74HC4002; 74HCT4002
Dual 4-input NOR gate
Rev. 5 — 26 May 2016
Product data sheet
1. General description
The 74HC4002; 74HCT4002 is a dual 4-input NOR gate. Inputs also include clamp diodes
that enable the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
2. Features and benefits
Complies with JEDEC standard JESD7A
Low-power dissipation
Input levels:
For 74HC4002: CMOS level
For 74HCT4002: TTL level
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +80 C and from 40 C to +125 C.
3. Ordering information
Table 1.
Type number
74HC4002D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body
width 5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT4002D
74HC4002DB
74HCT4002DB
74HC4002PW
74HC4002; 74HCT4002
Nexperia
4. Functional diagram
DDD
Fig 1.
Functional diagram
Fig 2.
DDD
Logic symbol
DDD
DDD
Fig 3.
IEC Logic symbol
Fig 4.
Logic diagram
5. Pinning information
5.1 Pinning
+&7
9&&
QF
*1'
QF
+&7
9&&
QF
*1'
QF
DDD
Fig 5.
Pin configuration SOT108-1
74HC_HCT4002
Product data sheet
DDD
Fig 6.
Pin configuration SOT337-1 and SOT402-1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74HC4002; 74HCT4002
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Y
1
data output
1A, 1B, 1C, 1D
2, 3, 4, 5
data input
n.c.
6, 8
not connected
GND
7
ground (0 V)
2Y
13
data output
2A, 2B, 2C, 2D
9, 10, 11, 12
data input
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nB
nC
nD
nY
L
L
L
L
H
H
X
X
X
L
X
H
X
X
L
X
X
H
X
L
X
X
X
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
mA
IO
output current
0.5 V < VO < VCC + 0.5 V
25
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
SO14, and (T)SSOP14 packages
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT4002
Product data sheet
3 of 15
74HC4002; 74HCT4002
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC4002
Min
Typ
74HCT4002
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
Min
Typ
VCC = 2.0 V
1.5
VCC = 4.5 V
40 C to +85 C 40 C to +125 C Unit
Max
Min
Max
Min
Max
1.2
1.5
1.5
V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
74HC4002
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2
A
74HC_HCT4002
Product data sheet
4 of 15
74HC4002; 74HCT4002
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
CI
input
capacitance
Typ
Max
Min
Max
Min
Max
3.5
pF
74HCT4002
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.84
4.32
3.84
3.7
V
LOW-level
output voltage
IO = 20 A
0.1
0.1
V
IO = 5.2 mA
0.15
0.26
0.33
0.4
V
VOL
II
input leakage
current
VI = VCC or GND;
VCC = 5.5 V
0.1
1
1
A
ICC
supply current
VCC = 5.5 V
2
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
45
162
203
221
A
CI
input
capacitance
3.5
pF
74HC_HCT4002
Product data sheet
5 of 15
74HC4002; 74HCT4002
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for load circuit see Figure 8.
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
VCC = 2.0 V
30
100
125
150
ns
VCC = 4.5 V
11
30
ns
VCC = 6.0 V
9
17
21
26
ns
9
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
16
pF
13
22
28
33
ns
74HC4002
propagation delay nA, nB, nC or nD to nY;
see Figure 7
tpd
[1]
VCC = 5.0 V; CL = 15 pF
transition time
tt
[2]
see Figure 7
VCC = 6.0 V
power dissipation
capacitance
CPD
per package; VI = GND to VCC
[3]
74HCT4002
tpd
see Figure 7
[1]
VCC = 4.5 V
transition time
tt
power dissipation
capacitance
CPD
[1]
11
ns
VCC = 4.5 V; see Figure 7
[2]
7
15
19
22
ns
per package;
VI = GND to VCC 1.5 V
[3]
22
pF
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT4002
Product data sheet
6 of 15
74HC4002; 74HCT4002
Nexperia
11. Waveforms
9,
Q$Q%Q&
Q'LQSXW
90
*1'
W3+/
92+
Q
很抱歉,暂时无法提供与“74HC4002PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.704881+0.70965
- 10+3.9058910+0.48586
- 25+3.4501225+0.42917
- 100+2.95212100+0.36722
- 250+2.71511250+0.33774
- 500+2.57196500+0.31993
- 1000+2.454101000+0.30527
