74LVC11D,118
74LVC11D,118
    NEXPERIA(安世)
    SO-14_8.65X3.9MM
    电压电平转换器 1.65~3.6V 100mA SOIC14_8.75X4MM
74LVC11D,118 数据手册
74LVC11 Triple 3-input AND gate Rev. 7 — 10 November 2017 1 General description The 74LVC11 provides three 3-input AND functions. 2 Features and benefits • • • • • Wide supply voltage range from 1.2 V to 3.6 V Inputs accept voltages up to 5.5 V CMOS low power consumption Direct interface with TTL levels Complies with JEDEC standard: – JESD8-7A (1.65 V to 1.95 V) – JESD8-5A (2.3 V to 2.7 V) – JESD8-C/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM JESD22-A114F exceeds 2000 V – MM JESD22-A115-B exceeds 200 V – CDM JESD22-C101E exceeds 1000 V • Specified from -40 °C to +85 °C and -40 °C to +125 °C Product data sheet 74LVC11 Nexperia Triple 3-input AND gate 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC11D -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LVC11DB -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74LVC11PW -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LVC11BQ -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm 4 SOT762-1 Functional diagram 1 1 1A 2 1B 13 1C 3 2A 4 2B 5 2C 9 3A 10 3B 11 3C 2 1Y 12 2Y 6 3Y 8 4 & 6 5 A 9 10 & 8 11 Figure 1.  Logic symbol Product data sheet 12 13 3 mna793 74LVC11 & mna792 Figure 2.  IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 B C Y mna794 Figure 3.  Logic diagram for one gate © Nexperia B.V. 2017. All rights reserved. 2 / 15 74LVC11 Nexperia Triple 3-input AND gate 5 Pinning information 5.1 Pinning 1 1A terminal 1 index area 1B 2 13 1C 2A 3 12 1Y 2B 4 11 3C 2C 5 10 3B 2Y 6 9 3A GND 7 8 3Y 12 1Y 2B 4 11 3C 2C 5 2Y 6 74LVC11 1A 1 14 VCC 1B 2 13 1C 2A 3 12 1Y 2B 4 11 3C 2C 5 10 3B 2Y 6 9 3A GND 7 8 3Y aaa-027674 001aad043 Figure 5.  Pin configuration for Figure 4.  Pin configuration for SO14 (T)SSOP14 GND(1) 13 1C 10 3B 9 8 14 VCC 3 3Y 1 2 2A 7 1A 1B GND 74LVC11 14 VCC 74LVC11 3A 001aad044 Transparent top view (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad.However, if it is soldered, the solder land should remain floating or be connected to GND. Figure 6.  Pin configuration for DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A, 2A, 3A 1, 3, 9 data input 1B, 2B, 3B 2, 4, 10 data input 1C, 2C, 3C 13, 5, 11 data input 1Y, 2Y, 3Y 12, 6, 8 data output GND 7 ground (0 V) VCC 14 supply voltage 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 15 74LVC11 Nexperia Triple 3-input AND gate 6 Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = don’t care Output Input nA nB nC nY L X X L X L X L X X L L H H H H 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage IO output current ICC supply current IGND ground current Ptot total power dissipation Tstg storage temperature Conditions VI < 0 V [1] VO > VCC or VO < 0 V [2] VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] Min Max Unit -0.5 +6.5 V -50 - -0.5 +6.5 V - ±50 mA -0.5 VCC + 0.5 - ±50 mA - 100 mA -100 - mA - 500 mW -65 +150 °C mA V [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO14 packages: above 70 °C the value of PD derates linearly with 8 mW/K. For (T)SSOP14 packages: above 60 °C the value of PD derates linearly with 5.5 mW/K. For DHVQFN14 packages: above 60 °C the value of PD derates linearly with 4.5 mW/K. 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 15 74LVC11 Nexperia Triple 3-input AND gate 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V functional VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +125 °C Δt/ΔV input transition rise and fall VCC = 1.65 V to 2.7 V 0 - 20 ns/V rate VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9 Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage Conditions -40 °C to +85 °C Min Max - - 1.08 - V 0.65xVCC - - 0.65xVCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35xVCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC-0.2 - - VCC-0.3 - V IO = -4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = -8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = -12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = -18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = -24 mA; VCC = 3.0 V 2.2 - - 2.0 - V VCC = 1.2 V VCC = 1.65 V to 1.95 V Product data sheet Min Typ 1.08 -40 °C to +125 °C Unit Max VI = VIH or VIL HIGH-level output voltage IO = -100 μA; VCC = 1.65 V to 3.6 V 74LVC11 [1] All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 0.35xVCC V © Nexperia B.V. 2017. All rights reserved. 