74HC1GU04GW,125
74HC1GU04GW,125
    NEXPERIA(安世)
    TSSOP-5_2.05X1.25MM
    IC INVERTER 1CH 1-INP 5TSSOP
74HC1GU04GW,125 数据手册
74HC1GU04 Single unbuffered inverter Rev. 6 — 25 July 2018 Product data sheet 1. General description The 74HC1GU04 is a single unbuffered inverter. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • Symmetrical output impedance Wide operating voltage range from 2.0 V to 6.0 V Low power dissipation Balanced propagation delays SOT353-1 and SOT753 package options 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC1GU04GW -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74HC1GU04GV -40 °C to +125 °C SC-74A plastic surface-mounted package; 5 leads SOT753 4. Marking Table 2. Marking codes Type number Marking[1] 74HC1GU04GW HD 74HC1GU04GV HU4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 2 A Y 4 2 mna043 Fig. 1. Logic symbol 1 4 A mna044 Fig. 2. IEC logic symbol Y mna045 Fig. 3. Logic diagram 74HC1GU04 Nexperia Single unbuffered inverter 6. Pinning information 6.1. Pinning 74HC1GU04 n.c. 1 A 2 GND 3 5 VCC 4 Y 001aaf105 Fig. 4. Pin configuration SOT353-1 and SOT753 6.2. Pin description Table 3. Pin description Symbol Pin Description n.c. 1 not connected A 2 data input GND 3 ground (0 V) Y 4 data output VCC 5 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level Input Output A Y L H H L 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 2 / 13 74HC1GU04 Nexperia Single unbuffered inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage -0.5 +7.0 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current IO output current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA -0.5 V < VO < VCC + 0.5 V [1] - ±12.5 mA ICC supply current - 25 mA IGND ground current -25 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 200 mW [1] [2] Conditions Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Above 55 °C the value of Ptot derates linearity with 2.5 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 2.0 5.0 6.0 V VI VO input voltage 0 - VCC V output voltage 0 - VCC V Tamb ambient temperature -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - - 139 ns/V VCC = 6.0 V - - 83 ns/V 10. Static characteristics Table 7. Static characteristics Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C. Symbol VIH VIL Parameter HIGH-level input voltage LOW-level input voltage 74HC1GU04 Product data sheet Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V 1.7 1.4 - 1.7 - V VCC = 4.5 V 3.6 2.6 - 3.6 - V VCC = 6.0 V 4.8 3.4 - 4.8 - V VCC = 2.0 V - 0.6 0.3 - 0.3 V VCC = 4.5 V - 1.9 0.9 - 0.9 V VCC = 6.0 V - 2.6 1.2 - 1.2 V All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 3 / 13 74HC1GU04 Nexperia Single unbuffered inverter Symbol VOH VOL Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max IO = -20 μA; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = -20 μA; VCC = 4.5 V 4.0 4.5 - 4.0 - V IO = -20 μA; VCC = 6.0 V 5.5 6.0 - 5.5 - V IO = -2.0 mA; VCC = 4.5 V 4.13 4.32 - 3.7 - V IO = -2.6 mA; VCC = 6.0 V 5.63 5.81 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 20 μA; VCC = 4.5 V - 0 0.5 - 0.5 V IO = 20 μA; VCC = 6.0 V - 0 0.5 - 0.5 V IO = 2.0 mA; VCC = 4.5 V - 0.15 0.33 - 0.4 V IO = 2.6 mA; VCC = 6.0 V VI = VIH or VIL HIGH-level output voltage VI = VIH or VIL LOW-level output voltage - 0.16 0.33 - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 - 1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 10 - 20 μA CI input capacitance - 5 - - - pF 11. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; tr = tf = 6.0 ns; For test circuit see Fig. 6. All typical values are measured at Tamb = 25 °C. Symbol Parameter -40 °C to +85 °C CPD -40 °C to +125 °C Unit Min Typ Max Min Max VCC = 2.0 V; CL = 50 pF - 10 90 - 105 ns VCC = 4.5 V; CL = 50 pF - 7 18 - 21 ns VCC = 6.0 V; CL = 50 pF - 6 15 - 18 ns VCC = 5.0 V; CL = 15 pF - 5 - - - ns - 14 - - - pF propagation delay A to Y; see Fig. 5 tpd [1] [2] Conditions [1] power dissipation VI = GND to VCC capacitance [2] tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation PD (μW). 2 2 PD = CPD x VCC x fi + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts. 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 4 / 13 74HC1GU04 Nexperia Single unbuffered inverter 11.1. Waveform and test circuit VCC PULSE GENERATOR VI VO DUT CL 50 pF RT VM(1) A input mna034 tPHL Test data is given in Table 8. DUT = Device Under Test CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. tPLH VM(1) Y output mna046 (1) VM Fig. 5. = 0.5xVCC; VI = GND to VCC. Input to output propagation delays Fig. 6. Test circuit for measuring switching times 11.2. Additional characteristics Rbias = 560 kΩ VCC 0.47 µF input output 100 µF VI (f = 1 kHz) A IO GND mna050 gfs = ΔIO/ΔVI at VO is constant. Fig. 7. Test set-up for measuring forward transfer conductance mnb124 30 gfs (mA/V) 20 10 0 0 2 4 6 VCC (V) 8 Tamb = 25 °C Fig. 8. Typical forward transconductance as a function of supply voltage 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 5 / 13 74HC1GU04 Nexperia Single unbuffered inverter 11.3. Typical transfer characteristics mna047 1 ICC (mA) 0 Fig. 9. 0 1 VI (V) 2 1 5 0 0 VCC = 2.0 V; IO = 0 A 5 VO (V) ICC (mA) VO (V) 0.5 mna048 10 2 2.5 0 2.5 VI (V) 5 0 Fig. 10. VCC = 4.5 V; IO = 0 A mna049 20 ICC (mA) VO (V) 10 0 6 3 0 3 VI (V) 6 0 Fig. 11. VCC = 6.0 V; IO = 0 A 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 6 / 13 74HC1GU04 Nexperia Single unbuffered inverter 12. Application information Some applications are: • • Linear amplifier (see Fig. 12) In crystal oscillator design (see Fig. 13) Remark: All values given are typical unless otherwise specified. R2 VCC 1 µF R1 R1 U04 ZL R2 U04 mna052 out Maximum Vo(p-p) = VCC - 1.5 V centered at 0.5xVCC. C2 mna053 C1 = 47 pF (typ.) C2 = 22 pF (typ.) R1 = 1 MΩ to 10 MΩ (typ.) R2 optimum value depends on the frequency and required stability against changes in VCC or average minimum ICC (ICC is typically 2 mA at VCC = 3 V and f = 1 MHz). Gol = open loop gain Gv = voltage gain R1 ≥ 3 kΩ, R2 ≤ 1 MΩ ZL > 10 kΩ; Gol = 20 (typ.) Typical unity gain bandwidth product is 5 MHz. Fig. 12. Used as a linear amplifier C1 Fig. 13. Crystal oscillator configuration Table 9. External components for resonator (f < 1 MHz) All values given are typical and must be used as an initial set-up Frequency R1 R2 C1 C2 10 kHz to 15.9 kHz 2.2 MΩ 220 kΩ 56 pF 20 pF 16 kHz to 24.9 kHz 2.2 MΩ 220 kΩ 56 pF 10 pF 25 kHz to 54.9 kHz 2.2 MΩ 100 kΩ 56 pF 10 pF 55 kHz to 129.9 kHz 2.2 MΩ 100 kΩ 47 pF 5 pF 130 kHz to 199.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 200 kHz to 349.9 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF 350 kHz to 600 kHz 2.2 MΩ 47 kΩ 47 pF 5 pF Table 10. Optimum value for R2 Frequency R2 Optimum for 3 kHz 6 kHz 10 kHz 14 kHz >14 kHz 74HC1GU04 Product data sheet 2.0 kΩ minimum required ICC 8.0 kΩ minimum influence due to change in VCC 1.0 kΩ minimum required ICC 4.7 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 2.0 kΩ minimum influence by VCC 0.5 kΩ minimum required ICC 1.0 kΩ minimum influence by VCC - replace R2 by C3 with a typical value of 35 pF All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 7 / 13 74HC1GU04 Nexperia Single unbuffered inverter mna054 80 input capacitance (pF) (1) 60 (2) 40 (3) 20 0 0 2 4 6 VI (V) 8 (1) VCC = 2.0 V (2) VCC = 4.5 V (3) VCC = 6.0 V Fig. 14. Typical input capacitance as a function of the input voltage 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 8 / 13 74HC1GU04 Nexperia Single unbuffered inverter 13. