74HC3G04-Q100;
74HCT3G04-Q100
Triple inverter
Rev. 3 — 26 November 2018
Product data sheet
1. General description
The 74HC3G04-Q100; 74HCT3G04-Q100 is a triple inverter. Inputs include clamp diodes. This
enables the use of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 6.0 V
Input levels:
• For 74HC3G04-Q100: CMOS level
• For 74HCT3G04-Q100: TTL level
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF; R = 0 Ω)
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC3G04DP-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74HCT3G04DP-Q100
74HC3G04DC-Q100
74HCT3G04DC-Q100
Nexperia
Triple inverter
4. Marking
Table 2. Marking codes
Type number
Marking code[1]
74HC3G04DP-Q100
H04
74HCT3G04DP-Q100
T04
74HC3G04DC-Q100
H04
74HCT3G04DC-Q100
T04
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
1A
1Y
1
1
7
3
1
5
6
1
2
7
3
2A
2Y
5
6
3A
3Y
2
Y
A
mna720
Fig. 1.
Logic symbol
mna721
Fig. 2.
mna110
IEC logic symbol
Fig. 3.
Logic diagram (one gate)
6. Pinning information
6.1. Pinning
74HC3G04
74HCT3G04
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aai257
Fig. 4.
Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
GND
4
ground (0 V)
1Y, 2Y, 3Y
7, 5, 2
data output
VCC
8
supply voltage
74HC_HCT3G04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 12
Nexperia
Triple inverter
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nY
L
H
H
L
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
[1]
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
[1]
25
mA
ICC
supply current
[1]
50
mA
IGND
ground current
[1]
-50
mA
Tstg
storage temperature
-65
+150
°C
PD
dynamic power dissipation
300
mW
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
74HC3G04-Q100
74HCT3G04-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and VCC = 2.0 V
fall rate
VCC = 4.5 V
625
ns/V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT3G04_Q100
Product data sheet
3 / 12
Nexperia
Triple inverter
10. Static characteristics
Table 7. Static characteristics
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
VCC = 2.0 V
1.5
1.2
VCC = 4.5 V
3.15
2.4
1.5
3.15
VCC = 6.0 V
4.2
3.2
VCC = 2.0 V
0.8
VCC = 4.5 V
-40 °C to +125 °C Unit
Min
Max
1.5
V
3.15
V
4.2
4.2
V
0.5
0.5
0.5
V
2.1
1.35
1.35
1.35
V
74HC3G04-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
4.18
4.32
4.13
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.68
5.81
5.63
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
II
input leakage
current
ICC
supply current per input pin; VCC = 6.0 V;
VI = VCC or GND; IO = 0 A;
1.0
10
μA
CI
input
capacitance
1.5
pF
74HC_HCT3G04_Q100
Product data sheet
VI = VCC or GND; VCC = 6.0 V
4 / 12
Nexperia
Triple inverter
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT3G04-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL
HIGH-level
output voltage
4.4
4.5
4.4
4.4
V
4.18
4.32
4.13
3.7
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
VOL
VI = VIH or VIL
LOW-level
output voltage
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
ICC
supply current per input pin; VCC = 5.5 V;
1.0
10
μA
ΔICC
additional
per input;
supply current VCC = 4.5 V to 5.5 V;
VI = VCC - 2.1 V; IO = 0 A
300
375
410
μA
CI
input
capacitance
1.5
pF
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); all typical values are measured at Tamb = 25 °C; for test circuit see Fig. 6.
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
22
75
90
110
ns
VCC = 4.5 V
8
15
18
22
ns
VCC = 6.0 V
6
13
16
ns
VCC = 2.0 V
18
75
95
125
ns
VCC = 4.5 V
6
15
19
25
ns
5
13
16
ns
9
pF
74HC3G04-Q100
tpd
tt
propagation
delay
nA to nY; see Fig. 5
transition time see Fig. 5
[1]
[2]
VCC = 6.0 V
CPD
power
dissipation
capacitance
74HC_HCT3G04_Q100
Product data sheet
VI = GND to VCC
[3]
5 / 12
Nexperia
Triple inverter
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
10
18
23
29
ns
74HCT3G04-Q100
tpd
propagation
delay
[1]
VCC = 4.5 V
tt
transition time VCC = 4.5 V; see Fig. 5
[2]
6
15
19
22
ns
CPD
power
dissipation
capacitance
[3]
9
pF
[1]
[2]
[3]
VI = GND to VCC - 1.5 V
tpd is the same as tPLH and tPHL.
tt is the same as tTLH and tTHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
11.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
90 %
VM
nY output
VM
10 %
VOL
t THL
t TLH
mna722
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5.
The data input (nA) to output (nY) propagation delays
Table 9. Measurement points
Type
Input
Output
VM
VM
74HC3G04-Q100
0.5 × VCC
0.5 × VCC
74HCT3G04-Q100
1.3 V
1.3 V
74HC_HCT3G04_Q100
Product data sheet
6 / 12
Nexperia
Triple inverter
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VCC
VO
DUT
RT
RL
S1
open
CL
001aad983
Test data is given in Table 10.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance; RL = Load resistance; S1 = Test selection switch.
Fig. 6.
Test circuit for measuring switching times
Table 10. Test data
Type
Input
S1 position
Load
VI
tr, tf
CL
RL
tPHL, tPLH
VCC
≤ 6 ns
50 pF
1 kΩ
open
74HCT3G04-Q100 3 V
≤ 6 ns
50 pF
1 kΩ
open
74HC3G04-Q100
74HC_HCT3G04_Q100
Product data sheet
7 / 12
Nexperia
Triple inverter
12. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
Fig. 7.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Package outline SOT505-2 (TSSOP8)
74HC_HCT3G04_Q100
Product data sheet
8 / 12
Nexperia
Triple inverter
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
Fig. 8.
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Package outline SOT765-1 (VSSOP8)
74HC_HCT3G04_Q100
Product data sheet
9 / 12
Nexperia
Triple inverter
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT3G04_Q100 v.3
20181126
Product data sheet
74HC_HCT3G04_Q100 v.2
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC3G04GD-Q100 and 74HCT3G04GD-Q100 (SOT996-2/XSON8)
removed
20131118
Modifications:
74HC_HCT3G04_Q100 v.1
20120827
74HC_HCT3G04_Q100
Product data sheet
Product data sheet
Added type numbers 74HC3G04GD-Q100 and 74HCT3G04GD-Q100 (XSON8 package)
Product data sheet
10 / 12
Nexperia
Triple inverter
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT3G04_Q100
Product data sheet
11 / 12
Nexperia
Triple inverter
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Package outline.......................................................... 8
13. Abbreviations............................................................ 10
14. Revision history........................................................10
15. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 26 November 2018
74HC_HCT3G04_Q100
Product data sheet
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC3G04GD-Q100H 74HCT3G04GD-Q100H 74HC3G04DP-Q100H 74HCT3G04DC-Q100H 74HCT3G04DPQ100H 74HC3G04DC-Q100H