5 / 15 74LVC11 Nexperia Triple 3-input AND gate Symbol Parameter Conditions -40 °C to +85 °C Min VOL [1] -40 °C to +125 °C Unit Typ Max Min Max - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.55 - 0.8 V VCC = 3.6 V; VI = 5.5 V or GND - ±0.1 ±5 - ±20 μA VI = VIH or VIL LOW-level output voltage IO = 100 μA; VCC = 1.65 V to 3.6 V II input leakage current ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 μA ΔICC additional per input pin; VCC = 2.7 V to 3.6 V; supply current VI = VCC - 0.6 V; IO = 0 A - 5 500 - 5000 μA CI input capacitance - 5.0 - - - pF VCC = 0 V to 3.6 V; VI = GND to VCC [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C. 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 8. Symbol Parameter Conditions -40 °C to +85 °C Min tpd propagation delay nA, nB, nC to nY; see Figure 7 Max Min Max - 14.0 - - - ns VCC = 1.65 V to 1.95 V 1.0 4.7 12.2 1.0 14.1 ns VCC = 2.3 V to 2.7 V 1.5 2.8 6.9 1.5 8.0 ns VCC = 2.7 V 1.5 2.9 7.0 1.5 8.1 ns 1.5 2.5 6.2 1.5 7.2 ns VCC = 1.65 V to 1.95 V - 3.1 - - - pF VCC = 2.3 V to 2.7 V - 6.2 - - - pF VCC = 3.0 V to 3.6 V - 9.0 - - - pF VCC = 3.0 V to 3.6 V power dissipation capacitance -40 °C to +125 °C Unit [2] VCC = 1.2 V CPD Typ [1] per gate; VI = GND to VCC [3] [1] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL × VCC x fo) = sum of the outputs 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 15 74LVC11 Nexperia Triple 3-input AND gate 10.1 Waveforms and test circuit VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VI VCC VM nA, nB, nC input GND tPHL tPLH PULSE GENERATOR VI VO DUT RT VOH CL VM nY output VOL RL 001aaf615 mna795 Test data is given in Table 8. Definitions for test circuit: VM = 1.5 V at VCC ≥ 2.7 V. VM = 0.5 x VCC at VCC < 2.7 V. RL = Load resistance. propagation delays Figure 8.  Test circuit for measuring switching times VOL and VOH are typical output voltage levels that occur with CL = Load capacitance including jig and probe capacitance. the output load. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Figure 7.  Input (nA, nB and nC) to output (nY) Table 8. Test data Supply voltage Input Load VI tr, tf CL RL 1.2 V VCC ≤ 2 ns 30 pF 1 kΩ 1.65 V to 1.95 V VCC ≤ 2 ns 30 pF 1 kΩ 2.3 V to 2.7 V VCC ≤ 2 ns 30 pF 500 Ω 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 15 74LVC11 Nexperia Triple 3-input AND gate 11 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 9.  Package outline SOT108-1 (SO14) 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 15 74LVC11 Nexperia Triple 3-input AND gate SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 10.  Package outline SOT337-1 (SSOP14) 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 15 74LVC11 Nexperia Triple 3-input AND gate TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Figure 11.  Package outline SOT402-1 (TSSOP14) 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 15 74LVC11 Nexperia Triple 3-input AND gate DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 Eh e 14 8 k 13 9 Dh X k 0 2 scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Figure 12.  Package outline SOT762-1 (DHVQFN14) 74LVC11 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 15 74LVC11 Nexperia Triple 3-input AND gate 12 Abbreviations Table 9. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13 Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC11 v.7 20171110 Product data sheet - 74LVC11 v.6 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74LVC11 v.6 20111117 Modifications: • Legal pages updated. • Table 6, bodyrow ΔICC: condition VCC changed. 74LVC11 v.5 20111025 74LVC11 v.4 - 74LVC11 v.5 Product data sheet - 74LVC11 v.4 20040113 Product specification - 74LVC11 v.3 74LVC11 v.3 19980428 Product specification - 74LVC11 v.2 74LVC11 v.2 19980428 Product specification - 74LVC11 v.1 74LVC11 v.1 - - - - 74LVC11 Product data sheet Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 15 74LVC11 Nexperia Triple 3-input AND gate 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74LVC11 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 15 74LVC11 Nexperia Triple 3-input AND gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74LVC11 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 10 November 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 15 74LVC11 Nexperia Triple 3-input AND gate Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Package outline ...................................................8 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 November 2017 Document identifier: 74LVC11 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC11BQ,115 74LVC11D,112 74LVC11DB,112 74LVC11DB,118 74LVC11D,118 74LVC11PW,112 74LVC11PW,118 74LVC11PW/AUJ
74LVC11D,118 价格&库存
很抱歉,暂时无法提供与“74LVC11D,118”相匹配的价格&库存,您可以联系我们找货
74LVC11D,118
  • 2500+0.875592500+0.10581
  • 5000+0.822525000+0.09939
  • 12500+0.7694512500+0.09298
  • 25000+0.7057725000+0.08529
  • 62500+0.6792462500+0.08208
  • 125000+0.65675125000+0.07936
库存:2518
74LVC11D,118
    • 1+1.21187
    • 10+0.98043
    • 30+0.88118
    库存:1
