74LVC06ABQ-Q100X
74LVC06ABQ-Q100X
    NEXPERIA(安世)
    DHVQFN-14-EP(2.5x3)
    电压电平转换器 5V 100mA DHVQFN14_3X2.5MM-EP
74LVC06ABQ-Q100X 数据手册
74LVC06A-Q100 Hex inverter with open-drain outputs Rev. 2 — 2 October 2019 Product data sheet 1. General description The 74LVC06A-Q100 provides six inverting buffers. The outputs are open-drain and can be connected to other open-drain outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V applications. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 5 V tolerant inputs and outputs (open-drain) for interfacing with 5 V logic Wide supply voltage range from 1.2 V to 5.5 V CMOS low power consumption Direct interface with TTL levels Complies with JEDEC standard: • JESD8-7A (1.65 V to 1.95 V) • JESD8-5A (2.3 V to 2.7 V) • JESD8-C/JESD36 (2.7 V to 3.6 V) ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVC06APW-Q100 -40 °C to +125 °C TSSOP14 plastic thin shrink outline package; 14 leads; body width 4.4 mm SOT402-1 74LVC06ABQ-Q100 DHVQFN14 plastic dual in-line compatible thermal enhanced SOT762-1 very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74LVC06AD-Q100 -40 °C to +125 °C 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 4. Functional diagram 1 1A 1Y 2 3 2A 2Y 4 5 3A 3Y 6 9 4A 4Y 8 11 5A 5Y 10 13 6A 6Y 12 1A 2A 3A 4A 5A 6A 1 1 2 3 1 4 5 1 6 9 1 8 11 1 10 13 mna525 Fig. 1. 1 12 1Y 2Y 3Y 4Y 5Y Y A 6Y mna526 Logic symbol Fig. 2. GND mna527 IEC logic symbol Fig. 3. Logic diagram for one gate 5. Pinning information 5.1. Pinning 1 74LVC06A-Q100 13 6A 3 13 6A 2Y 4 11 5A 3A 5 10 5Y 3Y 6 12 6Y GND(1) 2A 3 12 6Y 2Y 4 11 5A 8 2 2 2A 7 1Y 1Y 3A 5 10 5Y 4Y 14 VCC GND 1A 1 3Y 6 9 4A GND 7 8 4Y 9 4A aaa-007302 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. aaa-007301 Fig. 4. 1A terminal 1 index area 14 VCC 74LVC06A-Q100 Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) Fig. 5. Pin configuration SOT762-1 (DHVQFN14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A, 4A, 5A, 6A 1, 3, 5, 9, 11, 13 data input 1Y, 2Y, 3Y, 4Y, 5Y, 6Y 2, 4, 6, 8, 10, 12 data output GND 7 ground (0 V) VCC 14 supply voltage 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 2 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state Input Output nA nY L Z H L 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO < 0 VO output voltage active mode high-impedance mode VI < 0 Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 -50 - [2] -0.5 +6.5 V [2] -0.5 +6.5 V [1] V mA IO output current - 50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW Min Typ Max Unit 1.65 - 5.5 V 1.2 - - V [1] [2] [3] VO = 0 V to VCC mA Tamb = -40 °C to +125 °C [3] The minimum input voltage ratings may be exceeded if the input current ratings are observed. The output voltage ratings may be exceeded if the output current ratings are observed. For SOT108-1 (SO14) packages: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) packages: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) packages: Ptot derates linearly with 9.6 mW/K above 98 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions supply voltage functional VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74LVC06A_Q100 Product data sheet 0 - 5.5 V active mode 0 - 5.5 V high-impedance mode 0 - 5.5 V -40 - +125 °C VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 5.5 V 0 - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 3 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions -40 °C to +85 °C HIGH-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V VIH VOL LOW-level output voltage Unit Min Typ [1] Max Min Max 1.08 - - 1.08 - V 0.65 × VCC - - 0.65 × VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - 0.7 × VCC - V - - 0.12 - 0.12 V LOW-level input VCC = 1.2 V voltage VCC = 1.65 V to 1.95 V VIL -40 °C to +125 °C - - 0.35 × VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.35 × VCC V 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V - - 0.30 × VCC - IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.20 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.6 V IO = 8 mA; VCC = 2.3 V - - 0.3 - 0.75 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V IO = 32 mA; VCC = 4.5 V - - 0.55 - 0.8 V 0.30 × VCC V VI = VIH or VIL