74HC05D-Q100,118
74HC05D-Q100,118
    NEXPERIA(安世)
    SOIC-14
    IC INVERTER OD 6CH 6-INP 14SO
74HC05D-Q100,118 数据手册
74HC05-Q100 Hex inverter with open-drain outputs Rev. 1 — 9 July 2012 Product data sheet 1. General description The 74HC05-Q100 is a high-speed Si-gate CMOS device that complies with JEDEC standard no. 7A. The 74HC05-Q100 contains six inverters. The outputs of the 74HC05-Q100 are open-drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. The open-drain outputs require pull-up resistors to perform correctly. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide operating voltage 2.0 V to 6.0 V  Input levels:  For 74HC05-Q100: CMOS level  Latch-up performance exceeds 100 mA per JESD 78 Class II level A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  Multiple package options 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74HC05PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74HC05BQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1 thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HC05D-Q100 4. Functional diagram 1 1A 1Y 2 3 2A 2Y 4 5 3A 3Y 6 9 4A 4Y 8 11 5A 5Y 10 13 6A 6Y 12 VCC Y A GND mna525 Fig 1. Logic symbol 74HC05_Q100 Product data sheet 001aaj979 Fig 2. Logic diagram (one gate) All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 2 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 5. Pinning information 5.1 Pinning 74HC05-Q100 1A 1 14 VCC 1Y 2 13 6A 2A 3 12 6Y 2Y 4 11 5A 3A 5 10 5Y 3Y 6 9 4A GND 7 8 4Y aaa-003361 Fig 3. Pin configuration SOT108-1 (SO14) 1 1A terminal 1 index area 74HC05-Q100 14 VCC 74HC05-Q100 1Y 2 13 6A 1A 1 14 VCC 2A 3 12 6Y 1Y 2 13 6A 2Y 4 11 5A 2A 3 12 6Y 3A 5 2Y 4 11 5A 3Y 6 6 9 4A 7 8 4Y 8 3Y GND 10 5Y 9 7 10 5Y 4Y 5 GND 3A GND(1) 4A aaa-003363 Transparent top view aaa-003362 (1) The die substrate is attached to this pad using conductive die attach material. It can not be used as a supply pin or input. Fig 4. Pin configuration SOT402-1 (TSSOP14) Fig 5. Pin configuration SOT762-1 (DHVQFN14) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 6A 1, 3, 5, 9, 11, 13 data input 1Y to 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 3 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 6. Functional description Table 3. Function table[1] Input Output nA nY L Z H L [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - ±20 mA mA input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] - ±20 VO output voltage [1] 0.5 VCC + 0.5 V V IO output current - 25 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW IIK VO < VCC + 0.5 V [2] total power dissipation Ptot [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC Min Typ Max Unit supply voltage 2.0 5.0 6.0 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 - +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V 74HC05_Q100 Product data sheet Conditions All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 4 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min VIH VIL VOL HIGH-level input voltage LOW-level input voltage LOW-level output voltage Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 A VI = VIH or VIL input leakage current VI = VCC or GND; VCC = 6.0 V IOZ OFF-state output current per input pin; VI = VIL; VO = VCC or GND; other inputs at VCC or GND; VCC = 6.0 V; IO = 0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V CI input capacitance Product data sheet Typ VCC = 4.5 V II 74HC05_Q100 40 C to +85 C 40 C to +125 C Unit - - ±0.5 - ±5.0 - ±10 A - - 2.0 - 20 - 40 A - 3.5 - - - - - pF All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 5 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; for test circuit see Figure 7. Symbol Parameter 25 C Conditions Min Typ Max Max (85 C) Max (125 C) - 20 90 115 135 ns VCC = 4.5 V - 11 18 23 27 ns VCC = 6.0 V - 10 15 20 23 ns - 22 90 115 135 ns VCC = 4.5 V - 9 18 23 27 ns VCC = 6.0 V - 8 15 20 23 ns VCC = 2.0 V - 18 