multivibrators 74HC2G14-Q100; 74HCT2G14-Q100 Nexperia Dual inverting Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC2G14GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74HC2G14GV-Q100 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G14GW-Q100 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 40 C to +125 C SC-74 plastic surface-mounted package (TSOP6); 6 leads SOT457 74HCT2G14GV-Q100 5. Marking Table 2. Marking codes Type number Marking code[1] 74HC2G14GW-Q100 HK 74HC2G14GV-Q100 H14 74HCT2G14GW-Q100 TK 74HCT2G14GV-Q100 T14 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram   $ $ < <   Logic symbol 74HC_HCT2G14_Q100 Product data sheet  $   $ < < PQE PQE PQE Fig 1.  Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 Fig 3. Logic diagram © Nexperia B.V. 2017. All rights reserved 2 of 21 74HC2G14-Q100; 74HCT2G14-Q100 Nexperia Dual inverting Schmitt trigger 7. Pinning information 7.1 Pinning +&*4 +&7*4 $   < *1'   9&& $   < DDD Fig 4. Pin configuration 7.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 8. Functional description Table 4. Function table[1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level. 74HC_HCT2G14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 © Nexperia B.V. 2017. All rights reserved 3 of 21 74HC2G14-Q100; 74HCT2G14-Q100 Nexperia Dual inverting Schmitt trigger 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] - 20 mA output current VO = 0.5 V to VCC + 0.5 V [1] - 25 mA supply current [1] - +50 mA IGND ground current [1] 50 - mA Tstg storage temperature 65 +150 C - 250 mW IO ICC [2] total power dissipation Ptot [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit 74HC2G14-Q100 VCC supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 74HCT2G14-Q100 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C 74HC_HCT2G14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 © Nexperia B.V. 2017. All rights reserved 4 of 21 Nexperia 74HC2G14-Q100; 74HCT2G14-Q100 Dual inverting Schmitt trigger 11. Static characteristics Table 7. Static characteristics for 74HC2G14-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = 5.2 mA; VCC = 6.0 V 5.68 5.81 - V IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V Tamb = 25 C VOH VOL HIGH-level output voltage VI = VT+ or VT LOW-level output voltage VI = VT+ or VT II input leakage current VI = GND or VCC; VCC = 6.0 V - - 0.1 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 1.0 A CI input capacitance - 2.0 - pF IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4.0 mA; VCC = 4.5 V 4.13 - - V IO = 5.2 mA; VCC = 6.0 V 5.63 - - V IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V Tamb = 40 C to +85 C VOH VOL HIGH-level output voltage VI = VT+ or VT LOW-level output voltage VI = VT+ or VT II input leakage current VI = GND or VCC; VCC = 6.0 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 10.0 A 74HC_HCT2G14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 © Nexperia B.V. 2017. All rights reserved 5 of 21 Nexperia 74HC2G14-Q100; 74HCT2G14-Q100 Dual inverting Schmitt trigger Table 7. Static characteristics for 74HC2G14-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 40 C to +125 C VOH VOL HIGH-level output voltage VI = VT+ or VT IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4.0 mA; VCC = 4.5 V 3.7 - - V IO = 5.2 mA; VCC = 6.0 V 5.2 - - V IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V LOW-level output voltage VI = VT+ or VT IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = GND or VCC; VCC = 6.0 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 6.0 V - - 20.0 A Min Typ Max Unit IO = 20 A; VCC = 4.5 V 4.4 4.5 - V IO = 4.0 mA; VCC = 4.5 V 4.18 4.32 - V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 V VI = GND or VCC; VCC = 5.5 V - - 0.1 A Table 8. Static characteristics for 74HCT2G14-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = 25 C VOH VOL HIGH-level output voltage VI = VT+ or VT LOW-level output voltage VI = VT+ or VT II input leakage current ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 1.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 300 A CI input capacitance - 2.0 - pF 74HC_HCT2G14_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 © Nexperia B.V. 2017. All rights reserved 6 of 21 74HC2G14-Q100; 74HCT2G14-Q100 Nexperia Dual inverting Schmitt trigger Table 8. Static characteristics for 74HCT2G14-Q100 …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit Tamb = 40 C to +85 C VOH VOL HIGH-level output voltage VI = VT+ or VT IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 4.0 mA; VCC = 4.5 V 4.13 - - V - - 0.1 V LOW-level output voltage VI = VT+ or VT IO = 20 A; VCC = 4.5 V IO = 4.0 mA; VCC = 4.5 V - - 0.33 V II input leakage current VI = GND or VCC; VCC = 5.5 V - - 1.0 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 10.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 375 A IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 4.0 mA; VCC = 4.5 V 3.7 - - V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.4 V VI = GND or VCC; VCC = 5.5 V - - 1.0 A Tamb = 40 C to +125 C VOH VOL HIGH-level output voltage VI = VT+ or VT LOW-level output voltage VI = VT+ or VT II input leakage current ICC supply current VI = GND or VCC; IO = 0 A; VCC = 5.5 V - - 20.0 A ICC additional supply current VI = VCC  2.1 V; VCC = 4.5 V to 5.5 V; IO = 0 A - - 410 A 12. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) VCC = 2.0 V; CL = 50 pF - 53 125 - 155 190 ns VCC = 4.5 V; CL = 50 pF - 16 25 - 31 38 ns VCC = 6.0 V; CL = 50 pF - 13 21 - 26 32 ns VCC = 2.0 V; CL = 50 pF - 20 75 - 95 110 ns VCC = 4.5 V; CL = 50 pF - 7 15 - 19 22 ns VCC = 6.0 V; CL = 50 pF - 5 13 - 16 19 ns - 10 - - - - pF 74HC2G14-Q100 tpd tt CPD propagation delay transition time power dissipation capacitance 74HC_HCT2G14_Q100 Product data sheet nA to nY; see Figure 5 [1] nY; see Figure 5 VI = GND to VCC [1] [2] All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 March 2014 © Nexperia B.V. 2017. All rights reserved 7 of 21 74HC2G14-Q100; 74HCT2G14-Q100 Nexperia Dual inverting Schmitt trigger Table 9. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Min Max (85 C) Max (125 C) - 21 32 - 40 48 ns - 6 15 - 19 22 ns - 10 - - - - pF 74HCT2G14-Q100 propagation delay tpd [1] nA to nY; see Figure 5 VCC = 4.5 V; CL = 50 pF [1] tt transition time nY; see Figure 5 CPD power dissipation capacitance VI = GND to VCC  1.5 V VCC = 4.5 V; CL = 50 pF [2] [1] tpd is the same as tPLH and tPHL; tt is the same as tTLH and tTHL. [2] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 13. Waveforms and test circuit 9, Q$LQSXW 90 90 *1' W 3+/ W 3/+ 92+ Q
74HCT2G14GW-Q100H 价格&库存
很抱歉,暂时无法提供与“74HCT2G14GW-Q100H”相匹配的价格&库存,您可以联系我们找货
74HCT2G14GW-Q100H
  • 1+3.350191+0.40572
  • 10+2.3160910+0.28049
  • 25+2.0657125+0.25017
  • 100+1.78504100+0.21618
  • 250+1.65137250+0.19999
  • 500+1.57075500+0.19023
  • 1000+1.504531000+0.18221
库存:4192
74HCT2G14GW-Q100H
  • 3000+1.422563000+0.17228
  • 6000+1.382476000+0.16742
  • 9000+1.362399000+0.16499
  • 15000+1.3401415000+0.16230
  • 21000+1.3271221000+0.16072
  • 30000+1.3146330000+0.15921
库存:4192