II input leakage current VI = 5.5 V or GND; VCC = 1.65 V to 5.5 V - ±0.1 ±5 - ±20 μA IOZ OFF-state output current VI = VIH; VO = 5.5 V or GND; VCC = 1.65 V to 5.5 V - ±0.1 ±10 - ±20 μA IOFF power-off VI or VO = 5.5 V; VCC = 0 V leakage current - ±0.1 ±10 - ±20 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - 0.1 10 - 40 μA ΔICC additional supply current per input pin; VI = VCC - 0.6 V; IO = 0 A; VCC = 2.7 V to 5.5 V - 5 500 - 5000 μA CI input capacitance VCC = 0 V to 5.5 V; VI = GND to VCC - 5.0 - - - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 4 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7. Symbol Parameter Conditions -40 °C to +85 °C Min tPZL OFF-state to LOW propagation delay tPLZ LOW to OFF-state propagation delay CPD [1] [2] power dissipation capacitance Typ [1] -40 °C to +125 °C Unit Max Min Max nA to nY; see Fig. 6 VCC = 1.2 V - 9 - - - ns VCC = 1.65 V to 1.95 V 0.5 2.8 5.7 0.5 6.7 ns VCC = 2.3 V to 2.7 V 0.5 1.9 3.1 0.5 4.0 ns VCC = 2.7 V 0.5 1.8 3.9 0.5 5.0 ns VCC = 3.0 V to 3.6 V 0.5 1.8 3.7 0.5 5.0 ns VCC = 4.5 V to 5.5 V 0.7 1.5 2.5 0.7 3.5 ns - 10 - - - ns VCC = 1.65 V to 1.95 V 0.5 2.6 5.7 0.5 6.7 ns VCC = 2.3 V to 2.7 V 0.5 1.4 3.1 0.5 4.0 ns VCC = 2.7 V 0.5 2.6 3.9 0.5 5.0 ns VCC = 3.0 V to 3.6 V 0.5 2.2 3.7 0.5 5.0 ns VCC = 4.5 V to 5.5 V 0.6 1.5 2.6 0.6 3.5 ns VCC = 1.65 V to 1.95 V - 6.5 - - - pF VCC = 2.3 V to 2.7 V - 6.9 - - - pF VCC = 3.0 V to 3.6 V - 7.2 - - - pF nA to nY; see Fig. 6 VCC = 1.2 V per buffer; VI = GND to VCC [2] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC × fo) = sum of the outputs 10.1. Waveforms VI VM nA input GND t PLZ t PZL VCC nY output VM VX VOL mna529 Measurement points are given in Table 8 Logic level: VOL is a typical output voltage level that occurs with the output load. Fig. 6. The input nA to output nY propagation delays 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 5 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs Table 8. Measurement points Supply voltage Input Output VCC VM VX < 2.7 V 0.5 × VCC VOL + 0.15 V ≥ 2.7 V to 3.6 V 1.5 V VOL + 0.3 V ≥ 4.5 V to 5.5 V 0.5 × VCC VOL + 0.3 V tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 6 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 Fig. 8. JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 7 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 Fig. 9. REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Package outline SOT402-1 (TSSOP14) 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 8 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 10. Package outline SOT762-1 (DHVQFN14) 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 9 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC06A_Q100 v.2 20191002 Product data sheet - Modifications: • • • • 74LVC06A_Q100 v.1 74LVC06A_Q100 Product data sheet 74LVC06A_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 4: Derating values for Ptot total power dissipation updated. Package outline drawing SOT762-1 (DHVQFN14) updated. 20130514 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 - © Nexperia B.V. 2019. All rights reserved 10 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 11 / 12 74LVC06A-Q100 Nexperia Hex inverter with open-drain outputs Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 2 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................3 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 5 10.1. Waveforms.................................................................5 11. Package outline.......................................................... 7 12. Abbreviations............................................................ 10 13. Revision history........................................................10 14. Legal information......................................................11 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 October 2019 74LVC06A_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 2 October 2019 © Nexperia B.V. 2019. All rights reserved 12 / 12 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC06ABQ-Q100X 74LVC06APW-Q100J 74LVC06AD-Q100J
74LVC06ABQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74LVC06ABQ-Q100X”相匹配的价格&库存,您可以联系我们找货
