74HCT32BQ-Q100,115
74HCT32BQ-Q100,115
    NEXPERIA(安世)
    DHVQFN-14-EP(2.5x3)
    电压电平转换器 5V 40μA DHVQFN14_3X2.5MM-EP
74HCT32BQ-Q100,115 数据手册
74HC32-Q100; 74HCT32-Q100 Quad 2-input OR gate Rev. 2 — 30 September 2019 Product data sheet 1. General description The 74HC32-Q100; 74HCT32-Q100 is a quad 2-input OR gate. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range from 2.0 V to 6.0 V Complies with JEDEC standard JESD7A Symmetrical output impedance High noise immunity Low power dissipation Balanced propagation delays Input levels: • For 74HC32-Q100: CMOS level • For 74HCT32-Q100: TTL level ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) Multiple package options 3. Ordering information Table 1. Ordering information Type number Package 74HC32D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm SOT762-1 74HCT32D-Q100 74HC32PW-Q100 74HCT32PW-Q100 74HC32BQ-Q100 74HCT32BQ-Q100 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate 4. Functional diagram 1 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 4 1Y 3 5 2Y 6 9 3Y 8 4Y 11 10 12 3 ≥1 6 ≥1 8 ≥1 11 A 13 Y B mna243 mna242 Fig. 1. ≥1 Logic symbol Fig. 2. IEC logic symbol mna241 Fig. 3. Logic diagram (one gate) 5. Pinning information 5.1. Pinning 1 2 13 4B 3 2A 4 2B 5 2Y 6 11 4Y GND(1) 1Y 3 12 4A 2A 4 11 4Y 2B 5 10 3B 2Y 6 9 7 8 Product data sheet 9 3A aaa-004223 (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 3Y aaa-004222 74HC_HCT32_Q100 10 3B Transparent top view 3A Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) 13 4B 12 4A 8 1B 1Y 7 14 VCC 2 3Y 1 1B GND 1A GND Fig. 4. 1A terminal 1 index area 74HC32-Q100 74HCT32-Q100 14 VCC 74HC32-Q100 74HCT32-Q100 Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 2 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10,13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Output Input nA nB nY L L L L H H H L H H H H 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) packages: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) packages: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) packages: Ptot derates linearly with 9.6 mW/K above 98 °C. 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 3 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC32-Q100 74HCT32-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V 74HC32-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT32_Q100 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 4 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74HCT32-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.25 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA IO = -4.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA IO = 5.2 mA II input leakage current VI = VCC or GND; VCC = 5.5 V ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2.0 - 20 - 40 μA ΔICC additional per input pin; supply current VI = VCC - 2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - - 430 - 540 - 590 μA CI input capacitance - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for test circuit see Fig. 7. Symbol Parameter Conditions -40 °C to +85 °C 25 °C Min Typ Max -40 °C to Unit +125 °C Max Max 74HC32-Q100 tpd propagation delay nA, nB to nY; see Fig. 6 [1] VCC = 2.0 V - 22 90 115 135 ns VCC = 4.5 V - 8 18 23 27 ns VCC = 5.0 V; CL = 15 pF - 6 - - - ns - 6 15 20 23 ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns VCC = 6.0 V - 6 13 16 19 ns - 16 - - - pF VCC = 6.0 V tt CPD transition time power dissipation capacitance 74HC_HCT32_Q100 Product data sheet see Fig. 6 [2] per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 5 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate Symbol Parameter Conditions -40 °C to +85 °C 25 °C Min Typ Max -40 °C to Unit +125 °C Max Max 74HCT32-Q100 propagation delay nA, nB to nY; see Fig. 6 tpd [1] VCC = 4.5 V - 11 24 30 36 ns VCC = 5.0 V; CL = 15 pF - 9 - - - ns tt transition time VCC = 4.5 V; see Fig. 6 [2] - 7 15 19 22 ns CPD power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] - 28 - - - pF [1] [2] [3] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + Σ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ (CL × VCC × fo) = sum of outputs. 10.1. Waveforms VI nA, nB input VM GND tPHL VOH VY nY output VOL tTHL tPLH VM VX tTLH aaa-004037 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Input to output propagation delays and output transition times Table 8. Measurement points Input Type Output VM VM VX VY 74HC32-Q100 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT32-Q100 1.3 V 1.3 V 0.1VCC 0.9VCC 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 6 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 7. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC32-Q100 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT32-Q100 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 7 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 8 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 9 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 10. Package outline SOT762-1 (DHVQFN14) 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 10 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT32_Q100 v.2 20190930 Product data sheet - Modifications: • • • • 74HC_HCT32_Q100 v.1 74HC_HCT32_Q100 Product data sheet 74HC_HCT32_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 4: Derating values for Ptot total power dissipation have changed. Package outline drawing SOT762-1 (DHVQFN14) updated. 20120801 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 - © Nexperia B.V. 2019. All rights reserved 11 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 12 / 13 74HC32-Q100; 74HCT32-Q100 Nexperia Quad 2-input OR gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms.................................................................6 11. Package outline.......................................................... 8 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 September 2019 74HC_HCT32_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 30 September 2019 © Nexperia B.V. 2019. All rights reserved 13 / 13 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC32D-Q100,118 74HCT32BQ-Q100,115 74HCT32D-Q100,118 74HCT32PW-Q100,118 74HC32BQ-Q100,115 74HC32PW-Q100,118
74HCT32BQ-Q100,115 价格&库存
很抱歉,暂时无法提供与“74HCT32BQ-Q100,115”相匹配的价格&库存,您可以联系我们找货
