74HC4002-Q100; 74HCT4002-Q100
Dual 4-input NOR gate
Rev. 1 — 18 July 2012
Product data sheet
1. General description
The 74HC4002-Q100; 74HCT4002-Q100 is a dual 4-input NOR gate. Inputs also include
clamp diodes, this enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Complies with JEDEC standard JESD7A
Low-power dissipation
Input levels:
For 74HC4002-Q100: CMOS level
For 74HCT4002-Q100: TTL level
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Ordering information
Table 1.
Type number
74HC4002D-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
TSSOP14 plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74HCT4002D-Q100
74HC4002PW-Q100 40 C to +125 C
Nexperia
4. Functional diagram
DDD
Fig 1.
Functional diagram
Fig 2.
DDD
Logic symbol
DDD
Fig 3.
IEC Logic symbol
Fig 4.
DDD
Logic diagram
5. Pinning information
5.1 Pinning
+&4
+&74
9&&
QF
*1'
+&4
9&&
QF
QF
*1'
QF
DDD
DDD
Fig 5.
Pin configuration SOT108-1
74HC_HCT4002_Q100
Product data sheet
Fig 6.
Pin configuration SOT402-1
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Y
1
data output
1A, 1B, 1C, 1D
2, 3, 4, 5
data input
n.c.
6, 8
not connected
GND
7
ground (0 V)
2Y
13
data output
2A, 2B, 2C, 2Y
9, 10, 11, 12
data input
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
nA
nB
nC
nD
nY
L
L
L
L
H
H
X
X
X
L
X
H
X
X
L
X
X
H
X
L
X
X
X
H
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
IGND
Tstg
storage temperature
Max
Unit
0.5
+7
V
mA
mA
25
mA
supply current
50
mA
ground current
50
mA
65
+150
C
DIP14 package
750
mW
SO14, and (T)SSOP14
packages
500
mW
[2]
total power dissipation
Ptot
Min
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
74HC_HCT4002_Q100
Product data sheet
3 of 14
Nexperia
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
74HC4002-Q100
Min
Typ
74HCT4002-Q100
Max
Min
Typ
Unit
Max
VCC
supply voltage
2.0
5.0
6.0
4.5
5.0
5.5
V
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
40
+25
+125
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 C
Conditions
Min
Typ
VCC = 2.0 V
1.5
VCC = 4.5 V
40 C to +85 C 40 C to +125 C Unit
Max
Min
Max
Min
Max
1.2
1.5
1.5
V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = 20 A; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
74HC4002-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND;
VCC = 6.0 V
0.1
1
1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
2
A
74HC_HCT4002_Q100
Product data sheet
4 of 14
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 C
Conditions
Min
CI
input
capacitance
Typ
Max
Min
Max
Min
Max
3.5
pF
74HCT4002-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
4.4
4.4
V
IO = 4.0 mA
3.84
4.32
3.84
3.7
V
LOW-level
output voltage
IO = 20 A
0.1
0.1
V
IO = 5.2 mA
0.15
0.26
0.33
0.4
V
VOL
II
input leakage
current
VI = VCC or GND;
VCC = 5.5 V
0.1
1
1
A
ICC
supply current
VCC = 5.5 V
2
A
ICC
additional
supply current
per input pin;
VI = VCC 2.1 V; IO = 0 A;
other inputs at VCC or GND;
45
162
203
221
A
CI
input
capacitance
3.5
pF
74HC_HCT4002_Q100
Product data sheet
5 of 14
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; CL = 50 pF; for load circuit see Figure 8.
Symbol Parameter
25 C
Conditions
40 C to +125 C Unit
Min
Typ
Max
Max
(85 C)
Max
(125 C)
VCC = 2.0 V
30
100
125
150
ns
VCC = 4.5 V
11
30
ns
VCC = 6.0 V
9
17
21
26
ns
9
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
16
pF
13
22
28
33
ns
74HC4002-Q100
tpd
propagation delay nA, nB, nC or nD to nY;
see Figure 7
[1]
VCC = 5.0 V; CL = 15 pF
tt
transition time
[2]
see Figure 7
VCC = 6.0 V
CPD
power dissipation
capacitance
per package; VI = GND to VCC
[3]
74HCT4002-Q100
tpd
see Figure 7
[1]
VCC = 4.5 V
tt
CPD
[1]
transition time
power dissipation
capacitance
11
ns
VCC = 4.5 V; see Figure 7
[2]
7
15
19
22
ns
per package;
VI = GND to VCC 1.5 V
[3]
22
pF
tpd is the same as tPHL and tPLH.
[2]
tt is the same as tTHL and tTLH.
[3]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT4002_Q100
Product data sheet
6 of 14
Nexperia
11. Waveforms
9,
Q$Q%Q&
Q'LQSXW
90
*1'
W3+/
92+
W3/+
9<
90
Q
很抱歉,暂时无法提供与“74HC4002D-Q100,118”相匹配的价格&库存,您可以联系我们找货
