74HC9114; 74HCT9114
Nine wide Schmitt trigger buffer; open drain outputs;
inverting
Rev. 3 — 2 October 2017
1
Product data sheet
General description
The 74HC9114; 74HCT9114 is a 9-bit inverter with Schmitt trigger inputs and open
drain outputs. Inputs also include clamp diodes, this enables the use of current limiting
resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform
slowly changing input signals into sharply defined jitter-free output signals.
2
Features and benefits
Wide operating voltage 2.0 V to 6.0 V
Schmitt trigger action on all data inputs
Low-power dissipation
Complies with JEDEC standard no. 7A
ESD protection:
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
74HC9114D
74HCT9114D
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74HC9114; 74HCT9114
Nexperia
Nine wide Schmitt trigger buffer; open drain outputs; inverting
4
Functional diagram
1
2
3
4
5
6
7
8
9
A0
Y0
A1
Y1
A2
Y2
A3
Y3
A4
Y4
A5
Y5
A6
Y6
A7
Y7
A8
Y8
19
18
17
16
15
14
13
Yn
12
An
11
GND
aaa-027416
aaa-027417
Figure 1. Logic symbol
5
Figure 2. Logic diagram (one Schmitt trigger)
Pinning information
5.1 Pinning
74HC9114
74HCT9114
A0
1
A1
2
20 VCC
19 Y0
A2
3
18 Y1
A3
4
17 Y2
A4
5
16 Y3
A5
6
15 Y4
A6
7
14 Y5
A7
8
13 Y6
A8
9
12 Y7
GND 10
11 Y8
aaa-027418
Figure 3. Pin configuration SO20
74HC_HCT9114
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 13
74HC9114; 74HCT9114
Nexperia
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
A0, A1, A2, A3, A4, A5, A6, A7, A8
1, 2, 3, 4, 5, 6, 7, 8, 9
data input
GND
10
ground (0 V)
Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7, Y8
19, 18, 17, 16, 15, 14, 13, 12, 11
data output
VCC
supply voltage
6
Functional description
Table 3. Function table
[1]
Input
Output
An
Yn
L
Z
H
L
[1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state.
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
IOK
input clamping current
output clamping current
Conditions
Min
Max
Unit
-0.5
+7.0
V
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
-0.5 V < VO < VCC + 0.5 V
[1]
±25
mA
IO
output current
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[2]
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] Above 70 °C the value of Ptot derates linearly with 8 mW/K.
74HC_HCT9114
Product data sheet
3 / 13
74HC9114; 74HCT9114
Nexperia
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
74HC9114
74HCT9114
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
9
Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
74HC9114
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VT-
VI = VT+ or VT-
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT9114
Product data sheet
4 / 13
74HC9114; 74HCT9114
Nexperia
Symbol
Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4.0 mA
3.98
4.32
3.84
3.7
V
IO = 20 μA;
0.1
0.1
V
IO = 4.0 mA;
0.15
0.26
0.33
0.4
V
74HCT9114
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VT-; VCC = 4.5 V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply current
per An input pin; IO = 0 A;
VCC = 4.5 V to 5.5 V;
VI = VCC - 2.1 V;
other inputs at VCC or GND
30
108
135
147
CI
input
capacitance
3.5
μA
pF
10 Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; CL = 50 pF; for test circuit see Figure 5.
Symbol
Parameter
Conditions
Tamb = 25 °C
Min
Typ
Max
Max
Max
(85 °C)
(125 °C)
Unit
74HC9114
tpd
tTHL
propagation delay
HIGH to LOW
output transition
time
An to Yn; see Figure 4
[1]
VCC = 2.0 V
36
110
140
165
ns
VCC = 4.5 V
13
22
28
33
ns
VCC = 5.0 V; CL = 15 pF
12
ns
VCC = 6.0 V
10
19
24
28
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
5
pF
Yn; see Figure 4
VCC = 6.0 V
CPD
power dissipation
capacitance
74HC_HCT9114
Product data sheet
per buffer; VI = GND to VCC
[2]
5 / 13
74HC9114; 74HCT9114
Nexperia
Symbol
Parameter
Conditions
Tamb = 25 °C
Min
Typ
Max
Max
Max
(85 °C)
(125 °C)
Unit
74HCT9114
tpd
propagation delay
[1]
VCC = 4.5 V
17
31
39
47
ns
13
ns
7
15
19
22
ns
5
pF
tTHL
HIGH to LOW
output transition
time
Yn; VCC = 4.5 V; see
Figure 4
CPD
power dissipation
capacitance
per buffer;
VI = GND to VCC - 1.5 V
[2]
[1] tpd is the same as tPLZ and tPZL.
