74HC4075D,653
74HC4075D,653
    NEXPERIA(安世)
    SOIC14_150MIL
    IC GATE OR 3CH 3-INP 14SO
74HC4075D,653 数据手册
74HC4075; 74HCT4075 Triple 3-input OR gate Rev. 4 — 4 February 2019 Product data sheet 1. General description The 74HC4075; 74HCT4075 is a triple 3-input OR gate. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • Complies with JEDEC standard no. 7A Input levels: • For 74HC4075: CMOS level • For 74HCT4075: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and from -40 °C to +125 °C • • 3. Ordering information Table 1. Ordering information Type number Package 74HC4075D Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74HCT4075D 4. Functional diagram 3 1A 4 1B 5 1C 1Y 6 3 4 ≥1 6 5 1 2A 2 2B 8 2C 2Y 1 9 2 ≥1 9 8 11 3A 12 3B 13 3C 3Y 11 10 12 Logic symbol ≥1 10 Y B 13 aaa-024793 Fig. 1. A aaa-024794 Fig. 2. IEC logic symbol C Fig. 3. aaa-024795 Logic diagram (one gate) 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 5. Pinning information 5.1. Pinning 74HC4075 74HCT4075 2A 1 14 VCC 2B 2 13 3C 1A 3 12 3B 1B 4 11 3A 1C 5 10 3Y 1Y 6 9 2Y GND 7 8 2C aaa-024796 Fig. 4. Pin configuration SOT108-1 (SO14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A 3, 1, 11 data input 1B, 2B, 3B 4, 2, 12 data input 1C, 2C, 3C 5, 8, 13 data input 1Y, 2Y, 3Y 6, 9, 10 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. Outputs Inputs nA nB nC nY L L L L X X H H X H X H H X X H 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 2 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC4075 Min Typ 74HCT4075 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V -40 °C to +125 °C Unit 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V LOW-level input VCC = 2.0 V voltage VCC = 4.5 V - 0.8 0.5 - 0.5 - 0.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V 74HC4075 VIH VIL HIGH-level input voltage 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 3 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate Symbol Parameter VOH VOL HIGH-level output voltage LOW-level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 μA CI input capacitance - 3.5 - - - - - pF 2.0 1.6 - 2.0 - 2.0 - V - 1.2 0.8 - 0.8 - 0.8 V IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA 3.98 4.32 - 3.84 - 3.7 - V 74HCT4075 VIH HIGH-level input voltage VIL LOW-level input VCC = 4.5 V to 5.5 V voltage VOH HIGH-level output voltage VOL LOW-level output voltage VCC = 4.5 V to 5.5 V VI = VIH or VIL; VCC = 4.5 V VI = VIH or VIL; VCC = 4.5 V IO = 20 μA - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 2.0 - 20 - 40 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A - 150 540 - 675 - 735 μA - 3.5 - - - - - pF nA, nB, nC inputs CI input capacitance 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 4 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 6. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Min Max Max (85 °C) (125 °C) VCC = 2.0 V - 28 100 - 125 150 ns VCC = 4.5 V - 10 20 - 25 30 ns VCC = 5.0 V; CL = 15 pF - 8 - - - - ns - 8 17 - 21 26 ns VCC = 2.0 V - 19 75 - 95 110 ns VCC = 4.5 V - 7 15 - 19 22 ns VCC = 6.0 V - 6 13 - 16 19 ns - 28 - - - - pF VCC = 4.5 V - 12 24 - 30 36 ns VCC = 5.0 V; CL = 15 pF - 10 - - - - ns 74HC4075 tpd propagation delay nA, nB, nC to nY; see Fig. 5 [1] VCC = 6.0 V tt transition time CPD power dissipation capacitance see Fig. 5 [2] per package; VI = GND to VCC [3] nA, nB, nC to nY; see Fig. 5 [1] 74HCT4075 tpd propagation delay tt transition time VCC = 4.5 V; see Fig. 5 [2] - 7 15 - 19 22 ns CPD power dissipation capacitance per package; VI = GND to VCC - 1.5 V [3] - 32 - - - - pF [1] [2] [3] tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑ (CL × VCC × fo) = sum of outputs. 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 5 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 10.1. Waveforms and test circuit VI nA, nB, nC input VM GND tPHL VOH tPLH VY VM VX nY output VOL tTHL tTLH aaa-024798 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 5. Input (nA, nB, nC) to output (nY) propagation delays and output transition times Table 8. Measurement points Input Type Output VM VM VX VY 74HC4075 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HCT4075 1.3 V 1.3 V 0.1VCC 0.9VCC 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 6 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Fig. 6. Test circuit for measuring switching times Table 9. Test data Type Input S1 position Load VI tr, tf CL RL tPHL, tPLH 74HC4075 VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HCT4075 3V 6 ns 15 pF, 50 pF 1 kΩ open 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 7 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 Fig. 7. JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 8 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4075 v.4 20190204 Product data sheet - Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HCT4075DB (SOT337-1) removed. Type numbers 74HC4075PW and 74HCT4075PW (SOT402-1) removed. 74HC_HCT4075 v.3 20161103 Modifications: • • • 74HC_HCT4075 v.2 74HC_HCT4075 Product data sheet 74HC_HCT4075 v.3 Product data sheet - 74HC_HCT4075 v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC4075N and 74HCT4075N removed. 19901201 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 - © Nexperia B.V. 2019. All rights reserved 9 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT4075 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 10 / 11 74HC4075; 74HCT4075 Nexperia Triple 3-input OR gate Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................1 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 2 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................3 10. Dynamic characteristics............................................ 5 10.1. Waveforms and test circuit........................................ 6 11. Package outline.......................................................... 8 12. Abbreviations.............................................................. 9 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 February 2019 74HC_HCT4075 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 4 February 2019 © Nexperia B.V. 2019. All rights reserved 11 / 11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC4075D,652 74HC4075DB,112 74HC4075DB,118 74HC4075D,653 74HC4075N,652 74HCT4075D,652 74HCT4075DB,112 74HCT4075DB,118 74HCT4075D,653 74HCT4075N,652 74HCT4075PW,118
74HC4075D,653 价格&库存
很抱歉,暂时无法提供与“74HC4075D,653”相匹配的价格&库存,您可以联系我们找货
74HC4075D,653
74HC4075D,653
  • 5000+1.06415
  • 10000+0.99321
库存:5000
