74LVC02A
Quad 2-input NOR gate
Rev. 8 — 16 November 2011
Product data sheet
1. General description
The 74LVC02A provides four 2-input NOR gates.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in mixed 3.3 V and 5 V applications.
2. Features and benefits
5 V tolerant inputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Complies with JEDEC standard:
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A (2.3 V to 2.7 V)
JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-B exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC02AD
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LVC02ADB
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
74LVC02APW
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LVC02ABQ
40 C to +125 C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
SOT762-1
74LVC02A
Nexperia
4. Functional diagram
2
1
1
1
4
3
2
1A
3
1B
5
2A
6
2B
8
3A
9
3B
11
4A
12
4B
1Y
1
5
2Y
4
6
3Y
10
8
A
Y
1
10
B
9
4Y
mna215
13
11
mna216
1
13
12
mna217
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram for one gate
5. Pinning information
1
1Y
terminal 1
index area
14 VCC
5.1 Pinning
1
14 VCC
1A
2
13 4Y
2Y
4
1B
3
12 4B
2A
5
2Y
4
2B
6
2A
5
10 3Y
8
12 4B
1Y
2B
6
9
3B
3A
13 4Y
3
7
2
1B
GND
7
8
3A
GND
1A
02
11 4A
02
11 4A
GND(1)
10 3Y
9
3B
001aac920
Transparent top view
001aac919
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and (T)SSOP14
74LVC02A
Product data sheet
Fig 5.
Pin configuration DHVQFN14
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
74LVC02A
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1Y to 4Y
1, 4, 10, 13
data output
1A to 4A
2, 5, 8, 11
data input
1B to 4B
3, 6, 9,12
data input
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table[1]
Input nA
Input nB
Output nY
L
L
H
X
H
L
H
X
L
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO > VCC or VO < 0 V
VO
output voltage
output in HIGH or LOW-state
IO
output current
VO = 0 V to VCC
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Tamb = 40 C to +125 C
[2]
[3]
[1]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
For SO14 packages: above 70 C derate linearly with 8 mW/K.
Min
Max
Unit
0.5
+6.5
V
50
mA
0.5
+6.5
V
50
mA
0.5
VCC + 0.5
V
50
mA
100
mA
100
mA
500
mW
65
+150
C
For (T)SSOP14 packages: above 60 C derate linearly with 5.5 mW/K.
For DHVQFN14 packages: above 60 C derate linearly with 4.5 mW/K.
74LVC02A
Product data sheet
3 of 14
74LVC02A
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
VCC
supply voltage
functional
Min
Typ
Max
Unit
1.65
3.6
V
1.2
V
V
VCC
V
VI
input voltage
VO
output voltage
Tamb
ambient temperature
40
+125
C
t/V
input transition rise and fall rate VCC = 1.65 V to 2.7 V
ns/V
ns/V
output HIGH or LOW state
VCC = 2.7 V to 3.6 V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
VIH
VIL
VOH
VOL
II
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output
voltage
LOW-level
output
voltage
Product data sheet
40 C to +125 C
Max
Min
Unit
Max
VCC = 1.2 V
1.08
1.08
V
VCC = 1.65 V to 1.95 V
0.65 VCC -
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
0.35 VCC -
0.35 VCC V
0.7
0.7
V
0.8
0.8
V
IO = 100 A;
VCC = 1.65 V to 3.6 V
VCC 0.2
VCC 0.3
V
IO = 4 mA; VCC = 1.65 V
1.2
1.05
V
IO = 8 mA; VCC = 2.3 V
1.8
1.65
V
IO = 12 mA; VCC = 2.7 V
2.2
2.05
V
IO = 18 mA; VCC = 3.0 V
2.4
2.25
V
IO = 24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 A;
0.2
0.3
V
0.45
0.65
V
0.6
0.8
V
VI = VIH or VIL
VI = VIH or VIL
0.4
0.6
V
0.55
0.8
V
0.1
5
A
input leakage VCC = 3.6 V; VI = 5.5 V or GND current
74LVC02A
Typ[1]
4 of 14
74LVC02A
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
Typ[1]
Min
40 C to +125 C
Max
Min