75 95 110 ns VCC = 4.5 V - 6 15 19 22 ns - 5 13 16 19 ns - 4 - - - pF LOW to OFF-state nA to nY; see Figure 6 propagation delay VCC = 2.0 V tPLZ OFF-state to LOW nA to nY; see Figure 6 propagation delay VCC = 2.0 V tPZL tTHL HIGH to LOW output transition time see Figure 6 power dissipation capacitance per inverter; VI = GND to VCC; VCC = 5.0 V VCC = 6.0 V CPD [1] 40 C to +125 C Unit [1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (0.5  CL  VO2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; VO = output voltage in V (output HIGH); VCC = supply voltage in V; N = number of inputs switching; RL = load resistance in M; CL = load capacitance in pF; 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 6 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 11. Waveforms VI nA input VM GND tPLZ tPZL VCC 90 % nY output VM 10 % VX VOL tTHL 001aaj981 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. The input nA to output nY propagation delays and output transition times Measurement points Input Output VM VM VX 0.5VCC 0.5VCC 0.1VCC 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 7 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs VI tW 90 % negative pulse VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL RT S1 open DUT CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = Load resistance. Fig 7. Table 9. Test circuit for measuring switching times Test data Input Load S1 position VI tr, tf CL RL tPZL, tPLZ VCC 6 ns 50 pF 1 k VCC 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 8 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 9 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 10 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A(1) max. A1 b 1 0.05 0.00 0.30 0.18 c D (1) Dh E (1) Eh 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 e 0.5 e1 L v w y y1 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 10. Package outline SOT762-1 (DHVQFN14) 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 11 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC05_Q100_1 20120709 Product data sheet - - 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 12 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC05_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 13 of 15 74HC05-Q100 Nexperia Hex inverter with open-drain outputs No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC05_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 9 July 2012 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia 74HC05-Q100 Hex inverter with open-drain outputs 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 July 2012 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC05D-Q100,118 74HC05BQ-Q100,115 74HC05PW-Q100,118
74HC05D-Q100,118
物料型号:74HC05-Q100
器件简介: - 74HC05-Q100是一个高速Si-gate CMOS设备,符合JEDEC标准号7A。 - 包含六个反相器,其输出为开漏形式,可以连接到其他开漏输出以实现主动低电平或高电平的线或逻辑功能。 - 产品已通过汽车电子协会(AEC)标准Q100(1级)认证,适用于汽车应用。
引脚分配: - 74HC05-Q100有不同的封装类型,包括SO14、TSSOP14和DHVQFN14。 - 引脚分配如下: - 1A至6A(数据输入) - 1Y至6Y(数据输出) - GND(接地,0V) - Vcc(供电电压)
参数特性: - 工作电压范围:2.0V至6.0V。 - 环境温度范围:-40℃至+125℃。 - 输入电平:CMOS级别。 - 抗静电能力:MIL-STD-883方法3015超过2000V,HBM JESD22-A114F超过2000V,MM JESD22-A115-A超过200V(C=200pf,R=0Ω)。
功能详解: - 74HC05-Q100的输出为开漏,需要上拉电阻才能正常工作。 - 逻辑功能表显示输入和输出的关系,其中“L”代表低电平,“H”代表高电平,“Z”代表高阻态。
应用信息: - 该产品符合汽车产品资格认证,适用于汽车应用。 - 描述了不同的封装选项,包括塑料小外形封装、塑料薄缩小型封装和塑料双列兼容热增强超薄四平封装。
封装信息: - 详细描述了SO14、TSSOP14和DHVQFN14三种封装的尺寸和特性。 - 提供了封装的轮廓图和尺寸参数。
74HC05D-Q100,118 价格&库存
很抱歉,暂时无法提供与“74HC05D-Q100,118”相匹配的价格&库存,您可以联系我们找货
74HC05D-Q100,118
  • 1+3.883171+0.50470
  • 10+2.6819510+0.34858
  • 25+2.3926325+0.31097
  • 100+2.06961100+0.26899
  • 250+1.91611250+0.24904
  • 500+1.82349500+0.23700
  • 1000+1.747371000+0.22711
库存:2254
74HC05D-Q100,118
  • 2500+1.266562500+0.16462
  • 5000+1.228295000+0.15964
  • 7500+1.209127500+0.15715
  • 12500+1.1879012500+0.15439
  • 17500+1.1754817500+0.15278
  • 25000+1.1635525000+0.15123
库存:2254
74HC05D-Q100,118
