74HCT4002DB,112
74HCT4002DB,112
    NEXPERIA(安世)
    SSOP14_6.4X5.4MM
    电压电平转换器 5V 50mA SSOP14_6.4X5.4MM
74HCT4002DB,112 数据手册
74HC4002; 74HCT4002 Dual 4-input NOR gate Rev. 5 — 26 May 2016 Product data sheet 1. General description The 74HC4002; 74HCT4002 is a dual 4-input NOR gate. Inputs also include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard JESD7A  Low-power dissipation  Input levels:  For 74HC4002: CMOS level  For 74HCT4002: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +80 C and from 40 C to +125 C. 3. Ordering information Table 1. Ordering information Type number 74HC4002D Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74HCT4002D 74HC4002DB 74HCT4002DB 74HC4002PW 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate 4. Functional diagram         $ %  < &   '  $  %  < &   '   DDD Fig 1. Functional diagram Fig 2. $ % < &  ' $ % < &  ' DDD Logic symbol •    $   % •  <   &   ' DDD DDD Fig 3. IEC Logic symbol Fig 4. Logic diagram 5. Pinning information 5.1 Pinning +& +&7 <   9&& $   < %   ' &   & '   % QF   $ *1'   QF +& +&7 <   9&& $   < %   ' &   & '   % QF   $ *1'   QF DDD Fig 5. Pin configuration SOT108-1 74HC_HCT4002 Product data sheet DDD Fig 6. Pin configuration SOT337-1 and SOT402-1 All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 May 2016 © Nexperia B.V. 2017. All rights reserved 2 of 15 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1Y 1 data output 1A, 1B, 1C, 1D 2, 3, 4, 5 data input n.c. 6, 8 not connected GND 7 ground (0 V) 2Y 13 data output 2A, 2B, 2C, 2D 9, 10, 11, 12 data input VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input Output nA nB nC nD nY L L L L H H X X X L X H X X L X X H X L X X X H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 25 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot SO14, and (T)SSOP14 packages [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For (T)SSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 74HC_HCT4002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 May 2016 © Nexperia B.V. 2017. All rights reserved 3 of 15 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC4002 Min Typ 74HCT4002 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC4002 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2 - 20 - 40 A 74HC_HCT4002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 May 2016 © Nexperia B.V. 2017. All rights reserved 4 of 15 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min CI input capacitance Typ 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max - 3.5 - - - - - pF 74HCT4002 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.84 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 2 - 20 - 40 A ICC additional supply current per input pin; VI = VCC  2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 45 162 - 203 - 221 A CI input capacitance - 3.5 - - - - - pF 74HC_HCT4002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 May 2016 © Nexperia B.V. 2017. All rights reserved 5 of 15 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF; for load circuit see Figure 8. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ Max Max (85 C) Max (125 C) VCC = 2.0 V - 30 100 125 150 ns VCC = 4.5 V - 11 20 25 30 ns VCC = 6.0 V - 9 17 21 26 ns - 9 - - - ns VCC = 2.0 V - 19 75 95 110 ns VCC = 4.5 V - 7 15 19 22 ns - 6 13 16 19 ns - 16 - - - pF - 13 22 28 33 ns 74HC4002 propagation delay nA, nB, nC or nD to nY; see Figure 7 tpd [1] VCC = 5.0 V; CL = 15 pF transition time tt [2] see Figure 7 VCC = 6.0 V power dissipation capacitance CPD per package; VI = GND to VCC [3] 74HCT4002 tpd propagation delay nA, nB, nC or nD to nY; see Figure 7 [1] VCC = 4.5 V VCC = 5.0 V; CL = 15 pF transition time tt power dissipation capacitance CPD [1] - 11 - - - ns VCC = 4.5 V; see Figure 7 [2] - 7 15 19 22 ns per package; VI = GND to VCC  1.5 V [3] - 22 - - - pF tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N +  (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching;  (CL  VCC2  fo) = sum of outputs. 74HC_HCT4002 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 26 May 2016 © Nexperia B.V. 2017. All rights reserved 6 of 15 74HC4002; 74HCT4002 Nexperia Dual 4-input NOR gate 11. Waveforms 9, Q$Q%Q& Q'LQSXW 90 *1' W3+/ 92+ Q
74HCT4002DB,112 价格&库存
很抱歉,暂时无法提供与“74HCT4002DB,112”相匹配的价格&库存,您可以联系我们找货
