74LVC132A-Q100
Quad 2-input NAND Schmitt trigger
Rev. 1 — 4 April 2013
Product data sheet
1. General description
The 74LVC132A-Q100 provides four 2-input NAND gates with Schmitt trigger inputs. It
can transform slowly changing input signals into sharply defined, jitter-free output signals.
The inputs switch at different points for positive and negative-going signals. The difference
between the positive voltage VT+ and the negative voltage VT is defined as the input
hysteresis voltage VH.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these
devices as translators in mixed 3.3 V and 5 V environment.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.2 V to 3.6 V
5 V tolerant inputs for interfacing with 5 V logic
CMOS low-power consumption
Direct interface with TTL levels
Unlimited input rise and fall times
Inputs accept voltages up to 5.5 V
Complies with JEDEC standard JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Applications
Wave and pulse shapers for highly noisy environments
Astable multivibrator
Monostable multivibrator.
74LVC132A-Q100
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width SOT108-1
3.9 mm
74LVC132APW-Q100 40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads; SOT402-1
body width 4.4 mm
74LVC132ABQ-Q100 40 C to +125 C
DHVQFN14 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads;
14 terminals; body 2.5 3 0.85 mm
74LVC132AD-Q100
Version
SOT762-1
5. Functional diagram
1
1 1A
2 1B
1Y 3
4 2A
5 2B
2Y 6
9 3A
10 3B
3Y 8
12 4A
13 4B
4Y 11
4
9
10
12
13
Fig 1. Logic symbol
Product data sheet
5
3
6
8
11
A
mna212
74LVC132A_Q100
2
Y
B
001aac532
mna246
Fig 2. IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3. Logic diagram (one gate)
Nexperia B.V. 2017. All rights reserved
2 of 16
74LVC132A-Q100
Nexperia
6. Pinning information
6.1 Pinning
/9&$4
WHUPLQDO
LQGH[DUHD
9&&
/9&$4
*1'
*1'
9&&
*1'
7UDQVSDUHQWWRSYLHZ
DDD
(1) The die substrate is attached to this pad using
conductive die attach material. It cannot be used as
a supply pin or input.
Fig 4. Pin configuration SO14 and TSSOP14
Fig 5. Pin configuration DHVQFN14
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input
1B
2
data input
1Y
3
data output
2A
4
data input
2B
5
data input
2Y
6
data output
GND
7
ground (0 V)
3Y
8
data output
3A
9
data input
3B
10
data input
4Y
11
data output
4A
12
data input
4B
13
data input
VCC
14
supply voltage
74LVC132A_Q100
Product data sheet
3 of 16
74LVC132A-Q100
Nexperia
7. Functional description
Table 3.
Function table[1]
Input
Output
nA
nB
nY
L
L
H
L
H
H
H
L
H
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
IIK
input clamping current
IOK
output clamping current
IO
output current
ICC
Conditions
Min
Max
Unit
0.5
+6.5
V
[1]
0.5
+6.5
V
[2][3]
0.5
VCC + 0.5
V
50
mA
VO > VCC or VO < 0 V
50
mA
VO = 0 V to VCC
50
mA
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
Ptot
total power dissipation
[1]
VI < 0 V
Tamb = 40 C to +125 C
[4]
65
+150
C
500
mW
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
When VCC = 0 V (Power-down mode), the output voltage can be 3.6 V in normal operation.
[4]
For SO14 packages: Ptot derates linearly with 8 mW/K above 70 C.
For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Typ
Max
Unit
1.65
3.6
V
functional
1.2
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+125
C
74LVC132A_Q100
Product data sheet
4 of 16
74LVC132A-Q100
Nexperia
10. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Min
Typ[1]
Max
Unit
IO = 100 A; VCC = 1.65 V to 3.6 V
VCC 0.2
V
IO = 4 mA; VCC = 1.65 V
VCC 0.45 -
V
IO = 8 mA; VCC = 2.3 V
VCC 0.5
V
IO = 12 mA; VCC = 2.7 V
VCC 0.5
V
IO = 18 mA; VCC = 3.0 V
VCC 0.6
V
IO = 24 mA; VCC = 3.0 V
VCC 0.8
V
Conditions
Tamb = 40 C to +85 C
VOH
HIGH-level output voltage
LOW-level output voltage
VOL
VI = VT+ or VT
VI = VT+ or VT
0.2
V
0.45
V
0.6
V
0.4
V
0.55
V
II
input leakage current
VCC = 3.6 V; VI = 5.5 V or GND
0.1
5
A
ICC
supply current
VCC = 3.6 V; VI = VCC or GND; IO = 0 A
0.1
10
A
ICC
additional supply current
per input pin; VCC = 2.7 V to 3.6 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND to VCC
4.0
pF
VCC 0.3
V
VCC 0.6
V
VCC 0.65 -
V
VCC 0.65 -
V
VCC 0.75 -
V
VCC 1
V
0.3
V
VOH
VOL
VI = VT+ or VT
VI = VT+ or VT
0.65
V
0.8
V
0.6
V
0.8
V
II
A
ICC
supply current
40
A
ICC
5
mA
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
74LVC132A_Q100
Product data sheet
5 of 16
74LVC132A-Q100
Nexperia
11. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 7.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
Min
Max
Min
Max
18.0
ns
VCC = 1.65 V to 1.95 V
2.0
7.2
12.8
2.0
16.0
ns
VCC = 2.3 V to 2.7 V
1.5
4.0
7.6
1.5
9.6
ns
[2]
nA, nB to nY; see Figure 6
VCC = 1.2 V
tsk(o)
CPD
[1]
40 C to +125 C Unit
Typ[1]
VCC = 2.7 V
1.5
3.8
7.6
1.5
9.6
ns
VCC = 3.0 V to 3.6 V
1.5
3.4
6.4
1.5
8.0
ns
1.0
1.5
ns
output skew time
[3]
power dissipation
capacitance
[4]
per buffer; VI = GND to VCC
10.5
pF
10.8
pF
11.4
pF
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
VI
nA, nB input
VM
GND
tPHL
tPLH
VOH
nY output
VM
mna213
VOL
VM = 1.5 V at VCC 2.7 V.