Unit
Max
ICC
supply
current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
A
ICC
additional
supply
current
per input pin;
VCC = 2.7 V to 3.6 V;
VI = VCC 0.6 V; IO = 0 A
5
500
5000
A
CI
input
capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
4.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
Min
Max
Min
Max
14
ns
0.5
4.0
8.6
0.5
10.1
ns
1.0
2.4
4.9
1.0
5.7
ns
nA, nB to nY; see Figure 6
[2]
VCC = 1.2 V
tsk(o)
power dissipation
capacitance
CPD
[1]
output skew time
40 C to +125 C Unit
Typ[1]
VCC = 2.7 V
1.0
2.5
5.1
1.0
6.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.2
4.4
1.0
5.5
ns
1.0
1.5
ns
[3]
per gate; VI = GND to VCC
[4]
2.5
pF
5.7
pF
8.5
pF
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
74LVC02A
Product data sheet
5 of 14
74LVC02A
Nexperia
11. AC waveforms
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VI
nA, nB input
VM
VCC
GND
tPHL
PULSE
GENERATOR
tPLH
VOH
nY output
VI
VO
DUT
RT
CL
RL
VM
mna213
VOL
001aaf615
VM = 1.5 V at VCC 2.7 V.
Test data is given in Table 8.
VM = 0.5 VCC at VCC < 2.7 V.
Definitions for test circuit:
VOL and VOH are typical output voltage levels that occur
with the output load.
RL = Load resistance.
CL = Load capacitance including jig and probe
capacitance.
RT = Termination resistance should be equal to output
impedance Zo of the pulse generator.
Fig 6.
Table 8.
The input (nA, nB) to output (nY) propagation
delays
Fig 7.
Load circuitry for measuring switching times
Test data
Supply voltage
Input
Load
VI
tr, tf
CL
RL
1.2 V
VCC
2 ns
30 pF
1 k
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
2.7 V
2.7 V
2.5 ns
50 pF
500
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
74LVC02A
Product data sheet
6 of 14
74LVC02A
Nexperia
12. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 8.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74LVC02A
Product data sheet
7 of 14
74LVC02A
Nexperia
SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm
D
SOT337-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
7
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.4
0.9
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT337-1
Fig 9.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Package outline SOT337-1 (SSOP14)
74LVC02A
Product data sheet
8 of 14
74LVC02A
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 10. Package outline SOT402-1 (TSSOP14)
74LVC02A
Product data sheet
9 of 14
74LVC02A
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 11. Package outline SOT762-1 (DHVQFN14)
74LVC02A
Product data sheet
10 of 14
74LVC02A
Nexperia
13. Abbreviations
Table 9.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC02A v.8
20111116
Product data sheet
74LVC02A v.7
Modifications:
Legal pages updated.
Table 6, bodyrow ICC: condition VCC changed.
74LVC02A v.7
20111019
Product data sheet
74LVC02A v.6
74LVC02A v.6
20110809
Product data sheet
74LVC02A v.5
74LVC02A v.5
20040312
Product specification
74LVC02A v.4
74LVC02A v.4
20030501
74LVC02A v.3
74LVC02A v.3
20020305
74LVC02A v.2
74LVC02A v.2
19980428
74LVC02A v.1
74LVC02A v.1
19970811
74LVC02A
Product data sheet
11 of 14
74LVC02A
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
74LVC02A
Product data sheet
12 of 14
74LVC02A
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC02A
Product data sheet
13 of 14
Nexperia
74LVC02A
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
AC waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 16 November 2011
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC02ABQ,115 74LVC02AD,112 74LVC02ADB,112 74LVC02ADB,118 74LVC02AD,118 74LVC02APW,112
74LVC02APW,118 74LVC02APW/AUJ