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Fig. 15. Package outline SOT353-1 (TSSOP5) 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 9 / 13 74HC1GU04 Nexperia Single unbuffered inverter Plastic surface-mounted package; 5 leads SOT753 D B E y A X HE 5 v M A 4 Q A A1 c 1 2 3 Lp detail X bp e w M B 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 bp c D E e HE Lp Q v w y mm 1.1 0.9 0.100 0.013 0.40 0.25 0.26 0.10 3.1 2.7 1.7 1.3 0.95 3.0 2.5 0.6 0.2 0.33 0.23 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT753 JEITA EUROPEAN PROJECTION ISSUE DATE 02-04-16 06-03-16 SC-74A Fig. 16. Package outline SOT753 (SC-74A) 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 10 / 13 74HC1GU04 Nexperia Single unbuffered inverter 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC1GU04 v.6 20180725 Product data sheet - 74HC1GU04 v.5 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Fig. 8: forward transconductance graph added. 74HC1GU04 v.5 20070710 Modifications: • • • • • Product data sheet - 74HC1GU04 v.4 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Package SOT353 changed to SOT353-1 in Table 1 and Fig. 15. Quick Reference Data and Soldering sections removed. Section 2 updated. 74HC1GU04 v.4 20020527 Product specification - 74HC1GU04 v.3 74HC1GU04 v.3 20020513 Product specification - 74HC1GU04 v.2 74HC1GU04 v.2 20010427 Product specification - 74HC1GU04 v.1 74HC1GU04 v.1 19981118 Product specification - - 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 11 / 13 74HC1GU04 Nexperia Single unbuffered inverter 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC1GU04 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 12 / 13 74HC1GU04 Nexperia Single unbuffered inverter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Marking.......................................................................... 1 5. Functional diagram.......................................................1 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 2 7. Functional description................................................. 2 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................3 10. Static characteristics..................................................3 11. Dynamic characteristics.............................................4 11.1. Waveform and test circuit.......................................... 5 11.2. Additional characteristics........................................... 5 11.3. Typical transfer characteristics...................................6 12. Application information............................................. 7 13. Package outline.......................................................... 9 14. Abbreviations............................................................ 11 15. Revision history........................................................11 16. Legal information......................................................12 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 25 July 2018 74HC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 25 July 2018 © Nexperia B.V. 2018. All rights reserved 13 / 13 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74HC1GU04GV,125 74HC1GU04GW,125
74HC1GU04GW,125 价格&库存
很抱歉,暂时无法提供与“74HC1GU04GW,125”相匹配的价格&库存,您可以联系我们找货
74HC1GU04GW,125
    • 3000+0.293253000+0.03647
    • 9000+0.291889000+0.03630
    • 15000+0.2918715000+0.03630
    • 30000+0.2918630000+0.03630
    • 60000+0.2918660000+0.03630
    库存:15000
