74LV08DB,118
74LV08DB,118
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    电压电平转换器 5V 50mA SSOP14_6.4X5.4MM
74LV08DB,118 数据手册
74LV08 Quad 2-input AND gate Rev. 4 — 8 December 2015 Product data sheet 1. General description The 74LV08 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC08 and 74HCT08. The 74LV08 provides a quad 2-input AND function. 2. Features and benefits      Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 C  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV08D 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV08DB 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LV08PW 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV08 Nexperia Quad 2-input AND gate 4. Functional diagram        $  %  $  %  $  %  $  % <  <     <  <  $  <   % Fig 1. PQD PQD PQD Logic symbol Fig 2. IEC logic symbol Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning /9 /9 $   9&& %   % $   9&& <   $ %   %  < <  $  %  <   $ *1'   < $ % < *1'    %     $ Pin configuration SO14 74LV08 Product data sheet  <  % < DDM DDM Fig 4.  $  Fig 5. Pin configuration (T)SSOP14 All information provided in this document is subject to legal disclaimers. Rev. 4 — 8 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 13 74LV08 Nexperia Quad 2-input AND gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A 1, 4, 9, 12 data input 1B, 2B, 3B, 4B 2, 5, 10, 13 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Input Output nA nB nY L X L X L L H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) Min Max Unit 0.5 +7.0 V - 20 mA - 50 mA - 25 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW Ptot total power dissipation Tamb = 40 C to +125 C [2] SO14, SSOP14, TSSOP14 [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For (T)SSOP14 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. 74LV08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 8 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 13 74LV08 Nexperia Quad 2-input AND gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions voltage[1] Min Typ Max Unit 1.0 3.3 5.5 V VCC supply VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74LV08 Product data sheet 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 1.2 V 0.9 - - 0.9 - V VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V - - 0.3 - 0.3 V VCC = 1.2 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V IO = 100 A; VCC = 1.2 V - 1.2 - - - V IO = 100 A; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = 100 A; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = 100 A; VCC = 3.0 V 2.8 3.0 - 2.8 - V VI = VIH or VIL IO = 100 A; VCC = 4.5 V 4.3 4.5 - 4.3 - V IO = 6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V IO = 12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V All information provided in this document is subject to legal disclaimers. Rev. 4 — 8 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 13 74LV08 Nexperia Quad 2-input AND gate Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL 40 C to +85 C Conditions LOW-level output voltage Min Typ[1] 40 C to +125 C Unit Max Min Max VI = VIH or VIL IO = 100 A; VCC = 1.2 V - 0 - - - V IO = 100 A; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 40 A ICC additional supply current per input; VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 A CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter tpd propagation delay 40 C to +85 C Conditions Max Min Max VCC = 1.2 V - 45 - - - ns VCC = 2.0 V - 15 26 - 33 ns [2] - 11 17 - 21 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 7 - - - ns VCC = 3.0 V to 3.6 V [3] - 9.0 15 - 19 ns - - 11 - 14 ns - 10 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance Unit Min nA, nB to nY; see Figure 6 VCC = 2.7 V CPD 40 C to +125 C Typ[1] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. [4] [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V). [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 74LV08 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 8 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 13 74LV08 Nexperia Quad 2-input AND gate 11. Waveforms 9, 90 Q$Q%LQSXW *1' W 3+/ W 3/+ 92+ Q
74LV08DB,118 价格&库存
很抱歉,暂时无法提供与“74LV08DB,118”相匹配的价格&库存,您可以联系我们找货
