74HC4049DB,118
74HC4049DB,118
    NEXPERIA(安世)
    SSOP16_208MIL
    IC BUFFER INVERT 6V 16SSOP
74HC4049DB,118 数据手册
74HC4049 Hex inverting HIGH-to-LOW level shifter Rev. 7 — 5 February 2016 Product data sheet 1. General description The 74HC4049 is a hex inverter with over-voltage tolerant inputs. Inputs are overvoltage tolerant to 15 V. This enables the device to be used in HIGH-to-LOW level shifting applications. 2. Features and benefits  Low-power dissipation  Complies with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2 000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC4049D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC4049DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HC4049PW 40 C to +125 C 74HC4049 Nexperia Hex inverting HIGH-to-LOW level shifter 4. Functional diagram  $ $ $        < <  <  $ $ $       99 99 99     <  < <  DDL Fig 1. 99 99 99   < $ DDQ Logic symbol Fig 2. PQD IEC logic symbol Fig 3. Logic diagram (one level shifter) 5. Pinning information 5.1 Pinning +& 9&&   QF <   < $   $ < $ < $ *1'  +& 9&&   QF <   < $   $  < <   QF  $ $   < <   $ $   < *1'   QF     <   $ DDQ Fig 4. Pin configuration SO16 74HC4049 Product data sheet  $ DDQ Fig 5. Pin configuration SSOP16 and TSSOP16 All information provided in this document is subject to legal disclaimers. . Rev. 7 — 5 February 2016 2 of 14 © Nexperia B.V. 2017. All rights reserved 74HC4049 Nexperia Hex inverting HIGH-to-LOW level shifter 5.2 Pin description Table 2. Pin description Symbol Pin Description VCC 1 supply voltage 1Y to 6Y 2, 4, 6, 10, 12, 15 output 1A to 6A 3, 5, 7, 9, 11, 14 input GND 8 ground (0 V) n.c. 13, 16 not connected 6. Functional description Table 3. Function table [1] Input Output nA nY L H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage 0.5 +7 V VIK input clamping voltage 0.5 +16 V IIK input clamping current VI < 0.5 V 20 - mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA VO = 0.5 V to (VCC + 0.5 V) IO output current - 25 mA ICC supply current - +50 mA IGND ground current - 50 mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] SO16, SSOP16 and TSSOP16 packages [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. For SSOP16 and TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 74HC4049 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 7 — 5 February 2016 3 of 14 © Nexperia B.V. 2017. All rights reserved 74HC4049 Nexperia Hex inverting HIGH-to-LOW level shifter ȍ LQSXW WRORJLF FLUFXLW SRO\VLOLFRQ UHVLVWRU ' *1' DDQ Fig 6. Input protection for the 74HC4049 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 2.0 5.0 6.0 V 0 - 15 V 0 - VCC V 40 +25 +125 C VCC = 2.0 V; VI = 2.0 V - - 625 ns/V VCC = 4.5 V; VI = 4.5 V - 1.67 139 ns/V VCC = 6.0 V; VI = 6.0 V - - 83 ns/V VCC = 6.0 V; VI = 10.0 V - - 81 ns/V VCC = 6.0 V; VI = 15.0 V - - 83 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74HC4049 Product data sheet Tamb = 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 3.15 VCC = 6.0 V 4.2 VCC = 2.0 V - VCC = 4.5 V - VCC = 6.0 V Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Max Min Max Min Max 1.3 - 1.5 - 1.5 - V 2.4 - 3.15 - 3.15 - V 3.1 - 4.2 - 4.2 - V 0.7 0.5 - 0.5 - 0.5 V 1.8 1.35 - 1.35 - 1.35 V - 2.3 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. . Rev. 7 — 5 February 2016 4 of 14 © Nexperia B.V. 2017. All rights reserved 74HC4049 Nexperia Hex inverting HIGH-to-LOW level shifter Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL VI = VIH or VIL Tamb = 25 C Min II LOW-level output voltage input leakage current ICC supply current CI input capacitance Tamb = 40 C to +85 C Tamb = 40 C to Unit +125 C Typ Max Min Max Min Max IO = 20 A; VCC = 2.0 V - - 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A VI = 15 V; VCC = 2.0 V to 6.0 V - - 0.5 - 5.0 - 5.0 A VI = 15 V or GND; IO = 0 A; VCC = 6.0 V - - 2.0 - 20 - 40 A - 3.5 - - - - - pF 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 8. Symbol Parameter tpd propagation delay Tamb = 25 C Conditions transition time 74HC4049 Product data sheet Tamb = 40 C to +125 C Unit Min Typ Max Min Max Min Max - 28 85 - 105 - 130 ns VCC = 4.5 V - 10 17 - 21 - 26 ns VCC = 5 V; CL = 15 pF - 8 - - - - - ns - 8 14 - 18 - 22 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns nA to nY; see Figure 7 [1] VCC = 2.0 V VCC = 6.0 V tt Tamb = 40 C to +85 C Yn; see Figure 7 [2] All information provided in this document is subject to legal disclaimers. . Rev. 7 — 5 February 2016 5 of 14 © Nexperia B.V. 2017. All rights reserved 74HC4049 Nexperia Hex inverting HIGH-to-LOW level shifter Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 8. Tamb = 25 C Symbol Parameter Conditions CPD CL = 50 pF; f = 1 MHz; VI = GND to VCC [1] power dissipation capacitance Tamb = 40 C to +85 C Tamb = 40 C to +125 C Min Typ Max Min Max Min Max - 14 - - - - - [3] Unit pF tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, Q$LQSXW 90 90 *1' W 3+/ W 3/+ 92+ Q
74HC4049DB,118 价格&库存
很抱歉,暂时无法提供与“74HC4049DB,118”相匹配的价格&库存,您可以联系我们找货
