74LV132BQ,115
74LV132BQ,115
    NEXPERIA(安世)
    DHVQFN-14-EP(2.5x3)
    电压电平转换器 5V 50mA DHVQFN14_3X2.5MM-EP
74LV132BQ,115 数据手册
74LV132 Quad 2-input NAND Schmitt trigger Rev. 6 — 9 December 2015 Product data sheet 1. General description The 74LV132 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC132 and 74HCT132. The 74LV132 contains four 2-input NAND gates which accept standard input signals. They are capable of transforming slowly changing input signals into sharply defined, jitter-free output signals. The gate switches at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. 2. Features and benefits      Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 C  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Applications  Wave and pulse shapers for highly noisy environments  Astable multivibrators  Monostable multivibrators 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV132D 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV132DB 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LV132PW 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV132BQ 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm SOT762-1 5. Functional diagram  $ <   $ <   %   %   $ <         %    $ <    Logic symbol 74LV132 Product data sheet <  % % PQD PQD Fig 1. $ Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 6 — 9 December 2015 PQD Fig 3. Logic diagram (one gate) © Nexperia B.V. 2017. All rights reserved 2 of 17 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 6. Pinning information 6.1 Pinning 1A terminal 1 index area 14 VCC 74LV132   9&& %   % 1B 2 13 4B  $ 1Y 3 12 4A 2A 4 2B 5 2Y 6 1 $   < %   % <   $ *1'   < 11 4Y VCC (1) 10 3B 9 8  3Y $ 7  GND < 3A 001aah099 Transparent top view DDF (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 4. Pin configuration SO14 and (T)SSOP14 Fig 5. Pin configuration DHVQFN14 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 4, 9, 12 data input 1B to 4B 2, 5, 10, 13 data input 1Y to 4Y 3, 6, 8, 11 data output GND 7 ground (0 V) VCC 14 supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nB nY L L H L H H H L H H H L 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V - 20 mA - 50 mA - 25 mA 50 mA IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) ICC supply current - IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation Tamb = 40 C to +125 C SO14 package [2] - 500 mW (T)SSOP14 package [3] - 500 mW DHVQFN14 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. [4] Ptot derates linearly with 4.5 mW/K above 60 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage[1] VI Min Typ Max Unit 1.0 3.3 5.5 V input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C [1] Conditions The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 10. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH HIGH-level output voltage LOW-level output voltage VOL Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max lO = 100 A; VCC = 1.2 V - 1.2 - - - V lO = 100 A; VCC = 2.0 V 1.8 2.0 - 1.8 - V lO = 100 A; VCC = 2.7 V 2.5 2.7 - 2.5 - V lO = 100 A; VCC = 3.0 V 2.8 3.0 - 2.8 - V lO = 100 A; VCC = 4.5 V 4.3 4.5 - 4.3 - V lO = 6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V lO = 12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V IO = 100 A; VCC = 1.2 V - 0 - - - V IO = 100 A; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V - 0.35 0.55 - 0.65 V VI = VT+ or VT VI = VT+ or VT II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 40 A ICC additional supply current per input; VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 A CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 C. 74LV132 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 17 74LV132 Nexperia Quad 2-input NAND Schmitt trigger 11. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter propagation delay tpd 40 C to +85 C Conditions power dissipation capacitance [1] Min Max Min Max VCC = 1.2 V - 65 - - - ns VCC = 2.0 V - 18 34 - 43 ns 24 - 30 ns nA, nB to nY; see Figure 6 - 15 VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 10 - - - ns VCC = 3.0 V to 3.6 V [3] - 12 20 - 25 ns VCC = 4.5 V to 5.5 V [3] - 9.0 14 - 17 ns CL = 50 pF; fi = 1 MHz; VI = GND to VCC [4] - 24 - - - pF All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [4] Unit [2] VCC = 2.7 V CPD 40 C to +125 C Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 12. Waveforms 9, 90 Q$Q%LQSXW *1' W 3+/ W 3/+ 92+ 90 Q
74LV132BQ,115 价格&库存
很抱歉,暂时无法提供与“74LV132BQ,115”相匹配的价格&库存,您可以联系我们找货
74LV132BQ,115
  • 1+2.734371+0.35420
  • 10+1.8638610+0.24144
  • 25+1.6500225+0.21374
  • 100+1.41942100+0.18387
  • 250+1.30866250+0.16952
  • 500+1.24243500+0.16094
  • 1000+1.187661000+0.15385
库存:3868
74LV132BQ,115
    74LV132BQ,115
      • 5+1.07828
      • 50+1.05516
      • 150+1.03972
      • 500+1.02428
