74LV14PW,118
74LV14PW,118
    NEXPERIA(安世)
    TSSOP14_5.1X4.5MM
    电压电平转换器 5V 50mA TSSOP14_5.1X4.5MM
74LV14PW,118 数据手册
74LV14 Hex inverting Schmitt trigger Rev. 7 — 9 December 2015 Product data sheet 1. General description The 74LV14 is a low-voltage Si-gate CMOS device that is pin and function compatible with 74HC14 and 74HCT14. The 74LV14 provides six inverting buffers with Schmitt-trigger input. It is capable of transforming slowly-changing input signals into sharply defined, jitter-free output signals. The inputs switch at different points for positive and negative-going signals. The difference between the positive voltage VT+ and the negative voltage VT is defined as the input hysteresis voltage VH. 2. Features and benefits      Wide operating voltage: 1.0 V to 5.5 V Optimized for low voltage applications: 1.0 V to 3.6 V Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and Tamb = 25 C  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Applications  Wave and pulse shapers for highly noisy environments  Astable multivibrators  Monostable multivibrators 74LV14 Nexperia Hex inverting Schmitt trigger 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV14D 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV14DB 40 C to +125 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LV14PW 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV14BQ 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm SOT762-1 5. Functional diagram       $ < $ < $ < $ < $ < $ < Logic symbol 74LV14 Product data sheet                  PQD Fig 1.  $ < PQD DDF Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 7 — 9 December 2015 Fig 3. Logic diagram for one Schmitt trigger © Nexperia B.V. 2017. All rights reserved 2 of 18 74LV14 Nexperia Hex inverting Schmitt trigger 6. Pinning information 6.1 Pinning  $ WHUPLQDO LQGH[DUHD  $   < <   $ $   < <   $ *1'   < <   $ $   < <  $  <   $ 9&&   <   <  9&&  $ <   $ *1' /9  9&& /9 $ DDK 7UDQVSDUHQWWRSYLHZ DDK (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 4. Pin configuration SO14 and (T)SSOP14 Fig 5. Pin configuration DHVQFN14 6.2 Pin description Table 2. Pin description Symbol Pin Description 1A 1 data input 1Y 2 data output 2A 3 data input 2Y 4 data output 3A 5 data input 3Y 6 data output GND 7 ground (0 V) 4Y 8 data output 4A 9 data input 5Y 10 data output 5A 11 data input 6Y 12 data output 6A 13 data input VCC 14 supply voltage 74LV14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 18 74LV14 Nexperia Hex inverting Schmitt trigger 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input nA Output nY L H H L 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V - 20 mA - 50 mA - 25 mA input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation IIK Tamb = 40 C to +125 C SO14 package [2] - 500 mW (T)SSOP14 package [3] - 500 mW DHVQFN14 package [4] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. [4] Ptot derates linearly with 4.5 mW/K above 60 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions [1] Min Typ Max Unit VCC supply voltage 1.0 3.3 5.5 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C [1] The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 74LV14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 18 74LV14 Nexperia Hex inverting Schmitt trigger 10. Static characteristics Table 6. Static characteristics Voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH HIGH-level output voltage LOW-level output voltage VOL Conditions Tamb = 40 C to +85 C Tamb = 40 C to +125 C Unit Min Typ[1] Max Min Max IO = 100 A; VCC = 1.2 V - 1.2 - - - V IO = 100 A; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = 100 A; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = 100 A; VCC = 3.0 V 2.8 3.0 - 2.8 - V IO = 100 A; VCC = 4.5 V 4.3 4.5 - 4.3 - V IO = 6 mA; VCC = 3.0 V 2.4 2.82 - 2.2 - V IO = 12 mA; VCC = 4.5 V 3.6 4.2 - 3.5 - V IO = 100 A; VCC = 1.2 V - 0 - - - V IO = 100 A; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 4.5 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V IO = 12 mA; VCC = 4.5 V VI = VT+ or VT VI = VT+ or VT - 0.35 0.55 - 0.65 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 20.0 - 40 A ICC additional supply current per input; VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 A CI input capacitance - 3.5 - - - pF [1] Typical values are measured at Tamb = 25 C. 74LV14 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 9 December 2015 © Nexperia B.V. 2017. All rights reserved 5 of 18 74LV14 Nexperia Hex inverting Schmitt trigger 11. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; For test circuit see Figure 7. Symbol Parameter propagation delay tpd Tamb = 40 C to +85 C Conditions Typ[1] Max Min Max VCC = 1.2 V - 80 - - - ns VCC = 2.0 V - 27 37 - 48 ns [2] nA to nY; see Figure 6 - 20 28 - 35 ns VCC = 3.0 V to 3.6 V; CL = 15 pF [3] - 13 - - - ns VCC = 3.0 V to 3.6 V [3] - 15 22 - 28 ns - - 18 - 23 ns - 15 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance Unit Min VCC = 2.7 V CPD Tamb = 40 C to +125 C [4] CL = 50 pF; fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at Tamb = 25 C. [2] tpd is the same as tPLH and tPHL. [3] Typical values are measured at nominal supply voltage (VCC = 3.3 V). [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz, fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in V N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 12. Waveforms 9, 90 Q$LQSXW 90 *1' W 3+/ W 3/+ 92+ 90 Q
74LV14PW,118
物料型号:74LV14
器件简介:74LV14是一款低压Si-gate CMOS设备,与74HC14和74HCT14引脚和功能兼容。它提供六个带有Schmitt触发器输入的反相缓冲器,能够将缓慢变化的输入信号转换为清晰、无抖动的输出信号。
引脚分配:74LV14有14个引脚,包括6个数据输入(1A、2A、3A、4A、5A、6A)和6个数据输出(1Y、2Y、3Y、4Y、5Y、6Y),以及供电电压(Vcc)和地(GND)。
参数特性:74LV14的工作电压范围宽,为1.0V至5.5V,优化用于1.0V至3.6V的低电压应用。它接受在VCC为2.7V至3.6V之间的TTL输入电平。此外,它还具有ESD保护功能。
功能详解:74LV14的输入在正向和负向信号的不同点切换,输入的正向电压阈值VT+和负向电压阈值VT-之间的差异定义为输入滞后电压VH。
应用信息:74LV14适用于高度嘈杂环境中的波形和脉冲整形、稳定多谐振荡器和单稳态多谐振荡器。
封装信息:74LV14有多种封装选项,包括SO14、SSOP14、TSSOP14和DHVQFN14。
74LV14PW,118 价格&库存
很抱歉,暂时无法提供与“74LV14PW,118”相匹配的价格&库存,您可以联系我们找货
74LV14PW,118
    • 5+1.87899
    • 50+1.50963
    • 150+1.35141
    • 500+1.15388
    • 2500+1.05538
    • 5000+1.00257
    库存:1970