VM = 0.5 VCC at VCC < 2.7 V.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6. The input (nA, nB) to output (nY) propagation delays
74LVC132A_Q100
Product data sheet
6 of 16
74LVC132A-Q100
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VI
PULSE
GENERATOR
VO
DUT
RT
CL
RL
001aaf615
Test data is given in Table 8. Definitions for test circuit:
RL = Load resistance
CL = Load capacitance including jig and probe capacitance
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 7.
Table 8.
Load circuitry for measuring switching times
Test data
Supply voltage
Input
Load
VI
tr, tf
CL
RL
1.2 V
VCC
2 ns
30 pF
1 k
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
2.7 V
2.7 V
2.5 ns
50 pF
500
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
74LVC132A_Q100
Product data sheet
7 of 16
74LVC132A-Q100
Nexperia
13. Transfer characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); see Figure 8.
Symbol
Parameter
positive-going
threshold voltage
VT+
negative-going
threshold voltage
VT
hysteresis voltage
VH
40 C to +85 C
Conditions
Min
Max
Min
Max
Unit
VCC = 1.2 V
0.2
1.0
0.2
1.0
V
VCC = 1.65 V
0.4
1.3
0.4
1.3
V
VCC = 1.95 V
0.6
1.5
0.6
1.5
V
VCC = 2.3 V
0.8
1.7
0.8
1.7
V
VCC = 2.5 V
0.9
1.7
0.9
1.7
V
VCC = 2.7 V
1.1
2
1.1
2
V
VCC = 3 V
1.2
2
1.2
2
V
VCC = 3.6 V
1.2
2
1.2
2
V
VCC = 1.2 V
0.12
0.75
0.12
0.75
V
VCC = 1.65 V
0.15
0.85
0.15
0.85
V
VCC = 1.95 V
0.25
0.95
0.25
0.95
V
VCC = 2.3 V
0.4
1.1
0.4
1.1
V
VCC = 2.5 V
0.4
1.2
0.4
1.2
V
VCC = 2.7 V
0.8
1.4
0.8
1.4
V
VCC = 3 V
0.8
1.5
0.8
1.5
V
VCC = 3.6 V
0.8
1.5
0.8
1.5
V
VCC = 1.2 V
0.1
1.0
0.1
1.0
V
VCC = 1.65 V
0.2
1.15
0.2
1.15
V
VCC = 1.95 V
0.2
1.25
0.2
1.25
V
(VT+ VT)
VCC = 2.3 V
0.3
1.3
0.3
1.3
V
VCC = 2.5 V
0.3
1.3
0.3
1.3
V
VCC = 2.7 V
0.3
1.1
0.3
1.1
V
0.3
1.2
0.3
1.2
V
0.3
1.2
0.3
1.2
V
VCC = 3 V
[1]
VCC = 3.6 V
[1]
40 C to +125 C
Typical transfer characteristic is displayed in Figure 9.
74LVC132A_Q100
Product data sheet
8 of 16
74LVC132A-Q100
Nexperia
14. Waveforms transfer characteristics
VT+
VO
VI
VH
VT−
VO
VI
VH
VT−
Fig 8.
VT+
mna208
mna207
VT at 20 % and VT+ at 70 %
Definition of VT+, VT and VH
mna582
5
I CC
(mA)
4
3
2
1
1.2
1.8
2.4
3
VI (V)
VCC = 3.3 V.
Fig 9. Typical transfer characteristic
74LVC132A_Q100
Product data sheet
9 of 16
74LVC132A-Q100
Nexperia
15. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 10. Package outline SOT108-1 (SO14)
74LVC132A_Q100
Product data sheet
10 of 16
74LVC132A-Q100
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 11. Package outline SOT402-1 (TSSOP14)
74LVC132A_Q100
Product data sheet
11 of 16
74LVC132A-Q100
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
0.5
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 12. Package outline SOT762-1 (DHVQFN14)
74LVC132A_Q100
Product data sheet
12 of 16
74LVC132A-Q100
Nexperia
16. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
17. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC132A_Q100 v.1
20130404
Product data sheet
74LVC132A_Q100
Product data sheet
13 of 16
74LVC132A-Q100
Nexperia
18. Legal information
18.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
18.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC132A_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
14 of 16
74LVC132A-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
18.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
19. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC132A_Q100
Product data sheet
15 of 16
Nexperia
74LVC132A-Q100
20. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
18
18.1
18.2
18.3
18.4
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Transfer characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms transfer characteristics. . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 04 April 2013
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC132ABQ-Q100X 74LVC132APW-Q100J 74LVC132AD-Q100J
