74HC30; 74HCT30
8-input NAND gate
Rev. 7 — 2 December 2015
Product data sheet
1. General description
The 74HC30; 74HCT30 is an 8-input NAND gate. Inputs include clamp diodes. This
enables the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
2. Features and benefits
Complies with JEDEC standard JESD7A
Input levels:
For 74HC30: CMOS level
For 74HCT30: TTL level
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
74HC30D
Package
Temperature range Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT30D
74HC30DB
74HCT30DB
74HC30PW
74HCT30PW
74HC30; 74HCT30
Nexperia
8-input NAND gate
4. Functional diagram
PQD
Fig 1.
PQD
Logic symbol
Fig 2.
IEC logic symbol
PQD
Fig 3.
Logic diagram
74HC_HCT30
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC30; 74HCT30
Nexperia
8-input NAND gate
5. Pinning information
5.1 Pinning
+&7
9&&
QF
QF
QF
*1'
DDO
Fig 4.
Pin configuration SO14 and (T)SSOP14
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
A
1
data input
B
2
data input
C
3
data input
D
4
data input
E
5
data input
F
6
data input
GND
7
ground (0 V)
Y
8
data output
n.c.
9
not connected
n.c.
10
not connected
G
11
data input
H
12
data input
n.c.
13
not connected
VCC
14
supply voltage
74HC_HCT30
Product data sheet
3 of 15
74HC30; 74HCT30
Nexperia
8-input NAND gate
6. Functional description
Table 3.
Function table[1]
Input
Output
A
B
C
D
E
F
G
H
Y
L
X
X
X
X
X
X
X
H
X
L
X
X
X
X
X
X
H
X
X
L
X
X
X
X
X
H
X
X
X
L
X
X
X
X
H
X
X
X
X
L
X
X
X
H
X
X
X
X
X
L
X
X
H
X
X
X
X
X
X
L
X
H
X
X
X
X
X
X
X
L
H
H
H
H
H
H
H
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
IGND
ground current
Tstg
storage temperature
total power dissipation
Ptot
Conditions
SO14, (T)SSOP14 packages
Min
Max
0.5
+7
V
[1]
mA
[1]
mA
25
mA
50
mA
50
mA
65
+150
C
500
mW
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
Unit
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT30
Product data sheet
4 of 15
74HC30; 74HCT30
Nexperia
8-input NAND gate
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC30
Min
Typ
74HCT30
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+125
40
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
40 C to +85 C 40 C to +125 C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
74HC30
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2.0
A
74HC_HCT30
Product data sheet
5 of 15
74HC30; 74HCT30
Nexperia
8-input NAND gate
Table 6.
Static characteristics …continued
Symbol Parameter
CI
25 C
Conditions
input
capacitance
Min
Typ
Max
Min
Max
Min
Max
3.5
pF
74HCT30
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.98
4.32
3.84
3.7
V
LOW-level
output voltage
IO = 20 A
0.1
0.1
V
IO = 4.0 mA
0.15
0.26
0.33
0.4
V
VOL
II
input leakage
current
VI = VCC or GND;
VCC = 5.5 V
0.1
1
1
A
ICC
supply current
VCC = 5.5 V
2.0
A
ICC
additional
supply current
per input pin;
VI = VCC 2.4 V; IO = 0 A;
other inputs at VCC or GND;
60
216
275
294
A
CI
input
capacitance
3.5
pF
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for test circuit see Figure 6.
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
VCC = 2.0 V
41
130
165
195
ns
VCC = 4.5 V
15
26
33
39
ns
VCC = 5.0 V; CL = 15 pF
12
ns
12
22
28
33
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
74HC30
tpd
propagation delay A, B, C, D, E, F, G, H to Y;
see Figure 5
[1]
VCC = 6.0 V
tt
transition time
74HC_HCT30
Product data sheet
see Figure 5
[2]
6 of 15
74HC30; 74HCT30
Nexperia
8-input NAND gate
Table 7.
Dynamic characteristics …continued
Symbol Parameter
CPD
25 C
Conditions
power dissipation
capacitance
[3]
per package; VI = GND to VCC
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
15
pF
16
28
35
42
ns
74HCT30
[1]
see Figure 5
tpd
VCC = 4.5 V
transition time
tt
power dissipation
capacitance
CPD
[1]
12
ns
VCC = 4.5 V; see Figure 5
[2]
7
15
19
22
ns
per package;
VI = GND to VCC 1.5 V
[3]
15
pF
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
9,
LQSXW
*1'
90
W3+/
92+
W3/+
9<
90
Q
很抱歉,暂时无法提供与“74HCT30D,652”相匹配的价格&库存,您可以联系我们找货
