74LV08D-Q100,118
74LV08D-Q100,118
    NEXPERIA(安世)
    SO-14_8.65X3.9MM
    电压电平转换器 5V 50mA SOIC14_8.75X4MM
74LV08D-Q100,118 数据手册
74LV08-Q100 Quad 2-input AND gate Rev. 1 — 31 July 2012 Product data sheet 1. General description The 74LV08-Q100 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC08-Q100 and 74HCT08-Q100. The 74LV08-Q100 provides a quad 2-input AND function. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide operating voltage: 1.0 V to 5.5 V  Optimized for low voltage applications: 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C  Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 C  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV08D-Q100 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV08PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV08-Q100 Nexperia Quad 2-input AND gate 4. Functional diagram 1 & 3 & 6 2 1 1A 2 1B 4 2A 5 2B 9 3A 10 3B 12 4A 13 4B 1Y 3 4 2Y 6 5 3Y 8 9 A Y & 8 B 10 4Y mna221 11 12 mna222 & 11 13 mna223 Fig 1. Logic symbol Fig 2. IEC logic symbol Fig 3. Logic diagram (one gate) 5. Pinning information 5.1 Pinning /94 /94 $   9&& %   % $  <   $  9&& %   %   $ $   < < %   % $   < %   % <   <   $ *1'   < *1'   $ < DDD Fig 4. Pin configuration SO14 74LV08_Q100 Product data sheet DDD Fig 5. Pin configuration TSSOP14 All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 2 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A 1, 4, 9, 12 data input 1B, 2B, 3B, 4B 2, 5, 10, 13 data input 1Y, 2Y, 3Y, 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function selection[1] Input Output nA nB nY L X L X L L H H H [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) ICC IGND Tstg storage temperature Max Unit 0.5 +7.0 V - 20 mA - 50 mA - 25 mA supply current - 50 mA ground current 50 - mA 65 +150 C - 500 mW total power dissipation Ptot Conditions Tamb = 40 C to +125 C Min [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO14 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For TSSOP14 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 3 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions voltage[1] Min Typ Max Unit 1.0 3.3 5.5 V VCC supply VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 9. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74LV08_Q100 Product data sheet 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max VCC = 1.2 V 0.9 - - 0.9 - VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.3VCC - 0.3VCC V IO = 100 A; VCC = 1.2 V - 1.2 - - - V IO = 100 A; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = 100 A; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = 100 A; VCC = 3.0 V 2.8 3.0 - 2.8 - V IO = 100 A; VCC = 4.5 V 4.3 4.5 - 4.3 - V IO = 6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V IO = 12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 4 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate Table 6. Static characteristics …continued Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOL 40 C to +85 C Conditions LOW-level output voltage 40 C to +125 C Unit Min Typ[1] IO = 100 A; VCC = 1.2 V - 0 - - - V IO = 100 A; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 3.0 V - 0 0.2 - 0.2 V Max Min Max VI = VIH or VIL IO = 100 A; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 40 A ICC additional supply current per input; VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 A CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions Max Min Max VCC = 1.2 V - 45 - - - ns VCC = 2.0 V - 15 26 - 33 ns [2] - 11 17 - 21 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 7 - - - ns VCC = 3.0 V to 3.6 V [3] - 9.0 15 - 19 ns - - 11 - 14 ns - 10 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance Unit Min nA, nB to nY; see Figure 6 VCC = 2.7 V CPD 40 C to +125 C Typ[1] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. [4] [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V). [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 5 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 11. Waveforms VI VM nA, nB input GND t PHL t PLH VOH VM nY output VOL mna224 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. The input (nA, nB) to output (nY) propagation delays Measurement points Supply voltage Input Output VCC VM VM < 2.7 V 0.5VCC 0.5VCC 2.7 V to 3.6 V 1.5 V 1.5 V  4.5 V 0.5VCC 0.5VCC VCC PULSE GENERATOR VI VO DUT RT CL 50 pF RL 1 kΩ 001aaa663 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. Fig 7. Table 9. Load circuit for switching times Test data Supply voltage Input VCC VI tr, tf < 2.7 V VCC  2.5 ns 2.7 V to 3.6 V 2.7 V  2.5 ns  4.5 V VCC  2.5 ns 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 6 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 7 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 8 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic Military MIL 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV08_Q100 v.1 20120731 Product data sheet - - 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 9 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LV08_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 10 of 12 74LV08-Q100 Nexperia Quad 2-input AND gate No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LV08_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 31 July 2012 © Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia 74LV08-Q100 Quad 2-input AND gate 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 4 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 31 July 2012 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LV08D-Q100,118 74LV08PW-Q100,118
74LV08D-Q100,118 价格&库存
很抱歉,暂时无法提供与“74LV08D-Q100,118”相匹配的价格&库存,您可以联系我们找货