[2] CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑ (CL × VCC × fo) = sum of outputs.
10.1 Waveforms and test circuit
VI
VM
An input
GND
tPLZ
tPZL
VCC
Yn output
VM
VX
VOL
tTHL
aaa-027419
Measurement points are given in Table 8.
VOL is a typical voltage output level that occurs with the output load.
Figure 4. Input to output propagation delays and HIGH to LOW output transition time
Table 8. Measurement points
Type
Input
Output
VM
VM
VX
74HC9114
0.5VCC
0.5VCC
0.1VCC
74HCT9114
1.3 V
1.3 V
0.1VCC
74HC_HCT9114
Product data sheet
6 / 13
74HC9114; 74HCT9114
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
VI
G
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance
S1 = Test selection switch
Figure 5. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZL, tPLZ
74HC9114
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
VCC
74HCT9114
3V
6 ns
15 pF, 50 pF
1 kΩ
open
VCC
74HC_HCT9114
Product data sheet
7 / 13
74HC9114; 74HCT9114
Nexperia
10.2 Transfer characteristics
Table 10. Transfer characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see Figure 6 and Figure 7.
Symbol
Parameter
Conditions
Tamb = 25 °C
Tamb = −40 °C
to +85 °C
Tamb = −40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
0.70
1.13
1.50
0.70
1.50
0.70
1.50
V
VCC = 4.5 V
1.75
2.37
3.15
1.75
3.15
1.75
3.15
V
VCC = 6.0 V
2.30
3.11
4.20
2.30
4.20
2.30
4.20
V
VCC = 2.0 V
0.30
0.70
1.10
0.30
1.10
0.30
1.10
V
VCC = 4.5 V
1.35
1.80
2.40
1.35
2.40
1.35
2.40
V
VCC = 6.0 V
1.8
2.43
3.30
1.80
3.30
1.80
3.30
V
VCC = 2.0 V
0.2
0.43
0.80
0.18
0.80
0.15
0.80
V
VCC = 4.5 V
0.4
0.57
1.00
0.40
1.00
0.40
1.00
V
VCC = 6.0 V
0.5
0.68
1.10
0.50
1.10
0.50
1.10
V
positive-going
threshold voltage
VCC = 4.5 V
0.9
1.50
2.0
0.9
2.0
0.9
2.0
V
VCC = 5.5 V
1.2
1.70
2.1
1.2
2.1
1.2
2.1
V
negative-going
threshold voltage
VCC = 4.5 V
0.7
1.06
1.4
0.7
1.4
0.7
1.4
V
VCC = 5.5 V
0.8
1.27
1.7
0.8
1.7
0.8
2.7
V
hysteresis voltage
VCC = 4.5 V
0.2
0.44
0.8
0.2
0.8
0.2
0.8
V
VCC = 5.5 V
0.2
0.44
0.8
0.2
0.8
0.2
0.8
V
74HC9114
VT+
VT-
VH
positive-going
threshold voltage
negative-going
threshold voltage
hysteresis voltage
74HCT9114
VT+
VTVH
10.3 Transfer characteristics waveforms
VO
VI
VI
VH
VT-
VT+
Figure 6. Transfer characteristics
74HC_HCT9114
Product data sheet
VT+
VH
VT-
VO
mna207
mna208
Figure 7. Transfer characteristics definitions
8 / 13
74HC9114; 74HCT9114
Nexperia
11 Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 8. Package outline SOT163-1 (SO20)
74HC_HCT9114
Product data sheet
9 / 13
74HC9114; 74HCT9114
Nexperia
12 Abbreviations
Table 11. Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
13 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT9114 v.3
20171002
Product data sheet
74HC_HCT9114 v.2
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74HC_HCT9114 v.2
19901201
Product specification
74HC_HCT9114 v.1
74HC_HCT9114 v.1
19880301
74HC_HCT9114
Product data sheet
10 / 13
74HC9114; 74HCT9114
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74HC_HCT9114
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
11 / 13
74HC9114; 74HCT9114
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74HC_HCT9114
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
12 / 13
Nexperia
74HC9114; 74HCT9114
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
10.2
10.3
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 3
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 4
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveforms and test circuit ................................ 6
Transfer characteristics ..................................... 8
Transfer characteristics waveforms ................... 8
Package outline ...................................................9
Abbreviations .................................................... 10
Revision history ................................................ 10
Legal information .............................................. 11
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 2 October 2017
Document identifier: 74HC_HCT9114
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC9114D,112 74HC9114D,118 74HC9114N,112 74HCT9114D,112 74HCT9114D,118
